philipchan
11-21-2007, 05:15 AM
I bought the replacement D2S 12000K HID bulbs, just replaced them today, but after i turn on the lights , they will go off about the same time in about 10~15 seconds, if I turn them off and on again,they light up for 15 seconds again, can't stay for long , dont know what's the problem, need help...PLZ....
http://i18.tinypic.com/6lmejwj.jpg
http://i4.tinypic.com/8g9hw1k.jpg
Spinning Sushi
11-21-2007, 05:35 AM
Could be that 12000k is too high and the HID ballasts shuts them off to prevent any further damage to your car.
philipchan
11-21-2007, 06:32 AM
It is possible to get a better HID ballasts so that I can use the 12000K s?
Or is it really hard to change them coz the HID ballasts is from Factory?
XLR83N
11-21-2007, 05:52 PM
i had a similar problem with 8000K bulbs but only 1 of them turned off. After sending them back twice, the 3rd set are going strong
abbid
11-21-2007, 06:22 PM
12000k is illegal
and you will get ticketed
i will await the thread stating this when it happens.
Jedi54
11-21-2007, 06:25 PM
the bulbs are inferior quality; stock balast should be able to handle it.
GET RID of them, save yourself the trouble of the ticket. Also, you do realize that visibility will be extremely compromised with that, right????
NgoRX8
11-21-2007, 07:48 PM
running 12k on stock ballasts are fine. it has to be the bulbs.
philipchan
11-22-2007, 04:34 AM
I see, thankyou guys...It may be the problem of the blubs...I should send them back...and also get rid of the 12000Ks......6000Ks or 8000Ks???
chancejat
11-22-2007, 04:50 AM
go with 8000..........there legal.......enough
Jedi54
11-22-2007, 12:44 PM
depends on the look you're going for. If you want a slightly "bluer" look, 6k should do the trick. Remember, the higher the number, the more ultra violet you get and less visibility
