View Full Version : Problems in Cold weather?
psonoda
12-03-2007, 05:47 PM
Not able to rev over 6k.
Does your car do this. The other day I started the car and took off. (OK I was late) Anyway I normally don't push the car until it warms up. But, being in a hurry, I punched the gas (I had been driving a couple of minutes) and the car coughed and acted like it hit a rev limiter at 6k rpm. Has this happened to anyone else? Is this supposed to happen?
Let me know.:uhh:
New Yorker
12-03-2007, 06:06 PM
Nope, not supposed to happen.
DarkBrew
12-03-2007, 06:11 PM
The ECU is protecting the engine (consult the manual) but the coughing I'm not sure about.
4me2
12-03-2007, 06:12 PM
Many threads about this. already.
PSUGreySreet
12-03-2007, 08:57 PM
The engine will cut-off fuel at 6k RPM to save your engine from damage. Never punch it before warming it up. If you need to leave ASAP, wait until needle falls to 1.5-2k and then keep RPM's low in shifting until the temperature needle rises to the middle.
champi0n
12-04-2007, 10:44 AM
When i start my car it never idles above 1.5k (usually around 1k)
Razz1
12-04-2007, 10:50 AM
By your avitar your idle is way too high!
psonoda
12-04-2007, 04:18 PM
Thanks. That is what I thought it was. Anyway, I have not done it since. I have to admit, it is real easy to rev the motor without realizing it. I try to keep the revs down below 4k until the motor warms up completely. :uhh:
Renesis07
12-04-2007, 04:27 PM
normal
delhi
12-04-2007, 09:27 PM
....just like the M3! :lol2:
PSUGreySreet
12-05-2007, 07:10 PM
Even when cold, it never shoots up to about 3 - 3.5k and then slowly comes down?? You have a winner then...
nycgps
12-05-2007, 07:13 PM
Normal.
Default Protection.
When I start my car, sometimes it jumps up to 2.1 K for couple of seconds before it goes back down to like 1.8K.
Cuz its too cold, today is about 30, tonight will go around 26, couple days ago it was 20 degrees.
