what the heck are spacers? :dunno:
Old Oct 20, 2007 | 04:51 PM
yoshistoned's Avatar
confused
Question what the heck are spacers? :dunno:
wassaiii fellow 8 lovers! Long time reader first time posting! Please keep up sharing the knowledge- this forum is the greatest thing next to the 8!!
Posting hoping to get some insight from some of the gurus here. i am trying to mount a set of Works Emotion Cr Kai wheels on my 8. After patiently waiting for shipment this problem came up: my mechanic called asking where the spacers are. I had no clue what he was talking about but he told me I should use them to protect my wheels. I did a search here and understand that spacers are a preference thing? I don’t completely understand what their purpose is or even if I really should use them. Do i really need them and where to get em’? Many thanks in advance for your input.
Here are the specs:
Front: 18x8.5 38mm Tires: 245/40ZR-18
Rear: 18x9.5 38mm Tires: 275/35ZR-18
Old Oct 20, 2007 | 04:57 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
Here are the specs:
I am by no means a guru, so someone straighten me out if I am not correct on this:
Okay, here's the deal. Spacers are used if the calipers or something else won't clear the rims. They basically go on the lug bolts to put a space between the rotor cap(if you will) and the rim...this moves the rim outward. Now.........I have +38 offset and I have no issues with clearance at all, but we most likely have different rims, so you could be needing them. Good news is they are cheap, but don't use them unless you must. I also have the same size rims as you, I'm just 255 wide in the rear for tire width.
Old Oct 20, 2007 | 05:00 PM
TopGear8's Avatar
mkuhnracing.com
Yeah. what Mazurfer said was right. My wheels didnt clear my calipers so i had to get spacers. works fine for me. very cheap and they just slide right on.
Old Oct 20, 2007 | 05:01 PM
Mazurfer's Avatar
And any auto parts store would have them and most likely any decent tire shop.
Old Oct 20, 2007 | 05:22 PM
confused
Thanks for your quick responses!
Mazurfer thanks for breaking it down nicely for the rookie. btws Titanium Grey is the color man!
So basically what you are saying is that when the rims go on and it clears and doesn’t touch anything- don’t use spacers?
My mechanic hasn’t yet attempted to mount the rims to the car, just unpacked and didn't see any spacers so he called asking. He said that if I don’t use spacers I ran the risk of damage to the rims and the vehicle. He also said that whomever I got the rims from should have addressed this with me and supplied the appropriately sized spacers for my install. Is this a legitimate claim? I don’t understand how he could have determined I would need spacers without attempting to mount them first. I am wrong?
Old Oct 20, 2007 | 05:24 PM
Mazurfer's Avatar
Before I even attempt to answer this time.....what are your new rims? What make? We got the sizes down.
"So basically what you are saying is that when the rims go on and it clears and doesn’t touch anything- don’t use spacers?" <---- yes, I would not use them if no clearance issues. At +38 mine are close to not clearing the calipers, but they clear.
Old Oct 20, 2007 | 05:27 PM
confused
They are Work Emotion CR Kai:
Old Oct 20, 2007 | 05:32 PM
Mazurfer's Avatar
Okay.......not familiar with them as I have HP Racing Lightning Darks, so hopefully someone else will jump in or you can just buy some just in case. They are dirt cheap and you may not even need them. Sorry I can't answer 100%, but don't want to give you false info.
Old Oct 20, 2007 | 05:53 PM
Aipex8's Avatar
X e p i A
I would hope that you wouldn't need spacers for those wheels, if you add say a 10mm spacer it's essentially changing your offset to +28 and you're going to start running into rubbing issues. There are quite a few people on the forum with those wheels and I don't remember hearing anyone talk about spacers. Maybe your mechanic meant hub-centric rings or center caps or something.
Old Oct 20, 2007 | 05:55 PM
Mazurfer's Avatar
Yeah, I'll bet he's just fine and the mechanic(who hasn't seen it yet) was just being cautious(ya know, "oh you are putting on aftermarket rims")....... Now..........if he doesn't put them on and charge him if not really needed, then he'll be a good bloke!
Old Oct 20, 2007 | 11:31 PM
bruce_van's Avatar
Bruce Van
I think your mechanic probably means the hub rings, not spacers.
Old Oct 27, 2007 | 11:09 AM
confused
The rims are on- zero spacers and zero rubbing or clearance problems. The dude was talking about the gapping whole that’s now in the middle which exposes rusted bolts in the back and two random rusted circles in the front. He said that the car should vibrate at highway speeds, but fortunately that has not happened up to sustained 100mph.
Old Oct 27, 2007 | 11:19 AM
confused
Yeah turns out that’s exactly what he was talking about. Apparently most wheel manufacturers include them when you get a set but Works failed to do this with CR Kais. They don't look bad without any but a small attempt at this would have been nice.
Old Oct 27, 2007 | 11:32 AM
insane<se3p>'s Avatar
hey what's up
hey i was ready up on your situation. it's good everything is ok. just to let you know thought, i don't think your rims come with the center cap. i had some volks gtp on my 240 and it didn't come with any, they were extra. works are a big company, they probubly don't send in the caps, unless you order them or ask. if you did want to get spacers, they help on widening your stance, it can help, your corning. some people get them cheaper then getting wider rims and tires. but be careful, there are cheap ones you can get, but they break easy. thought i let you know. later.
.... oh your works are nice!
Old Nov 3, 2007 | 05:35 PM
confused
without the center caps
Attached Thumbnails what the heck are spacers? :dunno:-rx81.jpg   what the heck are spacers? :dunno:-rx82.jpg   what the heck are spacers? :dunno:-rx83.jpg
Old Nov 5, 2007 | 01:05 PM
lauy's Avatar
they still look gd without the wheel caps, I didn't put caps on my wheels either =p
Old Nov 5, 2007 | 05:05 PM
danielk015's Avatar
They look good without the center caps... i got the works emotions XT7 and i dont like the work center caps at all.. good looking rims.
92trbolzr
May 18, 2025 09:04 AM
JimmyBlack
273
Feb 10, 2020 10:23 PM
p8ntman442
Sep 22, 2015 08:06 PM
