Just got the Ride lowered BY Jenkins install INC.
Old Oct 23, 2007 | 12:27 PM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
I just got the ride lowed and it looks great well on one side it does (driver) but on the other side (after the long drive back home) it sits about 1/2 inch higher. Any ideas on how to get the (passenger) side to settle even?
Old Oct 23, 2007 | 12:31 PM
NgoRX8's Avatar
what springs did you go with? which side matches the stated drop of the springs?
if you already had the control arms tightened with the car on the ground, then i assume that your weight lowered the drivers side from the drive. it should go back up if that were the case though.
Old Oct 23, 2007 | 12:36 PM
Turbo SR20deT Son!
I bought them off the nopi site Number 1 springs or something like that. It was suppose to be a 1.2 inch drop and we did lower the car then tighten up the control arms so your saying i should loosen them up and drop it possibly with some extra weight on the passenger side then tighten them up ? and the drivers side displays the the correct drop
Old Oct 23, 2007 | 01:35 PM
jones75254's Avatar
You noticed the drop right from the jump? Reason I ask is cuz when I put mine on it took a good 3-4 weeks for it to settle down.
You sure you just didnt forget to do the other side? LOL j/k man.
I would wait a week or more just in case it needs to settle in. Is possible your body weight could have settled in the driver side a little ahead of the passenger but i wouldnt think it be THAT much of diff.
Old Oct 23, 2007 | 01:43 PM
Turbo SR20deT Son!
Yeah maybe i just need to rent a fat chick for the week to ride shotgun. That will solve that problem.
Old Oct 23, 2007 | 01:58 PM
kersh4w's Avatar
Hit & Run Magnet
rofl.
rent a fat chick.
Old Oct 23, 2007 | 02:11 PM
jones75254's Avatar
LOL, I guess we will find out just how much you want that side to even out wont we???
Bring her down to the Import Faceoff at the Motorplex this Sunday. I wont crack any jokes i swear
Old Oct 23, 2007 | 02:38 PM
Turbo SR20deT Son!
LOl you got it well see how long that holds up
Old Oct 24, 2007 | 01:06 PM
Nopstnz's Avatar
I have the same exact problem with my passenger side. What I did was loosen the bolts on the control arms at the front and drove around a bit (20 and under) which loads your suspension with the vehicle weight. That way it evens out.
Old Oct 24, 2007 | 01:21 PM
Turbo SR20deT Son!
Sweet thanks for the info im down with that i was running out of ideas!
Old Oct 24, 2007 | 01:29 PM
SideOfBacon's Avatar
looks good... be better when it evens out though
Paul_Y
Sep 21, 2015 02:23 PM
LMURailsplitter02
Sep 6, 2015 10:56 PM
Rupanrx
Sep 4, 2015 06:44 AM
TotalAutoPerformance
Group Buy Center
Sep 2, 2015 01:40 PM
