Will my Z wheels fit my RX8?
Old Nov 26, 2007 | 09:36 PM
Rosko350z's Avatar
I Heart 2nd Gear Racing
I have a set of 5zigen FN01R-C wheels that I used to use with my Z on occasion. I now want to use them on my RX8. They are 17 x 8. Two of them have a 35mm offset. Two of them have a 25mm offset. The bolt pattern is the same as the RX8.
My questions:
1) I'm guessing that a 35mm offset on an 8 inch wheel is enough, correct? The stock offset for an 18 x 8 inch wheels is 50mm. That's only about a half inch difference.
2) Will I need a 10mm spacer for the two wheels that have a 25mm offset?
3) Do I need to get new hubcentric rings. I don't know if they fit yet. If they don't, should I just toss them, and install the wheels without any hubcentric rings?
4) I have a set of lug nuts that I bought with the wheels. Any ideas if they are the same thread pattern?
Thanks for the help.
Old Nov 26, 2007 | 09:39 PM
ULLLOSE's Avatar
05-08 SCCA BS Natl Champ
I saw pics of Carter Thompson in the RX-8, I would guess right after he bought it, with his 18" 350Z wheels on it.
Send a PM to: tomsn16 they should be able to help you.
Old Nov 26, 2007 | 09:48 PM
Easy_E1's Avatar
Why do you want to go from an 18x8 to a 17x8?
As for a wheel spacer NO. Unless you want to make those 25's into 15 offset. Or the 35's into a 25 offset.
The smaller the offset number the farther the outside lip moves outward from center.
I haven't heard of anybody using a 25 offset on the RX-8.
Lug nut thread is 12x1.50. If that is what Nissan uses then they will work. You could search the web for the thread pattern Nissan uses.
Old Nov 26, 2007 | 10:06 PM
nuke0907's Avatar
Never Blend In
my Nissan 240SX has M12x1.25 lugs, so i don't think they will work. this weekend, for the hell of it i tried putting my OEM RX8 wheels on my 240 only to find out the bore size on the wheels were not big enough. most likely you'll have to use a hub centering ring. as for the offset, i'm running 19x8" +35 on my fronts and they look fine. with a 17" wheel though you might have some brake clearance problems. hope this may answer some of your questions.
Old Nov 26, 2007 | 10:39 PM
Endless Rotaries's Avatar
5Zigen FN01RC:
17x8.0 +25 and +35
In all honesty I'd suggest selling them but if you need the info here you go.
I do believe you can make this fit front and rear. Unless you roll the rear fenders you might have more success running the +25 up front and the +35 in the rear.
Your tire size options would be 245/45/17 or 225/50/17. I'd run the same sizes front and rear as well.
Rishie
Old Nov 26, 2007 | 10:41 PM
oh boltpattern is same.
Since they are FN's they are a 73mm centerbore.
Ideally you would want to get hubrings in the dims of 73x67.1, I have these in stock.
Lugnuts, well you can use the stock ones. They are a cone seat and will work.
12x1.50 = MAZDA
12x1.25 = NISSAN, arbitrary since we don't have nissan lugstuds
Rishie
Old Nov 26, 2007 | 10:42 PM
Centerbores:
MAZDA RX8 = 67.1
NISSAN Z33 = 66.1
If you want to use OEM Nissan wheels on a RX8 you would need to bore them out 1mm in diameter. FYI.....
Rishie
Old Nov 26, 2007 | 10:46 PM
RULES OF THUMB:
THE CLOSER THE OFFSET IS TO ZERO, THE MORE THE WHEEL STICKS OUTSIDE FENDER.
THE HIGHER THE OFFSET, THE WHEEL IS PUSHED FARTHER INTO THE FENDER.
SPACERS ARE A "NEGATIVE OFFSET"
i.e.
17x8.0 +25, NOW ADD 25MM SPACER = 17X8.0 +0 it sticking out way far.....
SPACERS ONLY WORK IF THE WHEEL IS TOOOO SUNK........ IN ORDER TO CREATE A MORE NEGATIVE OFFSET.
I'm putting all this info here whether it applies or not because I can see how this can get lost in translation.
It's all here, hopefully people can find this info with key words.
Thanks for playin.....
Rishie
Old Nov 27, 2007 | 10:03 PM
Turboz32's Avatar
yeah, they'll fit... the 350Z Touring wheels fit on the 300Z and so do the RX-8's so i wouldn't see a problem. Just a word to the wise about Nissan wheels, Nissan manufactures every part of their Z car to optimize performance (even the wheels) so putting them on a different car may have the reverse effect... or it could work to your benefit, and hey... if you can find a set of cobra R wheels from ford they will alsofit, (if your into the 5 spoke look) i think that is what i am going to do if i dont paint my stockers black and get the faces chromed
Old Nov 28, 2007 | 01:55 AM
He has 5Zigen wheels so it's a totally different question.
a 67.1 centerbore will fit over a 66.1.
BUT a 66.1 will not fit easily over a 67.1
So i don't think you're gonna have an easy time putting OEM Z wheels on a 8.
Rishie
Just FYI.
Rishie
Old Feb 10, 2008 | 12:57 PM
avakiannl's Avatar
Mazdarati
OEM Z wheels
I run OEM Z wheels on my 8 with Falken RT-615 245/45/17 with no rubbing. The centerbore is not really an issue, just torque it down a couple times in the first 20 miles of driving and they are fine. I've had them for 20,000 with no issues.
I use these for several reasons:
1) the tires are significantly cheaper than 18"
2) 10mm taller sidewall over the stock tires
3) It gears the car down slightly
4) Z wheels are cheap
5) Z wheels are strong
Keep in mind that 17" OEM Z wheels are heavier than than stock and they come in a staggered setup 17x7.5 and 17x8. I have 4 of the 8". The 7.5 work fine too. I have a set of 7.5 painted black for sale, $100.
Rishie
Just FYI.
Rishie
Old Feb 11, 2008 | 04:04 PM
c41250n's Avatar
you can put the +25 ones in the back and run same size tires!
Old Feb 12, 2008 | 09:52 PM
aliveoutofhabit's Avatar
I could see this working. I'm running 18x9.5 +35 fn01r-c and I have no rubbing issues... the 17x8 +25 should have the same clearance (actually it will probably have more clearance in relation to the fender).
DO IT and find out.
Old Mar 7, 2008 | 03:00 PM
Rosko350z's Avatar
I put the wheels on today. They definitely looked to give very little clearance between the fender and the tire, especially in front, where I have the 25mm offset.
Nonetheless, I took a quick, tire-screaching ride through the back of my neighborhood (which has empty lots and no houses). There was no rubbing and no problems. I have an autocross tomorrow, so that will be the real test.
I'll post pictures of this crazy offset when I have a chance.
Old Mar 7, 2008 | 06:03 PM
stogey420time's Avatar
The Fireball Kid
subscribing....i'd like to see this.
dweezil22
NE For Sale/Wanted
12
Sep 9, 2015 10:50 AM
JakeKaminskisRacing
Aug 23, 2015 01:10 AM
Mr.Durden
Aug 12, 2015 02:21 PM
Brandonien
Jul 30, 2015 12:33 PM
AussieGray
Jul 16, 2015 03:58 AM
