Uneven tein springs
Old Nov 30, 2007 | 01:58 PM
redD3vil's Avatar
Uneven tein springs
I recently installed tein s techs on my 8 and at first they were fyne they seems balanced n even, after 3 weeks of driving around with them , the front passenger side i sitting nice like it suppose to and tha passener rear is fyne ,. the driver side , the front it higher then tha pass side and tha driver side rear is lower than tha passener side....tha car looks lobsided.....i check that they were installd correctly n everythin seems fyne..any idea of what tha problem could be?
Old Nov 30, 2007 | 02:11 PM
SouthFL's Avatar
Try the loosening of the control arm bolt trick and see if the car settles evenly.
Old Nov 30, 2007 | 02:39 PM
lesper4's Avatar
T-29 years and counting
what rims you got there?
yeah let them settle lossened
Old Dec 1, 2007 | 12:33 AM
redD3vil's Avatar
19 hp lightning
Old Dec 1, 2007 | 12:53 AM
DOMINION's Avatar
I don't buy Kool-Aid
Do you have to pre load anything? Or is that with Coils only?
Old Dec 1, 2007 | 12:20 PM
HERO's Avatar
Ive had the same problem for a long time now. Tein S with Konis here. Nothing seems to have helped. Ive read somewhere that the rx8 ride height sits higher in the passengar rear than the driver rear. Only fix is to get yourself some coilovers.
Old Dec 1, 2007 | 12:24 PM
redD3vil's Avatar
i dont understand tha way it luks is pissing me off , i love tha way it luks on tha passenger side but tha driver side luks uneven , i kno ppl with teins on there and dnt have this probllem
Old Dec 15, 2013 | 08:43 PM
yurcivicsux's Avatar
Tein s-techs- i also have the same issue, my passenger side is 1/2 higher. did preload, researched until i almost lost sleep. this is very frustrating. i would love a solution. took everything apart and double checked even.....no result.
Old Dec 15, 2013 | 10:25 PM
EricB's Avatar
#225 of 1000
are your springs on backwards? (front is on back, back is on front?)
Old Jan 20, 2014 | 05:11 PM
Fickert's Avatar
Instagram @slowpandemrx8
I have this same problem but with the rear. My passenger side sometimes is lower than my drivers side and then sometimes even. I park it in my garage every night and that is where I judge it. Also, it seems that the drivers rear side didn't drop much at all when I installed them, and my friends rx8 is stock and his rear end sits a little bit lower than mine yet. Help!!
Sakebomb Garage
Sakebomb Garage
Oct 22, 2015 04:28 PM
duworm
Oct 1, 2015 04:57 PM
Turman-ator
11
Sep 22, 2015 11:22 AM
Sakebomb Garage
Group Buy Center
Sep 12, 2015 08:18 PM
