Common repairs for the RX-8: let's get some accurate info
Old Nov 27, 2007 | 01:12 PM
mkaresh's Avatar
In response to requests, I've added a Common Auto Repairs Database (CARDb) to my site, TrueDelta.com.
Currently it's just possible to add common repairs to the database. When the database has been populated, owners will be asked to report whether or not their car has actually had these problems. So we can find out how common "common repairs" actually are.
My suspicion: usually less common than people think.
The form includes a field for a forum thread URL, so people can be directed here for thorough discussions if there is a thread discussing the repair, and perhaps discover a great site they weren't previously aware of.
Old Nov 27, 2007 | 01:23 PM
eclipsegsx's Avatar
F-14 on afterburners
the damn visors break! common repair. mine has 12k on it and needs a new drivers side visor!
tajabaho1's Avatar
Destroying Threads
add spark plug and coils................
apart from that.......blahh
Old Nov 27, 2007 | 02:41 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Mine had the following done after I bought it new in the year and half I owned it (maintenance not included, just repairs).
2005 MY, Nov 04 build.
Brake TSB (squeeling)
Door/glove box rattle
Condensation in taillights
Foggy headlights
Cup holder door broke
Drivers side visor X2
Replaced starter
Engine Recall (just checked no issues)
All covered under warranty
Old Nov 27, 2007 | 02:56 PM
if its covered under warranty it should not be included into the database
I will say the most common thing to *Replace* (not repair) is engine oil.
Old Nov 27, 2007 | 03:19 PM
1935 lbs. FTW!
Why is that? Some 04's are out of warranty and the same common problems still happen to them just because they're not covered but potential buyers should still have the right to know what might potentially break on these cars regardless of whose dime it's on.
bsteimel's Avatar
Nice !!!
I bought a used 2004 with 22k miles and have owned the car for little over a year I have had
Repair:
transmission rebuild
both tail lights had water
engine mounts
new starter (hard start)
new battery (hard start)
new spark plugs ( hard start)
parking brake lever
Oil dipstick (milky substance)
AC **** replace
cost = 0
Maintenance:
clutch replaced (35k miles annoyingly early)
front brake pads replaced
8 oil and filter changes
Air filter replace and 1 refresh
cooling system flush
2 wiper blade replaces
normal tire maintenance
cost: about $1000
also new tires: $800
over $4000 dollars in fuel
Repairs Before I bought the car:
AC enhanced
all recalls
The grin one receives as the tach hits 9000 RPMS priceless
I would be glad to join your site add my information to your database
Old Nov 27, 2007 | 03:47 PM
DarkBrew's Avatar
Extraordinary Engineering
Rear O2 sensor replaced at just over 77000 km.
Airbag light => Connectors under seat
Gas cap CEL => New gas cap
Old Nov 27, 2007 | 09:15 PM
Soravia's Avatar
Why was the clutch replaced so early? You were not the first owner? I'm looking to buy an RX-8 at an auction, maybe I should look into that. How much to replace the clutch? I can do the labor.
Old Nov 27, 2007 | 11:09 PM
mkaresh's Avatar
My research counts clutches if something other than the lining forced the repair. Otherwise, it's a wear item, and you'll find some early failures with any model.
I'll have to search for a thread here on the sun visors unless someone has already added it, sounds like the sort of thing that should be in there.
Old Nov 28, 2007 | 09:36 AM
eclipsegsx's Avatar
lol i just bought mine from an old couple. clutch replaced at.... 9100 miles. wow they must have been on that thing!
mines 12k miles with a new clutch barely 2500 miles old. How much does mazda charge for an oil change?
Old Nov 28, 2007 | 11:08 AM
voodootrip's Avatar
prone to flooding
2004 45K miles
visor
airbag light
power steering pump x2
battery
plugs
new starter
cup holder door
gas cap
engine mounts
and yet i still love her...
Old Nov 28, 2007 | 11:16 AM
secret8gent's Avatar
the enemy in the mirror
Whaaaaat?
Old Nov 28, 2007 | 11:57 AM
New Yorker's Avatar
2005 purchased new 2/06, now has 13,200 miles. Problems:
• slightly squeaky clutch pedal: fixed
• occasionally squeaky sunroof (only over rough roads, only when open): fixed
That's all.
Old Nov 29, 2007 | 09:30 AM
bsteimel's Avatar
Nice !!!
I'm not exactly sure why the clutch was replaced so early. I was the second owner, the tires looked pretty much normal wear for 22k miles but don't know if they were the first set or not. So i couldn't tell anything when i bought the car
pretty much the entire transmission had to be rebuilt so that could have said something. I do know of a couple 2004's that had tranny problems so i have no clue if i was simply an unlucky owner or the previous owner was doing 9k drops or something. Or was simply a really bad driver.
It was 500 parts for the clutch, it was done with the tranny rebuild so labor was included under warranty. I think its probably around 700-1000 depending on the service place.
Old Nov 29, 2007 | 10:00 AM
tajabaho1's Avatar
Destroying Threads
Originally Posted by secret8gent
Whaaaaat?
what the
Old Nov 29, 2007 | 10:38 AM
8is>enuff's Avatar
Bland
Warranty:
Clogged cat (X2) - Eventually caused flooding.
New upper intake manifold
Blown coils
Rear tailights replaced
Airbag sensors under both front seats replaced
Clutch pedal fell off
Center console clip broke (X2)
Center console accessory outlet broke
No warranty:
New clutch (cracked clutch spring - one owner, no clutch drops)
Navigation controls stopped working
Heater controls stopped working
Sunglass holder broke off.
Crunch at the end of clutch pedal (at the firewall)
That's all I can remember right meow.
Old Nov 29, 2007 | 11:39 AM
Speedy400's Avatar
Originally Posted by 8is>enuff
Warranty:
Blown coils
No warranty:
Year and mileage?
Old Nov 29, 2007 | 11:40 AM
Speedy400's Avatar
'05 Sport, 5K miles
Under Warranty:
Headlight condensation
Tail light condensation
Old Nov 29, 2007 | 11:55 AM
8is>enuff's Avatar
Bland
Originally Posted by Speedy400
Year and mileage?
Whoops. 6MT '04, 52,8XX mi. Built 8/03.
Old Nov 29, 2007 | 12:11 PM
tajabaho1's Avatar
Destroying Threads
how can we have power steering fluid? we dont use power steering!! we have electronic assisted steering
Old Nov 29, 2007 | 12:22 PM
Juggernaut9's Avatar
Phantom Blue
You should also seperate the issues by year. some issues are no longer found in the newer cars while others are across all the years.
Old Nov 29, 2007 | 01:15 PM
Jeison's Avatar
hey new yorker what caused your squeaky clutch?
Old Nov 29, 2007 | 02:17 PM
New Yorker's Avatar
You know, I think it's the same squeaky clutch problem mentioned in this TSB: http://www.finishlineperformance.com...11-06-1724.pdf
Unfortunately, mine started squeaking before the TSB was issued, so the dealer simply lubed the clutch pedal with something. It hasn't squeaked since (over a year now), so I'm cool with that. If it starts squeaking again, I'll bring in the TSB and have them install the revised part.
Old Dec 2, 2007 | 09:42 PM
mkaresh's Avatar
I think the clutch in my father's 2005 squeaks. It can be annoying. He should probably have this checked out.
