JDM_Racer
11-17-2007, 03:05 PM
May be someone can help me out here...I have a JDM AT RX8 in the UK which has developed an Airbag ECU Fault. Being JDM it only has two Airbags where as all UK models come with 6. Therefore I can't simply replace the ECU with another from here. It needs to be from a Two airbag car... Does anyone one know of a JDM RX8 being broken with an Airbag ECU available?
Getting desperate here :(
foo77
11-18-2007, 06:52 AM
if i recall,you can't swap your ecu with other :scratchhe
Spinning Sushi
11-18-2007, 07:00 AM
If you swap the ECU's, your ignition/immobilizer system won't work thus you will not be able to start the car. There's alot of other fun stuff that won't work right as well. Hope this helps :)
foo77
11-18-2007, 08:02 AM
^ i know about that, maybe you mis understand with those smile scratche and mis read what i told him can't swap ;) hope that will help him out, not me :)
JDM_Racer
11-19-2007, 03:51 AM
I think you both may have misunderstood. I'm not talking about the main ECU that controls engine (and other) functions!
It's just the SAS (Airbag) control unit.
Zero_Rotary
11-22-2007, 07:34 AM
i suggest you post this on the general issues section...you may find better luck there on help
