View Full Version : Dumb question
RotoRocket
12-01-2007, 10:32 PM
Last night, after dropping off a friend who lives on a dirt road, and who has a bizarre and long driveway, I accidentally backed into a ditch by the side of his driveway when leaving.
There was a thud, but I managed to easily drive out of the ditch and everything was fine and I went home (at speeds of 75+) on the highway.
I noticed a small dent in my muffler today. It is maybe a couple inches wide, and maybe a half inch deep, and was obvious because the ground that made contact with it left it clean.
The assembly and everything is solid. There don't seem to be any structural issues, and there are no holes or anything like that in the muffler or exhaust.
I'm assuming this should be a non-issue, right?
I should have just turned around in his driveway rather than backing out.
Mazurfer
12-01-2007, 10:34 PM
Right....shouldn't be any issue.........if that's all that hit. I do assume you looked everything over really well.
RotoRocket
12-01-2007, 10:35 PM
I did.
I crawled under there with a flashlight.
It looked to be the only part to make contact with the ground.
Mazurfer
12-01-2007, 10:37 PM
I did.
You're good to go then, unless it starts to develop a crack due to heat, but don't worry about it.
RotoRocket
12-01-2007, 10:38 PM
Thanks Maz.
Mazurfer
12-01-2007, 10:41 PM
Thanks Maz.
I should be the 2nd member of this club. 2005 MT and no issues as well.
Renesis07
12-02-2007, 04:19 PM
I have a dent in mine too, I think it happend when I hit a rabbit one night but not sure. Anyway, mine hasnt had an issue and its been there (or when I noticed :) ) for about 20K miles now. Its about 2 inches long and a half inch dented in.
