Rough turning at low speed
Old Oct 16, 2007 | 09:04 AM
mum's Avatar
mum
Sometimes, when pulling away from a stop and turning, the car feels very rough. Almost like the traction control is kicking in when it shouldn't. Over the weekend I pulled away from a stop, turning left, and actually stopped about a hundred feet away to check if one of the tires had gone flat. It felt very much like it was a wobbly flat tire. The tires were all fine.
This only happens occasionally.
Any ideas?
Anyone experience anything similar?
Note that I've searched around a bit, but don't have a good enough set of terminology to describe it to turn anything up.
Thank you for any insights.
Old Oct 18, 2007 | 03:21 PM
MTLbroker's Avatar
Yeah, I get the same thing lately...... Dealer claims there is nothing wrong.
Old Oct 18, 2007 | 03:26 PM
ManFriday's Avatar
I get this once in a while too..
I have no idea what it is.
Old Oct 18, 2007 | 03:31 PM
rglbegl's Avatar
Baned
Start at the beginning.
tighten your lug nuts.
Dont ask how i learned that one.
Old Oct 18, 2007 | 04:37 PM
GRGJTSN's Avatar
vV Me on the Dragon Vv
Guys I may be barking up the wrong tree, but I think it might be the Limited Slip Differential...does it seem to be coming from the rear? Mine does it too, only occasionally and only on tight, slow turns.
If this is it, it is normal operation of the differential (it is trying to prevent the rear wheels from turning at different speeds).
Hope this helps.
Old Oct 18, 2007 | 04:47 PM
Uncivilizedracer's Avatar
Turbo SR20deT Son!
Hope this helps.
+1 And if your making a turn that makes a diff of how the differential reacts
Old Oct 18, 2007 | 08:36 PM
SayNoToPistons's Avatar
Wheels, not rims!!
alignment.
Old Oct 19, 2007 | 01:04 AM
DOMINION's Avatar
I don't buy Kool-Aid
Wink
Any ideas?
When was the last time you checked your spark plugs?
Old Oct 20, 2007 | 06:39 PM
05TiGr8Lady's Avatar
Jingle Ballzzzz!
Had the same thing and just got it fixed a couple of weeks ago. It would do the same thing after I'd driven it for a while. Getting in and out of parking spaces and slow turns were bad - grinding, clunky, shuddering... and I have 24K miles. I read a few other threads about this issue. Shaunv74 rode with me and said it felt/sounded like the differential. Took it to the dealer - they said they didn't feel anything when they drove it (I don't think they drove slow enough and sharp enough turns), but they drained and refilled the diff. twice. No problem at all now.
Old Oct 20, 2007 | 10:01 PM
moete87's Avatar
Ohio State
I get the same thing! I took my car in for service on wed and I noticed it a little wed and thursday, but it got real bad on friday. Going into turns and coming out of turns I could def feel something wrong. The dealer worked on my rear differential.....im looking at my invoice that I got from them and all it said for the rear differential is, replaced the lube and gasket. But before I went to get my car serviced, everything was working great and now it feels def weird.....like what everyone is describing.
Not sure what to do!!
Old Oct 20, 2007 | 10:04 PM
Jingle Ballzzzz!
Take it back..
Old Oct 20, 2007 | 11:25 PM
tajabaho1's Avatar
Destroying Threads
I think its time for you to get a new alignment!
D13
Aug 22, 2015 11:42 PM
Solmors
Aug 21, 2015 10:11 PM
Nisaja
Aug 6, 2015 01:27 AM
dbarber
Jul 25, 2015 01:34 PM
