i need help ASAP!!
Old Oct 21, 2007 | 11:07 AM
gotrx8's Avatar
i need help ASAP!!
I installed lowering springs on the front of my rex and looks great but just now got the drivers side rear lowering spring on it didnt lower it.... something i did wrong???
PLEASE HELP ASAP my car is in the driveway and in the air now after
i put the jack down and didnt look right
thanks guys/gals
Old Oct 21, 2007 | 11:26 AM
DOMINION's Avatar
I don't buy Kool-Aid
This will help you out a lot!
LINK
Old Oct 21, 2007 | 11:28 AM
Mazurfer's Avatar
Surf Hard, Drive Hard
thanks guys/gals
Jack car up
Put on stands
Loosen the bolts on the rear
Take car off stands and back to the ground
Either take it for a short drive or bounce the rear up and down to allow settling
Then and only then..........re-tighten the bolts with the car on the ground!
This should have been done in both the front and the rear by the way. On all four corners.
Or follow the link provided in the post above. I assume you have the springs turned and placed all the way where they should be.
Old Mar 14, 2008 | 11:43 AM
gotrx8's Avatar
everything is in perfect working order now.... sorry i forgot to update this thread.
Alignments works wonders!!!!
