Jasonawojo
11-06-2007, 10:41 PM
Quick question, I'm going to pick up some Redline MT-90 and 75w90 Gear Oil to change out the transmission and differential fluid as I believe my car still has the original (or really old!) fluid.
Will I need a torque wrench for the drain/fill plugs or can I get away with the one turn past tight that is generally used for oil changes?
ken-x8
11-07-2007, 12:16 AM
You don't need a torque wrench.
One turn past tight? That's way too much. Maybe you do need a torque wrench after all. :)
Ken
TrochoidMagic
11-07-2007, 04:08 AM
hand-tight then just do 1/4 turn to 1/3 turn to crush the new washer... or hand tight and 1/8 turn with the wrench if you use the old washer.
hmmm...kinda like the same thing for spark-plug with crush washer on my piston car.
but yeah, if you can't feel the difference between too loose or too tight....then get a torque wrench. just don't dial in 50lbs.
j/k...really, you don't need to waste soo much money and go overboard on the torquewrench. just handtight +1/3 turn, make sure its snug...you'll be fine.
Jasonawojo
11-07-2007, 06:51 AM
Yeah, I meant one tug past tight. Thought it but didn't type it :banghead:
Thanks guys! :)
