Center Console Lights Flickering...
Today I was driving and all of a sudden the lights on the center console started to flicker. The led display also started to act up showing weird patterns. A couple of times the entire radio and all lights completly turned off. It seems like it happens when I hit bumps etc., however when the center console went out the air kept working like normal when everything else turned off. Anyone have similar experience with this? Any information would be helpful cause I would want to avoid spending hours at the dealership.
Looking at an electrical diagram I wouldn't expect a relay issue since the audio unit is going off the ACC relay which is also feeding the cigarette lighter, your navigation system (if you have one), and your power mirrors. If these other devices work fine, then loose wiring or possible short would be my suggestion to look for.
Good luck and keep us posted.
yurcivicsux
192
Sep 12, 2017 10:54 PM
arexatemate
Oct 4, 2015 12:36 PM
