overflow can questions
Old Nov 22, 2007 | 05:31 PM
kevinD1226's Avatar
im goin to need as much room in the engine bay as possible very soon and one thing ive been thinking of is gettin a smaller overflow can.. does anyone out there make one? and i will be doin the sohn adapter as well and will be needing a can for that too what are some options i have on that as well oo btw i use my windshield washers so thats not an option.. thank you in advance.. and yes i used the search button on the overflow can idea no results were found
Old Nov 22, 2007 | 05:33 PM
Spinning Sushi's Avatar
I <3 Sushi
There's a small opening on the side of the windshield fluid reservoir. You can mount it there, alot of people uses that spot to store their oil
Old Nov 22, 2007 | 05:41 PM
kevinD1226's Avatar
yea but what should i mount there? is there something everyones buying that fits perfect there?
Old Nov 22, 2007 | 09:38 PM
Juice's Avatar
I made some poos
Check out Mazsport, they make a three can system that looks really trick. They have the washer can, air separator can, and oil catch can right where the stock washer tank mounts and it looks real nice all polished up.
Here Is a Link:
http://www.mazsport.net/store/index....uct_detail&p=1
Edit: I read your post again and I see that you want a tank for the Sohn adapter as well. I would suggest using the canister trio still and instead of using the oil catch tank to catch oil you should use it with the sohn adapter and use that tank as your oil supply.
Old Nov 22, 2007 | 09:58 PM
kevinD1226's Avatar
thats a cool kit a bit pricey but i see i can purchase them seperatly.. this might be a dumb question but what the hell is an air seperator?
Old Nov 23, 2007 | 01:29 PM
Juice's Avatar
I made some poos
The air separator replaces the white tank by the battery. The white tank has the same purpose but with a different name. They both seperate air from your cooling system.
Old Nov 23, 2007 | 03:59 PM
staticlag's Avatar
The Professor
just go to summitracing.com they have a ton of plastic and metal alternatives.
Old Nov 23, 2007 | 10:08 PM
chickenwafer's Avatar
Nope
Do a trunk-mounted battery and that frees up a bunch of space, cleans up the under hood look as well, looks much better without the big old battery in there
Old Nov 24, 2007 | 11:20 PM
I <3 Sushi
Ever heard of Circuit Sports? They make alot of Nissan parts They also make a 250cc oil catch can which is a little bit over half the size of a soda can. I buy from these guys all the time: http://www.frsport.com/Circuit_Sport...c__p_1511.html
I live just right down the street from them
WranglerFan
Aug 21, 2022 01:29 PM
nferguson88
Oct 6, 2015 12:45 PM
jer2911
Sep 29, 2015 06:37 PM
Learners_Permit
Sep 27, 2015 07:38 PM
