I Need Help! I dont know how to work OEM ipod!!
Old Oct 27, 2007 | 08:08 PM
My8DriftsMe's Avatar
Hey i just installed my OEM mazda ipod player and i cant get to to play the songs i want. i have an 05 base model. I can listen to some songs but i didn't pick them to play. how to i pick the songs i want to play? like from a playlist? any advice will help! =)
Old Oct 27, 2007 | 09:15 PM
DarkBrew's Avatar
Extraordinary Engineering
If you want to select a menu you hold down the cd change button (up or down) for one second or more. The number scrolls but you ignore that. When you release the button the time counter shows the menu number for a second or so before the next song starts counting.
The cd change button also is used to change the list number within the menu you selected. The list is changed if you press the button for less than one second. The only issue here is if you hit the cd button twice in one second it will change the menu instead of the list so you have to change lists slowly.
The menu numbers are documented in the manual and the list in each menu is selected in the order programmed on your IPOD.
Old Oct 27, 2007 | 09:24 PM
i still don't really get it. What i mainly want to do is get to a play list I've made and just play the songs on that play list.
Old Oct 27, 2007 | 09:43 PM
DarkBrew's Avatar
Okay. Select the playlist menu. The menus are represented by numbers and are selected as described above.
Within that menu select the playlist you want.
The lists are numbered in the same order as on your IPOD.
The same thing is described in the manual. Play with it a bit and you'll understand it. The real key to menu switching is to realize that the menu number only shows up on the time counter.
Old Oct 27, 2007 | 09:55 PM
mmk ill have to play with it ALOT then since i dont have the manual for it =(
Thanks for your help =)
Old Oct 27, 2007 | 10:10 PM
DarkBrew's Avatar
From my manual...
The numbers below shows up on the time counter for about two seconds after you change the menu.
1:00 = Playlists
2:00 = Artists
3:00 = Albums
4:00 = Songs
5:00 = Genres
6:00 = Composers
Lists within menus are changed by pressing CD change button once for less than a second. Twice in a second or longer than a second switches the menu.
Have fun.
BigMikeATL
May 26, 2016 12:31 AM
Nisaja
Series II Interior, Audio, and Electronics
Nov 3, 2015 05:30 PM
BigKid
Sep 23, 2015 07:46 PM
BigKid
Gulf For Sale/Wanted
Aug 13, 2015 12:40 PM
Jazzmeson
Jul 31, 2015 01:47 AM
