Did i luck out and get TPMS with my 2nd hand tires?
Old Nov 15, 2007 | 12:11 AM
champi0n's Avatar
So i have an 04 GT that came with 18'' rims, (im assuming tpms)
i bought 2nd hand rims/tires from a dude that use to own an rx8. He didn't seem all that into cars or anything, so just some middle age guy.
Now i assume that when i'd swap the wheels out, i would have a tpms light due to them not being there.... but no light
is there no light because the system senses them not there and doesnt worry about it, or no light because the tires have the tpms installed?
Old Nov 15, 2007 | 06:57 AM
CTrx8's Avatar
space for rent
try letting some air out of one and see if you get the light. they probably have TPMS.
Old Nov 15, 2007 | 07:29 AM
expo1's Avatar
He's as bad as Can
Most likely case is your new rims have the TPMS sensors in them. Can you take a photo of the valve stem? It should look like the one on this sensor.
Attached Thumbnails Did i luck out and get TPMS with my 2nd hand tires?-wheel_sensor.jpg
Old Nov 15, 2007 | 07:32 AM
Myardor's Avatar
No
Old Nov 15, 2007 | 12:56 PM
zoom44's Avatar
so he sold tires with tpms already installed. its easy to check - is there a long line of balancing weights on one edge of the rims?
Old Nov 15, 2007 | 02:32 PM
kersh4w's Avatar
Hit & Run Magnet
i installed a set of winter tires on my car. it takes about 10-15 minutes for the TPMS light to turn on. and when it does, it blinks. its not solid. what does the blinking mean? i checked the manual, but i didnt see a part on blinking.
if my tires did not have tpms, then the light would turn on instantly.. right?
and if air expands when heated.. shouldnt the light turn on in the first few minutes before the tires heat up?
also, my winter tires are 225/50/17 bridgestone blizzaks. it says on the tire, max pressure = 40psi. i put 35psi (warm) in there, but the light still comes on... what psi should i be shooting for with these tires?
Old Nov 15, 2007 | 02:51 PM
champi0n's Avatar
So i let the air out of my tire in the driveway, down to like 18psi... the light didnt come on.
The valve stems don't look "special"
And assuming i have a 2004 GT with sat nav, leather, hid... i would have tpms?
Do you think it was disabled somehow?
Most people seem to complain about the light being on, but im complaining about it being off... :\
Old Nov 15, 2007 | 02:54 PM
1.3L's Avatar
Are the TPMS sensors in the wheels uniquely matched to each vehicle, or are they interchangeable from car to car?
1.3L
Old Nov 15, 2007 | 03:01 PM
champi0n's Avatar
actually i just found this which might be helpful:
http://www.finishlineperformance.com...4-04-1374a.pdf
it says that it has batteries designed to last up to 10 years, an accelerometer that turns the unit on at 16mph (25km/h), a temp sensor and a pressure sensor.
So assuming letting the air out of my tire was a waste of time cuz i'd have to drive it...
Old Nov 15, 2007 | 03:04 PM
champi0n's Avatar
so maybe the previous owner or the dealership i bought it from removed the module/sensors?
Old Nov 15, 2007 | 03:37 PM
ken-x8's Avatar
32 psi cold. Unless there is specific information to the contrary, you inflate tires to the pressures in the owner's manual, or on the sticker in the door jamb.
That 40 psi is the maximum pressure the installer should use to help seat the bead. After the bead is seated, it should be brought back down to 32 psi.
Ken
Old Nov 15, 2007 | 05:34 PM
valpac's Avatar
Ahead of its time
Originally Posted by kersh4w
... what does the blinking mean? i checked the manual, but i didnt see a part on blinking....
recently had the same issue with my TPMS system as well. Turned out two sensors were going bad and had to have them replaced. A bad sensor will throw a code. Check it out.
Old Nov 15, 2007 | 05:39 PM
valpac's Avatar
Ahead of its time
..., an accelerometer that turns the unit on at 16mph ...
Dont think so. A couple months ago got a TPMS light when starting the car first thing in the AM before backing out.
Old Nov 21, 2007 | 09:03 AM
kersh4w's Avatar
Hit & Run Magnet
thanks ken.
how much does it cost to have a tpms sensor replaced?
Old Nov 21, 2007 | 10:19 AM
CTrx8's Avatar
space for rent
thanks ken.
rosenthal has them for $70.
http://www.finishlineperformance.com...n&key=RX081038
to have someone actually do the work ranges from free to $10/each from what i saw. of course that was when my tires were being mounted so i'm not sure what they would charge otherwise.
Old Nov 21, 2007 | 11:34 AM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
When i went in for my reflash one of my sensors were bad also i was wondering why i had the right pressure but the damn light stayed on, mine got replaced for free under warranty
Old Nov 21, 2007 | 11:39 AM
Nemesis8's Avatar
Bigus Rotus
TPMS are for the timid IMO. Nothing is better than a tire pressure gauge in your pocket. And besides, who wants all those wheel weights that zoom mentioned.
Old Nov 21, 2007 | 12:42 PM
RWatters's Avatar
I've been driving around all day on my snow tires which don't have any TPMS sensors in them and I've yet to even see the light come on. I hope it stays off. That beeping noise is annoying.
Old Nov 21, 2007 | 12:43 PM
CTrx8's Avatar
space for rent
TPMS in no way replaces a tire pressure guage (and if it does, shame on whoever is doing that). there are, however, times when you have the window open and either because of someone next to you or the echo off a divider, it sounds like a flat tire. almost always it's nothing but being paranoid i would pull over as soon as i could to make sure it wasn't me.
having the TPMS puts that paranoia away for a while and let's me know that if there was something severely wrong i'll get a beep and light. and then checking once a week with a tire pressure guage makes sure that expecially during these winter months when temperatures are crazy, i can keep them at the right pressure all the time.
Old Nov 21, 2007 | 10:13 PM
champi0n's Avatar
You have to understand if you have low profile tires on 18's its not as easy to tell if you have a flat or a leak.
nowakm99
Oct 9, 2015 07:10 AM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
fireishot34
Sep 5, 2015 06:45 PM
Octomus
Sep 3, 2015 11:40 AM
20b-3rotor
Sep 2, 2015 08:54 AM
