RX-8 Problems
Old Nov 4, 2007 | 09:49 PM
gksingh's Avatar
RX-8 Problems
Hey hows everyone doing, friend has an RX-8
its a 2004 model with 6 speed gearbox and 74,000km.
Recently its been having problems, well at first starting problems.
The computer read like 12 codes, got a tune-up done and replaced one of the coils from Mazda. Drove fine for a bit besides the occasional starting problems.
After sometime, the engine check light came on again.
It drove fine when that light came on but a few times it wouldnt pick up speed at all. It was like it lost all power and was moving like a turtle.
Exhaust was clipping a bit. Idle became really rough
If you stepped on the gas, the rpms would climb slowly. And when I say slow I mean slow. To the point where people would be like WTF is this dude moving 2 km and taking forever to cross the intersection
And finally it refuses to start. When you do try to start it, you hear a whining noise, sounds like the starter is spinning but the motor isnt cranking.
What could it be guys? Oh yea it burns alot of gas but im guessing that normal
60L gets around 480KM on a tank
Clogged cat?
Coils?
Spark Ignition?
Old Nov 6, 2007 | 10:21 AM
dfweyer's Avatar
Who's the Jackass now!
Any noticeable leaks? Have you taken it to a Certified Mazda dealer?
Old Nov 6, 2007 | 10:46 AM
Mike06's Avatar
seems like your rx8 got pwned...
Old Nov 6, 2007 | 10:47 AM
laythor's Avatar
I zoom therefore I am.
Replacing all the coils and plugs would be the first step.
Old Nov 6, 2007 | 10:55 AM
staticlag's Avatar
The Professor
Probably a clogged cat. If your car isn't modified, let mazda warranty fix it.
Old Nov 7, 2007 | 07:25 AM
Go48's Avatar
First, verify that the engine compression is in the acceptible range. To do that, have it checked by a Mazda-trained tech using the correct tool. This could save you money in the long run. Parts replacement without knowing the cause of the problem is a waste of money and time.
Old Nov 8, 2007 | 01:10 AM
Clogged cat?
Coils?
Spark Ignition?
and the 12 codes were????
that is were you would start.
Old Nov 8, 2007 | 07:58 AM
First off, it will be nice if you can tell us what those "12 codes" were.
if one of the code has something to do with Ignition coil, then I suggest you to replace ALL coils and Plugs and maybe Plug Wires.
if that does not fix your problem, I'll start looking for engine compression numbers.
Old Nov 8, 2007 | 11:10 PM
rtzrx8's Avatar
hey everyone its my rx8 that gksingh posted about. When i took it to the local Mazda dealer they said it has 12 codes but they didnt specify. I bought the car from a local private dealer and i guess whoever had the car before didn't take very good care of it and didn't get it serviced too often. What Mazda did was run a diagnostic(obviously) and said that they are gonna start with the most obviously problem. They ended up replacing all four spark plugs and wires and the #2 ignition coil. I just took the car today to a mechanic who specializes on rotary engines and hopefully he can fix this problem. I've had the car for one month and its been parked for half of it. Its fun to drive when it does run though
Old Nov 12, 2007 | 02:43 PM
SRrx-8JC's Avatar
Felix "The Man" Wankel
Hey guys would the coils going out have any direct relationship to having a midpipe on there? I wouldn't think so but that is why I am asking......Thanks
Old Nov 12, 2007 | 05:54 PM
987HYS's Avatar
Dragon Certified
I'm experiencing some of the same problems. I had my 2nd gear fixed about a month ago and noticed that occasionally gears would click when shifting. about 2 weeks ago my fill plug (on the trans.) came out about 100 yrds away from my house. topped off the tranny fluid and put the plug back in. now i have noticed that when at idle below 1,000 RPM it has a unsetteling vibration and when revved above 1K it seems smooth. any advise?
Old Nov 12, 2007 | 06:30 PM
hi1batu's Avatar
guys i have o4 auto at 39000 ... I have the similar problem ... when i come to a stop at a red light or whereever, there is this noise is coming under or from the front of the car..Noise only comes when i make the stop and it stays under and on the front/ Its like a small bird got stuck somewhere and makes a noise cik cik cik cik... its very anoying ... Any ideas ... they changed my trans cause they thought my old trans was the problem.. but there is the new trans now but its still making that noise on the stop untill i move...
Old Nov 15, 2007 | 10:16 PM
Koytch's Avatar
I had the identical problem, now fixed
Clogged cat?
Coils?
Spark Ignition?
I have a 2004, and had the same problem you mention, but sometimes it would go away and run fine. Every time I took to the dealer they couldn't find codes but would keep updating firmware for engine and transmission. That didn't help. One day when it did it again, drove it direct to the dealer and left it running. Even with Check Engine light on, and they still couldn't diagnose. They ended up calling Mazda Engineers. Mazda said they used to get this same problem on some of their Mazda 6's, but not in RX-8. They said the vehicle was going into "safe" mode to protect everything, but had the dealer change the fuel leveling pump. I'm no expert on design of the car, but I was told it has a split tank with a leveling pump. They changed that, and I've never had the problem again.
xAgyex
Jun 3, 2026 03:47 PM
drebbrnator
Dec 27, 2018 07:02 PM
uZu
Dec 30, 2015 12:35 PM
Lee_1420
Aug 10, 2015 01:05 PM
MarkX
Jul 31, 2015 07:50 AM
