Oil??
Old Nov 27, 2007 | 12:33 AM
mdr's Avatar
mdr
Oil??
Yes I searched.
Ok what brand of oil are you guys using and where are you getting it?
I just checked my oil and need to top up, I went to Super Cheap around the corner and after 30 minutes of looking there is no oil they sale in the Mazda recommended W range that is not synthetic.
I read in another thread that MA does not recommend syn oil. So is the only place to get oil a MA dealer???
Old Nov 27, 2007 | 01:26 AM
Revolver's Avatar
Shootin' from the hip
If you don't want to use synthetic, AFAIK, yes.
Old Nov 27, 2007 | 01:27 AM
auzoom's Avatar
Hmmmmmm.........
Short answer is yes, the only easily accessible place you can get non synthetic, RX-8 Spec oil is via MA.
Personally I think a semi synth is not a major issue and 10W30 is fine, even 5 or 10W40.
Cheers
Andrew
Old Nov 27, 2007 | 01:45 AM
erx8s's Avatar
There is a 10w 30 mineral oil available penzoil at halve the price at Repco , supercheap.autobarn etc
Cheers
Michael
Old Nov 27, 2007 | 01:55 AM
DrewMan's Avatar
Culpam Poena Premit Comes
Just used the mineral Motul oil
5w30
I think it was $60 for 5 litres? should be good i thought id give it a go
Old Nov 27, 2007 | 03:11 AM
DMRH's Avatar
Am using the Mazda Rotary oil personally...............
Purchased via West End Mazda via a mate (to get trade price) at $46 per container
REgards
Old Nov 29, 2007 | 07:25 AM
XLR83N's Avatar
i use royal purple 5W30, about $90 for 5L at autobarn
Old Nov 29, 2007 | 05:15 PM
Cromax's Avatar
Buzz Buzz Buzz
WHOA! You serious? I was going to try that, but if it's $90 that's too rich for me!
Old Nov 30, 2007 | 05:03 AM
Black-8's Avatar
Rotary noob
try http://www.performancelub.com/Royal%...0pricelist.htm, speak to Harold, he's the man!
Old Nov 30, 2007 | 05:38 AM
Cromax's Avatar
Buzz Buzz Buzz
That's not so bad ... but I want a datasheet for it. What's the TBN of it?
Old Nov 30, 2007 | 06:04 AM
Black-8's Avatar
Rotary noob
is this what you're after? http://www.royalpurple.com/motor-oil-pp.html
what's TBN?
Old Nov 30, 2007 | 05:57 PM
Cromax's Avatar
Buzz Buzz Buzz
Total Base Number is just the number of milligrams of KOH per gram.
It determines how long the oil will last before the oil starts to oxidise. Therefore it gives you an idea as to how long the oil will last between changes.
Old Dec 1, 2007 | 05:47 AM
enforcer's Avatar
REgards
+1
Old Dec 1, 2007 | 09:51 PM
Cromax's Avatar
Buzz Buzz Buzz
Well, at the moment that is what I'm using as well, however I'm doubting Mazda's statement about MRO being the only oil to use in our cars.
Old Dec 1, 2007 | 10:02 PM
DrewMan's Avatar
I think it was the fact that that was the ONLY oil mazda tested with the engine that works...which is why they reccommend it.
It doesnt mean that other oils cant be used
Old Dec 2, 2007 | 04:00 AM
thisllub's Avatar
10W30 most closely matches the temperature spec in the owners manual for where I live.
Australian conditions need oils suited to heat, not cold - unless you live in Canberra.
Old Dec 2, 2007 | 09:07 PM
ASH8's Avatar
Super Moderator
I agree what is wrong with using Castrol GTX3 it is a 15W40, heat range is great for our summers, it is mineral oil.
We already know that the oil pump and rotors are the same as the last RX-7 which can use GTX3, so why not use it in the 8??
Old Dec 3, 2007 | 01:07 AM
auzoom's Avatar
Hmmmmmm.........
In what way do you mean the rotors are the same? I have seen threads identifying incompatabilities between the renesis housing and FD rotors. I have also read that the clearances on the renesis are also much smaller than on the FD, hence the need for a thinner oil.
Old Dec 3, 2007 | 02:52 AM
DrewMan's Avatar
Correct me if im wrong, but:
the first number is the viscosity when its cold
W = winter
the second number is the viscosity when its hot
Therefore, the second number is whats more important right and the first number is only important in colder temperatures (like when it hits the negatives)?
Old Dec 3, 2007 | 04:19 AM
ASH8's Avatar
Super Moderator
Oil Pump Rotors I am taking about
The clearances are also the same so a thicker grade oil 15w40 GTX3 (mineral) would pump OK.
Old Dec 3, 2007 | 04:25 AM
auzoom's Avatar
Hmmmmmm.........
W = winter
Not quite true. The W number refers to the viscosity of the oil when its cold...not when its cold outside. So in the morning when the oil itself is cold, its viscosity is the one on the left, when its hot its the one on the right (actually I think its when the oil is 40c or 100c).
Old Dec 3, 2007 | 04:26 AM
ASH8's Avatar
Super Moderator
W = winter
You are right on Drewman..
So using 15W40 as an example the 40 degree Celsius temp is what we in Australia should use, a 5W30? how often does it get down to 5 degrees in Australia? and 30 max in Summer is an average summer temperature (well at least in SA). So why would you not use a 15w40.
Auzoom,,
I was always under the impression that the oil numbers are it min and max operating temps as a consumer guide in selecting the correct oils, at least old Mazda owners books and manuals say it that way.
Old Dec 3, 2007 | 05:45 AM
XLR83N's Avatar
Originally Posted by MissyK
What possesses you to spend $90 for oil????? Please tell me the benefits outweigh the costs by about 110% otherwise I dont see a justification? It's a lot of money for student, hell, its a lot of money even for me, I tried to bump down the MA rotary oil price as much as I could lol
Well I actually got it off the guy Black-8 mentioned, was just listing somewhere local that acutally stocks it and its retail.
I have only just started to use this oil (had mobil in before), have heard that RP is ment to be good for rotaries, and didnt know how much the rotary oil costs at mazda (assumed it would be an arm and a leg).
Meh, its not like I gotta change it every week, however I cant say that I notice anything different with the oils (besides that it looks alot cleaner when checking the levels compaired to when I used mobil)
