Drop in gas mileage after Voluntary Emission Recall Campaign 4206F?
Has anybody experienced a drop in gas mileage after having the 4206F recall done?
I had the recall done back in December 2006, but then put my car in storage for six months when I left town to finish up grad school half-way across the country. So I didn't start driving my RX-8 regularly again until just this past summer.
I immediately noticed that I was getting 13-14 mpg when previously I was getting 16-18 mpg. At first I thought it was a change in driving habits. I was taking more short trips and getting less highway time.
But since I keep a detailed account of every fill up I've had since I've owned the car, I checked back to compare gas mileage numbers. The lower numbers started right after I had the recall done. And the numbers are consistently lower ever since that time.
So what I'm wondering is:
1) Anybody notice the same problem?
2) Is it possible that the PCM reflash was done incorrectly?
3) Is it possible to get the PCM reflash redone or reversed back to the old one or an even newer one?
I think I might take my car on a long highway drive and just empty the tank, just to see what mileage I get on the highway and settle the question of whether or not it's change in driving style or an actual change in fuel consumption.
finish out the tank. get good gas. reset the ecu. drive it hard...
then see what the next tank brings..
Hate to say it but its most likely your short trips that is killing the mileage since I get the same (but getting progressivly worse
). My own lil theory is that the ECU runs it super rich for awhile then leans out after its been driven for awhile. Its that or your CAT is slowly failing on you.
). My own lil theory is that the ECU runs it super rich for awhile then leans out after its been driven for awhile. Its that or your CAT is slowly failing on you.Well Mazda, after a year and half of fighting with them, great customer service, agreed to do a mpg test. There results came out around 21mpg. (I won't go into how they screwed up the math at first) but this was Highway and far suburban mileage. When I drive the highway I get between 18 and 22mpg depending on aggressiveness and speed.
So this leaves me with one of two possible answers. There is something wrong with my car that Mazda can't/wont find. Two, the RX-8 is a horrible city car in terms of mpg. It my be a little of both.
Sure it is not just a winter thing???and that you really have been checking for more than a month or two???
Remember CA reformulates its gas in October through March for emissions, and gas mileage typically drops a couple MPG when that happens.
I've been checking since the end of June.
