NE RX-8 Forum Serving ME, NH, VT, MA, RI, CT, NY, NJ, DE, PA, WV, MD, VA, OH
question about tha tein s techs
Old Nov 9, 2007 | 10:26 PM
redD3vil's Avatar
Does any one know how to install tha tein springs i know its not as easy as jus changin tha springs what needs to b done and what needs to b cut? or does any one know wherr to install them around westchester, new york or nj
Old Nov 10, 2007 | 05:25 AM
nuke0907's Avatar
Never Blend In
dude why do you keep asking the same question in multiple forums? if you search there is a DIY in the tech section. i don't inderstand why you would need to cut something either
probably not the answer you were looking for but the info is already out there.
Old Nov 10, 2007 | 07:21 AM
chrism's Avatar
Misfit Moderator TnC
you actually do need to cut about an inch off the bump stops.....i will not install them but i have a shop locally that does.....this weekend i cant help you but next weekend i have no problem taking you there
Old Nov 10, 2007 | 04:59 PM
NYC Drift King's Avatar
Supercharged by Pettit
carlos waddup0 man.... chris why u have to cut a inch off the bump stops
Old Nov 10, 2007 | 09:27 PM
chrism's Avatar
if you dont you will not have enough spring travel and it will bottom out on every bump....the bump stops are a rubber/plastic bushing located on your shock inside the dust boot.....when you lower your car you have to cut the bump stop
Old Nov 11, 2007 | 10:28 AM
wow ur bro dam i gotta tell reddevil---l
gwailo
May 14, 2024 06:57 AM
OnebaddRx8
Oct 17, 2015 10:05 PM
Wurromurro
Sep 20, 2015 05:02 PM
yankeepicker
Sep 11, 2015 05:42 PM
