View Poll Results: Panel air filters: OEM or aftermarket?
OEM is best!
32.43%
Aftermarket filter (K&N, etc.) is so worth the 2 extra hp!
67.57%
Voters: 37. You may not vote on this poll
Poll for B-stock RX-8 drivers: High flow panel filter or OEM?
Old Nov 29, 2007 | 11:51 AM
chiketkd's Avatar
Row faster, I hear banjos
Just wondering what others are doing, even though I doubt the gains would be major...
Did you stick with an OEM filter or upgrade to a K&N, etc.?
Old Nov 29, 2007 | 11:58 AM
CosmosMpower's Avatar
1935 lbs. FTW!
It really doesn't matter either way as long as it's clean.
Old Nov 29, 2007 | 12:00 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
Guess someone needs to read SportsCar.
btw I have a used, but recharged, K&N for sale.
Old Nov 29, 2007 | 12:31 PM
mwood's Avatar
What'd you do, put new batteries in it?
I know, you cleaned it and oiled it...just never heard that referred to as "recharged"...
Also, do you really think your one day of dyno work with filters is statistically conclusive?
Old Nov 29, 2007 | 01:12 PM
ULLLOSE's Avatar
Every time you post you make yourself look more like a newb: http://www.knfilters.com/clningacc.htm
Old Nov 29, 2007 | 01:23 PM
mwood's Avatar
did you use official "Filtercharger" oil? 'cause if you didn't, then it doesn't count as a an official "recharge"...
Old Nov 29, 2007 | 01:26 PM
ULLLOSE's Avatar
If I didn't I would not have said it was recharged.
Old Nov 29, 2007 | 01:53 PM
chiketkd's Avatar
Do you have a month & year of the issue I should refer to?
I've only been an SCCA member since 2006 (i.e. I didn't get Sportscar before then).
Old Nov 29, 2007 | 02:08 PM
mwood's Avatar
It was very recent, maybe last month? The issue with Mark Huffman's Lotus D Mod car on the cover...the first issue where they let ULLLLLLLLLLLLLLLLLOSE loose in his new editorial role...
Old Nov 29, 2007 | 02:43 PM
chiketkd's Avatar
Sounds good - I'll take a look this evening. Thanks Mike.
Old Nov 29, 2007 | 03:05 PM
ULLLOSE's Avatar
Nov 07.
Old Nov 29, 2007 | 07:37 PM
ASSt. editorial role ...
Old Nov 29, 2007 | 09:13 PM
chiketkd's Avatar
Nov 07.
Thanks. I found the article. I think I'll pass on the used K&N!
The thinness of Green filter is kinda scary. I'm kinda in a toss-up between that and just sticking with the OE filter.
Old Nov 29, 2007 | 09:24 PM
ULLLOSE's Avatar
That is a great idea for you....btw I have an OE air flter with dyno time only if you want to buy a fresh one.
Old Nov 29, 2007 | 09:29 PM
chiketkd's Avatar
I'll PM you an offer (since I know what you paid for it from the article). If you accept, I can Paypal you the $$$ tonight.
Old Dec 1, 2007 | 12:18 AM
WpgDSMer's Avatar
Anyone have a scan of, or link to the article? I don't get sportscar (can't seem to find a link to anything on scca's page either). From the discussion here, it seems the OEM filter is probably pretty descent.
Old Dec 1, 2007 | 10:46 AM
noticed that they didn't show a dyno run sans air filter ...
Old Dec 1, 2007 | 01:13 PM
chiketkd's Avatar
DISCLAIMER: My scanner at home isn't the best. But I scanned the three pages of the article. I hope it's readable...
My thoughts: The OE filter is decent, but a new Green or K&N filter are slightly better. FWIW, while I'm picking up the virtually brand new OE filter Isley used in this article, I will also be getting a new Green Filter to use at autocross events only. Even though I'll be changing my oil every 2,500-3,000 miles with this car, I don't trust using a Green Filter for daily driving.
Old Dec 3, 2007 | 10:50 PM
WpgDSMer's Avatar
thanks for the scan.
Old Dec 26, 2007 | 08:31 AM
chiketkd's Avatar
FWIW, I picked up a new Green panel filter yesterday to use at autocross events only throughout the '08 season. If a new Green filter truly makes 5hp & 2lb-ft more than a new OE filter, then it'll be worth the $.
Question to Isley - as the ECU 'learns' that more air is getting into the engine with a high flow filter, will the performance increase you saw on the dyno be reduced over time?
Old Dec 26, 2007 | 11:06 AM
ULLLOSE's Avatar
We did a lot of dyno runs with all of the filters, and changed them around more than once to try and fool the ECU, our results stayed consistent. I don't think you could spend enough time on the dyno to see if the car learns and compensates, that could take a day or more of driving, and to come back to the dyno on a different day will give different results. Regardless of the actual number, what we found was no matter what order or how many pulls we did, the Green made the most power of the filters will listed.
Old Dec 26, 2007 | 11:33 AM
chiketkd's Avatar
Old Dec 29, 2007 | 11:10 PM
tpdrx8's Avatar
Chike, where'd you get the green? Best price I've found is about $61 inc. S&H at Car-stuff.
Old Dec 30, 2007 | 01:23 AM
chiketkd's Avatar
That's cheaper than what I paid Tom. I got mine for $65 shipped off of Ebay.
Old Dec 30, 2007 | 01:45 PM
mwood's Avatar
YMMV...but, probably not...literally
