cracked my sunvisor =(
Old Oct 18, 2007 | 08:26 AM
Miss.Trish's Avatar
patriciaaarrgghhhhh!!!
dont know how i did it but i flipped the passenger sunvisor down in my car and it cracked along the edge. it wont stay up anymore =(
and on top of that, after parking it in the sun yesterday for probably around 4 hours, i found that the plastic hook that the visor clicks into is starting to melt
anyone else had this sort of problem?
photos later.. maybe tmrw..
Old Oct 18, 2007 | 11:09 AM
DrewMan's Avatar
Culpam Poena Premit Comes
Apparently its a common problem. Are you still under warranty? Some people have had luck with the visors getting replaced at the dealer under warranty. XLR83N has the same problem but i think its his drivers side (hes out of warranty)
Ive had a rear 3rd brakelight fixed for free because it developed a mysterious crack. Maybe from closing the boot too hard?
Old Oct 18, 2007 | 05:01 PM
XLR83N's Avatar
yeh i have the same problem, passenger side (i dont have passengers anymore :P)
because i am out of warrenty i had to buy a new one ($120 trade/$150 rrp). Very expensive for what it is :@ Oh, it does come with a 1 year warrenty though, so i will have to make sure that i break it again before it runs out haha
As for your plastic clip thing, that sounds weird, will be interesting to see the pics.
Old Oct 18, 2007 | 07:16 PM
Cromax's Avatar
Buzz Buzz Buzz
I hope you don't do that in my car!
Old Oct 18, 2007 | 07:25 PM
Napboy's Avatar
Sho'Nuff
Don't know if it's similar in Australia, but in the states, there is a TSB and it's covered under warranty. Had mind down already.
http://www.finishlineperformance.com...02-07-1734.pdf
Old Oct 18, 2007 | 07:58 PM
Cromax's Avatar
Buzz Buzz Buzz
It's a stupid design, and they should've used better quality plastic.
Old Oct 18, 2007 | 09:40 PM
cmr333's Avatar
SR Dubbed Rx8
both of mine are gone. i got tired of flipping them bot up whenever i changed gears. my suggestion would be make some or get some made
Old Oct 18, 2007 | 11:49 PM
Cromax's Avatar
Buzz Buzz Buzz
Araldyte is your friend!
Old Oct 19, 2007 | 05:49 AM
DrewMan's Avatar
If duct tape and superglue cant fix it, its broken for good
Old Oct 19, 2007 | 11:10 AM
XLR83N's Avatar
I tried and still broke!!!, left it set for like 48 hours even
Old Oct 19, 2007 | 06:41 PM
Justinrx8's Avatar
Team QQ
Mine did this a while back and it was still under warranty. Basically what looks like happened is that the arm on the left of the sunvisor gets torqued or something and cannot rotate anymore, snapping the plastic in two when you try to lower it. I could barely rotate the arm with pliers before I took it in.
Old Oct 19, 2007 | 07:00 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
There is a TSB on it........if you take it in they will fix it for free.
Even if you are out of warranty and are nice aboout it, they will probably replace it for free as well.
It has happened to a lot of us and there are numerous threads on this!
Old Oct 19, 2007 | 08:52 PM
Cromax's Avatar
Buzz Buzz Buzz
Darn straight ... use gaffer tape though, the mesh in it would hold the crack together a bit better!
Nothing like a car that's taped together
Old Oct 21, 2007 | 02:02 PM
cmr333's Avatar
SR Dubbed Rx8
i have a plan drawn up for sun visor that i am coing to build. its very simple to make with materials ranging from fiber board to abs plastic, whatever your fancy. i have been trying to decide what to do with the power wires, sugestions would be cool. ill do what i can to get some plans posted up soon.
Old Oct 21, 2007 | 02:14 PM
AJ's Shinka's Avatar
Enthusiast
Both of mine broke passenger side and drivers side both were replaced under warranty took them 1 week to get the part and < 30 minutes to replace it. It's been fine ever since
Old Oct 21, 2007 | 02:16 PM
Mazurfer's Avatar
As long as it don't break, you'll make more money than Forrest Gump!
Old Oct 21, 2007 | 06:35 PM
Revolver's Avatar
Shootin' from the hip
Hmm, didn't know this was a common problem. Never had hassles with mine.
Mind you, sunnies take care of the glare for me and it's not like I have to check my hair and makeup too often, lol...
Old Oct 21, 2007 | 07:09 PM
Mazurfer's Avatar
Yeah, my Oakley's do just fine, but I do use both everyday to hold the sunshade up to keep the sun off the interior when I'm at work.
BTW..........I believe the did redesign it a little. I have new ones and no trouble since.
OnebaddRx8
Oct 17, 2015 10:05 PM
arexatemate
Oct 4, 2015 12:36 PM
archon
Oct 1, 2015 06:08 AM
GK1707
Sep 27, 2015 07:33 PM
coolcars44
Sep 24, 2015 05:47 PM
