View Full Version : why are 04 RX-8's faster than any other RX8's?
callee
11-28-2007, 08:03 PM
We did a little test because I didn’t believe at first but after 10 runs between a 04 rx8 w/ 42k miles and a 06 rx8 w/ 13k miles... the 04 rx8 wins it!!
Both stocks!
Any ideas???? :confused:
Mazurfer
11-28-2007, 08:05 PM
Both stocks!
Ohhhhhhh....I think I'll just let this one slide right on by without making any comments! :banghead:
///aldo
by how much.. who was the better driver? ect ect
abbid
11-28-2007, 08:08 PM
HOw many passengers in each car?
what are the weights of each driver?
was the 06 auto?
were you street racing?
4me2
04's weigh less. ^ 0-25mph street racing?
Soravia
11-28-2007, 08:10 PM
Maybe it was a Sport Vs GT and there's difference in weight? Maybe someone is driving better? Maybe one car has better engine management?
Mazurfer
11-28-2007, 08:14 PM
Still missing a few possibilities guys....C'mon :uhh: :)
rowteree
11-28-2007, 08:20 PM
rumor has it as rotaries age, they become faster since they are already fully broken in
///aldo
11-28-2007, 08:24 PM
chuck norris was driving the 04
rowteree
11-28-2007, 08:28 PM
i heard when chuck norris does push ups he doesnt push himself up, he pushes down the earth
thecow135
11-28-2007, 09:24 PM
so mike huckabee says
callee
11-28-2007, 09:28 PM
we both traded cars!! 5 times each!!
and
NO ... to street racing!
we did it indoors at my grandfather's old factory! (its big)
but
Seriously guys....
Why are the 04's faster!???
Its wins by a few inches
tajabaho1
11-28-2007, 09:40 PM
it has more miles, which means older, older rotaries = faster (if they don't loose compression)
4me2
11-28-2007, 09:42 PM
tires?
jones75254
11-28-2007, 09:49 PM
Making a pretty bold generalization arent you? Because this ONE 04 is quicker than this ONE 06, that makes 04's the fastest? :uhh:
....mind you i own an 04, so i would like for this to be the case, but lets get real here. We would need a much larger sample base to be able to make such a claim.
Renesis07
11-28-2007, 11:10 PM
Both stocks!
06's engine isnt broken in yet, as rotaries get older they get faster! As mentioned above
alnielsen
11-28-2007, 11:36 PM
06's engine isnt broken in yet, as rotaries get older they get faster! As mentioned aboveYep, It's true. The engine will be it's fastest just before it pukes its guts out (i.e. blows up).
Old Rotor
11-28-2007, 11:52 PM
and
but
Seriously guys....
I have had seven rotary cars and it is true that they do get stronger after you put a few thousand miles on them. The car has less frictions after the surface's smooth out and open up ever so slightly. We call it the engine has loosened up.
N rider89
11-29-2007, 12:17 AM
they get better with age, then die.
SkyLee
11-29-2007, 12:34 AM
gets faster in age
eviltwinkie
11-29-2007, 03:02 AM
Uhhh...most engines are at their "fastest" when they puke their guts out...that's generally one of the most common contributing causes of failure...
heh
eviltwinkie
11-29-2007, 03:03 AM
you talking about engines or your date?
TrochoidMagic
11-29-2007, 03:27 AM
though rotaries get faster with a few miles on it, it may be true. the carbon buid-up raises compression giving it better performance, but consequently at its oldest in age with so much buid-up it'll eventually blow the motor. but the truth behind this isn't exclusive to rotaries, such car's as NSX has been said to have the most horses after 45k.
racers have said the rotary is at its strongest before breathing its last breath...sad to say.
enforcer
11-30-2007, 03:39 AM
Callee to put it nicely, without some validity of the experimental findings it....
http://gispro.files.wordpress.com/2007/06/bullshit.jpg
Crztrtldck
12-01-2007, 07:24 PM
nooooo!
my beautiful 04
never!
valpac
12-02-2007, 06:10 AM
a win by inches? well within the margin of error. hell, wind speed and direction could be the answer. you cannot claim a victor based only on your limited test.
Bunique
12-02-2007, 06:45 AM
Even the amount of gas in each car throws of your results. Too many unknown variables.
Spin9k
12-02-2007, 07:08 AM
How 'bout ECU differences. The '04 ECUs are unique I think, then they changed them. The '04s started out with ~250HP before they detuned them, so the potential for motor+ECU matchup to produce high power due to manufacturing tolereance was possible. The later ECUs they likely designed any chance of improved power out of them.
Or..if you don't like that idea...I like the idea of smooth housing reducing internal friction after being honed to a nice finish by a well used '04 rotor.
knight7
12-02-2007, 10:25 AM
Why cant it be that the 04s are really faster??, make us owners happier; i mean you guys have the better key we have the better faster engine etc, etc.
