Is the RX8 gas cap supposed to be On loosely?
Old Nov 19, 2007 | 01:44 AM
liam's Avatar
Just had my first gas refill in my 8. Unlike other cars, the gas cap "clicks" a couple times and it just rotates over and over without seeming to fit snuggly and tightly on there. On other cars, this would lead to CEL. Is this normal with the 8s?
Old Nov 19, 2007 | 01:57 AM
IcarusX8's Avatar
i've lost my mind
LOOOOOOOOOOOOOOOL!
it over-rotates so you dont strip/break/detach/f up the cap.
one click = secure
congrats on the car
Old Nov 19, 2007 | 02:04 AM
liam's Avatar
Yes, all gas caps rotates. Let me rephrase the question. Compare to others, this "new" cap feels extraordinarily "loose," enough to not pressurize the gas tank. This will cause CEL to come on in other cars.
Old Nov 19, 2007 | 02:06 AM
IcarusX8's Avatar
i've lost my mind
im know my 8's gas cap like the back of my hand.
if it feels "extraordinary loose" and seems an issue, i cannot help you. sorry, but havent felt yours, nor have i heard of that problem before.
Old Nov 19, 2007 | 02:08 AM
IcarusX8's Avatar
i've lost my mind
anyone else????? im curious now too...
Old Nov 19, 2007 | 04:16 AM
nate340's Avatar
if the gas cap does not seal it will cause a CEL. so if you dont have a CEL guess what your gas cap must be working just fine.
Old Nov 19, 2007 | 06:07 AM
reaper1's Avatar
There's a TSB on the gas cap , if you get the Cel light take it in and they'll take care of it. You will get a new cap . If you dont get it that of course means , it is working fine ...
Old Nov 19, 2007 | 11:59 AM
champi0n's Avatar
Thats the winner right there. Its so you don't over torque it, most all new gas caps do this, its normal.
Old Nov 19, 2007 | 12:03 PM
dmc27's Avatar
doin' the bull dance
Normal; don't worry about it.
Congrats on the car! What did you get on the first tank - 185 miles??
Old Nov 19, 2007 | 12:06 PM
StewC625's Avatar
Insanely Yellow
This gas cap is just like every other car out there. If you don't think it's right, replace it. It's cheap anyway.
Old Nov 19, 2007 | 12:49 PM
Juggernaut9's Avatar
Phantom Blue
I had the TSB done on my 06' and it feels looser than the original but it is working fine....... The part of the cap that seals on the filler tube does seal tight. The top of the cap just rotates a little to freely for a lot of people. Remember when gas caps didn't click? everyone thought the new ones that did were broken. hehehe
Old Nov 19, 2007 | 06:58 PM
zerobio's Avatar
Atomic 8
Sorry to jump on with this but ... the gas cap has a plastic cord on it but can the cap be attached to the lid somehow when you pump gas? Mine always leans against the car and I'm dying to know if it can be held on the lid somehow.
Old Nov 19, 2007 | 08:29 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Here go read this thread! There are several good ideas out there concerning this issue. Me....I am just careful!
https://www.rx8club.com/showthread.p...hlight=gas+cap
And to the original post. Yeah, you will get a cel if not a good seal as others have said, but when you put the cap on, turn it until it clicks about two or three times and leave it alone. If no cel, then don't worry about it. Not to be a dick about it(okay, I will be), but it's on page 3-19 and 3-20 of my manual.....do you have a manual? If not, then go get one at www.mazdausa.com and read it. Maybe you'll find out about the mysterious trunk handle as well.
Old Nov 19, 2007 | 09:52 PM
CarAndDriver's Avatar
2005 Black RX-8 GT 6M
If you're not getting the CEL light u must be ok.
Old Nov 19, 2007 | 11:28 PM
New Yorker's Avatar
I know exactly what you mean—all the cars I've had over the last several years—a GTI and two MX-5s—allow you to keep clicking the gas cap forever, but the RX-8 is the only one that feels loose. I've wondered if mine was normal, too. But don't worry—it is. As others have said, if you don't get a CEL, it's fine. Mine goes on loosely with no CEL, so it's fine.
Separately, there is a problem with some RX-8 gas caps going on loose and tripping the CEL. There's a TSB on this with a revised, better fitting cap. But again, if you're not getting a CEL, your gas cap is fine.
Old Nov 20, 2007 | 01:21 AM
liam's Avatar
Thanks. I've also had GTis and Miatas. I know "Lionzoo" and couple others hang around the Miata forum. Do you also? If so, by what username?
Old Nov 20, 2007 | 02:01 PM
zerobio's Avatar
Atomic 8
Thanks Mazurfer, I'll check out the thread.
Old Nov 20, 2007 | 02:16 PM
ken-x8's Avatar
Only problem with the hook is that when my friends see it, they tend to roll their eyes and say the cap is plastic and will not scratch the paint.
But it does tend to make them more consciencious about wiping their feet before getting in the car, and more careful with their drinks and boogers. One of those "Don't mess with the **** lunatic" deals.
Ken
Old Nov 20, 2007 | 02:43 PM
GuyWithRx8's Avatar
Low compression
If you let the gas go until it shuts off by itself, does it shoot out of the tank all over your car? it does everytime I fill up
Old Nov 20, 2007 | 02:52 PM
Mazurfer's Avatar
Nope, but then again......I always have my finger on the trigger!
Old Nov 21, 2007 | 02:16 PM
zerobio's Avatar
Atomic 8
I found the little latch that protrudes off the inner part of the assembly (terrible description) but it's on the right side opposite to the side the plastic cord extends from so the cap and cord have to be pulled across to that side. I don't like the position so I will just continue to use care and let it dangle. But I always shake the gas nozzle in case there's excess gas and hold a paper towel under it during and after filling so as to not spill gas on the car. Little things ...
Old Nov 21, 2007 | 03:53 PM
ken-x8's Avatar
Mine does most of the time, if the nozzle is on its highest flow. When I get within a gallon or so of the expected amount (not hard to know what to expect with this car!) I'll step it down to the lowest notch. That rarely squirts.
Enough other cars and pumps do this, so it's usually a good idea to not stand in line with the filler.
Ken
Old Nov 21, 2007 | 08:25 PM
Renesis07's Avatar
Vtak just kicked in yo!!
no cel means its all good
Audio Concepts ATL
Sep 26, 2021 01:59 PM
Skyl3r
Dec 2, 2019 04:51 PM
learningdriver
Aug 8, 2015 06:55 AM
Belalnabi
Jul 17, 2015 07:48 PM
AussieGray
Jul 16, 2015 03:58 AM
