jdaled
10-20-2003, 04:02 PM
I'm pretty pleased overall, but I think I might re-work the controller installation one more time to try to make it look a little more integrated... we'll see. I like retaining use of the ashtray compartment, but if I give that up, I could mount the controller much more flush than it currently is.
The ashtray cover is held in place by two pins (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/ashtrycoverpin.jpg) and a spring (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/pinandspring.jpg). One of my pins had worked its way out a little, so I just pulled it out with pliers (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/pinandpliers.jpg) to remove the lid. There is a metal heat shield (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/ashtrycoverheatshield.jpg), which should be removed (pried off with a flathead screwdriver) (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/heatshieldpryhere.jpg) (pic 2) (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/pryitoff2.jpg) (pic 3) (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/heatshieldoff.jpg) before marking (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/marktheedges.jpg) and cutting (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/cutout1.jpg) an opening (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/cutout2.jpg).
I don't have any pics of this step, but I got some adhesive-backed rubber weathe rstripping from the local hardware store, and ran a line of that around the edge of the controller to hold it snugly in place. (cuz I accidentally cut the opening a little too large:( ) You can see it in the final pics.
Now to the car...
There are other pics and descriptions on this forum for how to get the stereo out, so I'll just pick up here with the stereo already out. After putzing around a bit to find a good location for the RF unit, I finally decided that neither the space under the ashtray, nor anywhere along the central spine of the car was going to work for me, so I decided to check out the space above the stereo. There were a couple of screws (left (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/VentCoverScrewLeft.jpg) & right (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/VentCoverScrewRight.jpg)) to remove, then the vent grills just pop out. Following that, there were a couple more screws (left (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/TopCoverScrewLeft.jpg) & right (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/TopCoverScrewRight.jpg)) and the central top cover pops off. (upward) Since I don't have the Nav unit, there was plenty of space (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/opendash.jpg) there for the RF Mod (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFUnitOnTop.jpg). It was pretty easy to run the wires down (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFWiresFromTop.jpg) beside the vents to the stereo space (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFWiresFromTop2.jpg).
I tracked down the proper wires to tap into, by looking at other connectors in the area... the dash lights, the cigarette lighter, etc. to deduce which colors I needed to look for for ground and battery wire. With those in place, I just poked the third wire from the RF into the various holes in the stereo wiring harness (with the ignition turned to ACC) to determine which other wire to use. I did a couple tests with the key in various positions to be sure I had the right one, then I either
spliced into (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFModWiresSplicedIn.jpg) them or tucked in (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFModWiresTuckedIn.jpg) (pic 2 (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/RFModWiresTuckedIn2.jpg)) the RF wires, and secured them all in place with electrical tape.
I connected the antenna adapter (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/antennaconnections.jpg) and ran the wires to the controller and to the Keg beside the vents, behind the stereo, and along the spine of the car, to the trunk (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/kegintrunk.jpg). (Sorry, no pics of the wiring under the spine cover... it wasn't very exciting anyway)
I popped and screwed everything back together, and this (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/controllerwithcushion.jpg) (pic2 (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/controllerwithcushion2.jpg)) is what I got. And hey, the ashtray cover still opens (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/ashtrycoverstillopens.jpg).
And it's so purty at night (http://members.aol.com/jdaled/RX8pics/MusicKegInstall/controlsLit2.jpg).
One more thing I plan to do (maybe tonight) is get some translucent red tape to cover the display screen, so it will look more like the upper display. (and won't be so bright at night)
Now to the car...
