minor problems with my 8
Old Nov 11, 2007 | 11:12 AM
raizen82's Avatar
resist, un-learn, defy...
Unhappy minor problems with my 8
i just bought a used 8 and i've got these minor problems, 3 of them to be exact.
first, the foglight mount on the driver's side snapped on the area where the screw holds it in place:
second, one of the plastic "supports" below the bumper also snapped on the driver's side:
third, the first owner had sirius installed in the sunglass compartment and i don't know how to take it out along with all of its wiring.
i already tried opening the reading lamp compartment to see if it had connectors but found none. i suspect it ran all the way to somewhere inside the car.
i was so pissed when i found out the sirius antenna was covering these scratches (i cut off the damn thing which ran around the windshield into the firewall bypass):
so i'll also be busy with touch-ups on a couple of scratches.
any ideas on what i should do or you recommend me to do with these?
Old Nov 11, 2007 | 11:19 AM
champi0n's Avatar
the foglight thing: use epoxy/resin
the bumper support, i dunno.
the radio, i wouldnt have cut it, coulda sold it.
The scratches, wet sand and buff? The areas with what seems to be rust, i would hit them with a dremel bit very carefully to get rid of the rust without effecting the surrounding paint too much then fill them in with touch up paint. then wetsand/buff. The white looking scratches will probably buff out just fine.
and when wet sanding use like 1,000,000,000,000,0000 grit paper.
Old Nov 12, 2007 | 02:40 AM
raizen82's Avatar
in hindsight, i don't think i could've sold it. imho, who would get satellite radio now that there's HD radio? thanks alot for the reply btw. i guess gotta research on how to repair scratches and do it myself. i was like, "wet sanding? what's that?"...
Old Nov 12, 2007 | 05:40 AM
Wind Dance's Avatar
Central Valley RX8
A process of sanding with ultra fine paper and water. Should be best if a pro did it. Just use some polish compound and a buffer for the time being
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
jgsnake
General Automotive
Jul 30, 2023 10:26 AM
arexatemate
Oct 28, 2019 08:16 AM
tommy26Germany
Sep 29, 2015 10:33 AM
Vedivan1
Sep 18, 2015 12:39 PM
