I think im gonna try 18x10+35 on all 4
Old Nov 14, 2007 | 04:32 AM
DXT-Motorsports's Avatar
I think im going to try
advan rs 18x10 +35 on all 4s im a bit scarred
with a kumho ecsta mx 255/35/18
Run -2 degrees camber all the way around and shave the rear fenders.
if sammytcl can get 17x10 +35 rolling on 255 45 18
I think i can do it!!
I used the offset calculator
it says ill lose 10mm on the inside and will be 40mm wider on the out side so about 1.5 inches outward.
If someone knows this wont work for sure let me know haha.
Old Nov 14, 2007 | 02:31 PM
c41250n's Avatar
i was running 18X10 24+ all around no problem, 245/40/18 front, 275/35/18 rear!
now im running 18X10 24+ front and 18X10 21+ rear, 255/35/18 all around!
NO rubbing!
Old Nov 14, 2007 | 03:22 PM
wow nice!
Old Nov 14, 2007 | 06:25 PM
yeah, he had to run -4.0 deg rear camber
I run 18 x 10.5 +43 all four with a reasonable alignment and it's extremely close in the rear, IMO you'll rub unless you run such a ridiculous alignment that it makes having wide wheels pointless
Old Nov 14, 2007 | 06:29 PM
LionZoo's Avatar
road warrior
NO rubbing!
Yeah, but you have fender work done.
Old Nov 14, 2007 | 07:10 PM
details, details ....
Polak tried 18 x 9.5 +38 with the same tires I have and rubbed in the rear
IMO anything lower than +40 on a 10" wheel is tempting a fender clearance issue in the rear, unless you run an under-width tire which again defeats the purpose
Old Nov 14, 2007 | 10:12 PM
maybeashinka?'s Avatar
Can I change my username?
whats the purpose?
Old Nov 15, 2007 | 02:11 PM
the purpose for me is purely functional; maximum grip,
it's not braggart "look at my parts list" rights or playing out a fantasy fad i.e. typical poseur BS
Old Nov 15, 2007 | 02:15 PM
kersh4w's Avatar
Hit & Run Magnet
just out of curiosity, what is your parts list?
:P
Old Nov 15, 2007 | 03:08 PM
MrWigggles's Avatar
FYI,
I have 18X9.5 +45 with 275/35-18 and I used to have some rubbing problems. It was very tight. Tire size makes a big difference not just wheel size.
If you went with a 255/35 - 18 (which is smaller than factory diameter BTW) a 18X10 +35 would probably fit but barely. the proper aspect ratio would be 255/40 which would probably rub just a little.
-Mr. Wigggles
Old Nov 15, 2007 | 03:19 PM
Easy_E1's Avatar
I'm running 18x8.5 with a 38 off set and FK-452's 265/35-18s on all corners and no problems. Lowered 1.4 inches.
Wheel turned all the way in front. I can get 1 finger between tire and inner fender.
Old Nov 15, 2007 | 03:29 PM
VarneyMazda's Avatar
Northeast Pimpin'
hmm for some reason i just dont see it working..
but your calculations seem spot on.
Old Nov 15, 2007 | 03:53 PM
c41250n's Avatar
no....i just rolled the rear fender thatz it!
c41250n's Avatar
haha...i have -2.5 front and -3 rear
Old Nov 15, 2007 | 03:55 PM
c41250n's Avatar
if somebody want to see my car, i can prove that its working!
i live by Daly City, anybody?
Old Nov 15, 2007 | 05:07 PM
LionZoo's Avatar
road warrior
Isn't rolling a fender fender work?
Old Nov 15, 2007 | 05:14 PM
Macius8's Avatar
Nice it should work. I'm tempted to try 19x10 with a 44mm offset and 285/35/19 or even a 295 tire but I'm not sure that'll work but Ill see. Team?
Old Nov 15, 2007 | 05:17 PM
Throwdown's Avatar
Turb O'd
I have 19 x 10 with 285's on them. There isn't much room there but they fit.
Old Nov 15, 2007 | 08:33 PM
once you get up in that range of tire you have to be worried about it rubbing on inside around the shock area protrusion as well as the outer fender lip, the brand and model tire also come into play; race tires are typically wider than street tires for a given size designation, as does the tire OD
but I know people running 18 x 9.5 +45 wheels with 285/30-18 Kumho V710 DOT-R tires and no fender mods, there's a good chance that 18 x 10 +44 wheel with a low profile 285/295 tire won't rub, but once you get up in this range your on your own in tight territory. The actual clearances from the factory can vary somce, so a super tight fit may be OK on one car and slightly rub on another.
and I don't run anywhere near -3 deg rear camber for racing, let alone on the street
Old Nov 15, 2007 | 11:42 PM
Macius8's Avatar
Whats your offset and what height is your tire?
Thanks Team.
Old Nov 15, 2007 | 11:43 PM
ocrapitzleon's Avatar
fō'tə-jěn'
its good to go
Old Nov 16, 2007 | 11:16 PM
G3tR3DDY2GR3DDY's Avatar
so what springs are you going to run or just stock ones? i have eibach's with 18x9.5 +35 on the rear with 265/35's and no rubbing issues and it looks good. No fender rolling or shaving so i think you can go a little more than that especially with stock springs.. i would say you can get away with 18x10 +28 with 255's because i had them... i had the fender cutting into my tire on the rear on bumps and whatnot so go somewhere in between the first mentioned and the second!
Old Nov 17, 2007 | 10:41 AM
stickmantijuana's Avatar
Unregistered User
19x9.5 +45 all around w/ falken 285/30/19 is safe (i run this with ride height lowered about 1.5" from stock height)
19x10.5 + 45 is what team recommends as max width application.
obviously you'll have bit more clearance with 18" rims.
i'd listen to teamrx8 over others.
Old Nov 17, 2007 | 01:21 PM
c41250n's Avatar
alrite guys...i'll post some pictures later today, someone took it when I was at the track, I can prove to you guys that have 3 negative camber is not just for looks, also for handling!
imo, rolling fender is a really minor fender work, I'm planing to pull my fender actually. rolling fenders are not that hard, most of my friends had theirs rolled!
what I'm doing now compare to the guys in japan, mine is really nothing!
Old Nov 17, 2007 | 01:35 PM
you can fit 20" wide wheels on anything if you're willing to modify the bodywork
there's no need for pics, nobody is doubting that your car exists, pics don't prove the validity of your choices, pics don't win races ...
