What size hub rings and lug nuts do I need?
Old Nov 23, 2007 | 10:53 PM
turborx8's Avatar
Boost 4 Life
I bought some 17" rims today for my winter tires.
The guy gave me his hub centric rings for Toyota and told me it will fit many other brands but could not tell me if they would fit my rx-8.
ALSO!
What size lug nuts do I need? He gave me tuner lug nuts for 12x1.5 thread. Will they work?
Thanks!!!
Old Nov 24, 2007 | 12:20 AM
d j's Avatar
d j
hukbong himpapawid
what size were they? one way to find out is to try it on...
yea, 12X1.5 is the right size for the lug nuts
Old Nov 24, 2007 | 03:09 AM
turborx8's Avatar
Boost 4 Life
No idea what size these rings are.
I will definately see if they fit.
Thanks.
Old Nov 24, 2007 | 11:06 AM
Slick's Avatar
Iirc, most Toyota hub rings are 60.1mm.
The 8's use 67.1mm so the Toyota rings probably won't fit.
Old Nov 24, 2007 | 06:24 PM
turborx8's Avatar
Boost 4 Life
Thats exactly what I needed to know.
The rims are from a Toyota MR2.
Old Nov 24, 2007 | 06:52 PM
DarkBrew's Avatar
Extraordinary Engineering
Hubcenter Bore should be = 67.1
Bolt Pattern is = 5x114.3
http://www.1010tires.com/hubrings.asp
Old Nov 24, 2007 | 10:50 PM
Slick's Avatar
Since they're aftermarket wheels, you should be fine as long as you get the proper Mazda hubcentric rings. Aftermarket wheels have larger hub bores so you can add the rings for the right fit.
If they were OEM Toyota wheels, you'd need to get the hubs machined out to 67.1mm.
Old Nov 24, 2007 | 10:53 PM
turborx8's Avatar
Boost 4 Life
These are the rims I picked up.
American Eagle Alloy SERIES 193
http://www.aewheel.com/eagle_alloy_wheels.cfm?id=79
Old Nov 28, 2007 | 12:21 AM
SolarYellow510's Avatar
Never use a plastic hub ring. They melt from brake heat. They also tend to be cheaply made POSs. I have had them cause a shop to rebalance a wheel set three times without eliminating a shake. Aluminum rings were a clean kill on the problem, because they were made better.
Old Nov 28, 2007 | 12:31 AM
I prefer the metal ones myself, but all the plastic ones I've used were heat resistant
Old Nov 29, 2007 | 12:29 AM
coolstorm92's Avatar
just center it on your own and torque it down. you dont really need those hubcentric rings. i have 17s with a 70.1 hub over the rx-8 67.1 and its is not an issue even without hubcentric rings.
Old Nov 29, 2007 | 09:32 AM
Wow. I have better things to do than debate this, but I have to disagree. It falls under the "I've been doing it that way for ten years" argument.
I looked for my melty plastic hub ring last night to post a picture, but I guess I got tired of having it live in the top of my toolbox, so no pic.
But here's another good one:
http://www.sportcompactcarweb.com/pr.../photo_06.html
Old Nov 30, 2007 | 07:13 AM
Slick's Avatar
With what statement? Using plastic hub rings or the comment re; not using hub rings at all.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
nferguson88
Oct 6, 2015 12:45 PM
pjwermuth
Sep 28, 2015 11:36 PM
GK1707
Sep 27, 2015 07:33 PM
