cant get front wheel out!
Old Nov 7, 2007 | 11:51 AM
slofo's Avatar
help i cant get my front tire wheel out
Old Nov 7, 2007 | 11:54 AM
Need to remove all the lugs nuts. Then make sure the tire is off the ground.
Old Nov 7, 2007 | 12:15 PM
costello's Avatar
Good one.
It's just a rusted on if you haven't removed it in a while. After you remove the lug nuts, lower the car back down so the weight of the vehicle is back on the wheel without the lug nuts. Sometimes this is enough to loosen the wheel. It may take a couple of tries. If you have a hydraulic jack you can drop it rather quickly. Just be careful. If you drop it too fast the wheel might fall off and you may cause damage.
Old Nov 7, 2007 | 12:18 PM
^^ yup, most likely rust holding it on.
try Costello's method and then hold the tire from each side and try to wiggle it off using small side to side motions. That should loosen it enough for it to come off.
Old Nov 7, 2007 | 12:43 PM
slofo's Avatar
nvm got it out lol
slofo's Avatar
have to kick it so it can pop out
Old Nov 7, 2007 | 12:44 PM
crowbars are a beautiful thing, aren't they?
Old Nov 7, 2007 | 12:47 PM
hough2696's Avatar
Man Up!!!!
Ummmmmm.......Was he for real?
Old Nov 7, 2007 | 12:54 PM
paulmasoner's Avatar
Asshole for hire
^^^who knows
Originally Posted by slofo
SUBJECT: After putting new spark
my car wont start any solution?
for some reason my ac/heater dont work.. sometime it work and sometime it dont.. when i turn on i put on cold it put on hot. and when i put on hot it put on cold..any ideal?
Old Nov 7, 2007 | 12:59 PM
hough2696's Avatar
Man Up!!!!
Nothing against my gender, cause some of us are smart and car savvy, but I hope this is a young girl.
Old Nov 13, 2007 | 10:31 PM
lepichichi's Avatar
I LuV mY Rotary....
he got jokes??????????
Warrior777
Jun 24, 2019 04:47 PM
Billy Marcial
Mar 1, 2018 06:50 AM
coolcars44
Nov 29, 2017 05:45 PM
amshaw
RX-8 Multimedia/Photo Gallery
10
Aug 26, 2015 08:50 PM
Brandonien
Jul 30, 2015 12:33 PM
