17x9 28mm offset fit?
Old Nov 19, 2007 | 08:47 PM
Slick's Avatar
I got a line on a set of 17x9" wide wheels which I believe the offset is 28mm.
Will these fit or will I require fender rolling or other?
I'd like to use these for track wheels...
Cheers,
Andre
Old Nov 19, 2007 | 08:49 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
You will probably be rolling the fenders................sorry to say.
Old Nov 20, 2007 | 12:57 AM
Endless Rotaries's Avatar
What tire size are you gonna run?
245/45/17 might require some rolling in the rear and be real close up front depending on your camber settings.
Rishie
Old Nov 20, 2007 | 02:44 AM
TurboEight's Avatar
Booost.
i doubt he will be running 245s....that's a little narrow for a 9inch wide wheel..
Old Nov 20, 2007 | 06:47 AM
Slick's Avatar
Looking at probably 255/40R17 all around.
I found out the wheels are actually 40mm offset so that should help.
Rishie
Old Nov 20, 2007 | 01:19 PM
Mazurfer's Avatar
I'm running 255/40ZR-18 in the rear with very minor rubbing on bumps, so you will probably be okay. Oh..............my offset is +38mm
Old Nov 20, 2007 | 02:00 PM
CosmosMpower's Avatar
1935 lbs. FTW!
Should fit easily, I had a 275/40/17 on a +44 wheel 17X9.5. The offset makes a big difference it was was a +28 instead of a +40 you'd probably be screwed.
Old Nov 20, 2007 | 02:11 PM
Sidus's Avatar
so, with a offset larger than +44 , you can fit in 275 without rolling fender?
very good to know....
assuming you have this setup all around, right?
Old Nov 20, 2007 | 04:27 PM
c41250n's Avatar
yea, if 40+ you'll be fine. if 28+, you might need the rear fender roll!
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
hufflepuff
May 30, 2016 10:45 AM
Quiggs321
Sep 30, 2015 05:34 PM
GK1707
Sep 27, 2015 07:33 PM
