View Full Version : Illuminated Glovebox?
Footman 10-13-2007, 06:28 PM Hey guys,
Does the glove box have a light? There appears to be what looks like a rectangular piece of clear plastic if you just look up inside the glove box. That spot looks perfect for a light to go there, but there is no light when I opened the box :(
Mazurfer 10-13-2007, 06:39 PM Hey guys,
Mine had a light and now it has a V-LED 194 blue in it!
See: http://www.rx8club.com/showthread.php?p=1958587#poststop
Footman 10-13-2007, 06:56 PM Mine had a light and now it has a V-LED 194 blue in it!
WHAT? the dealer lied to me and told me there is no light in the glove box??? So you're saying stock, it comes with a light in the glove box? Can you take a pic to show me? I want proof to show the dealer. Please and thank you.
Mazurfer 10-13-2007, 08:34 PM WHAT? the dealer lied to me and told me there is no light in the glove box??? So you're saying stock, it comes with a light in the glove box? Can you take a pic to show me? I want proof to show the dealer. Please and thank you.
Will do so tomorrow..................now, just in case, I have a 05 GT 6sp.............and I see you have an 07, but I don't see Mazda dropping that! :banghead:
Footman 10-13-2007, 09:06 PM Okay, I just went downstairs and took a screw driver to that clear plastic thing. There was a BULB inside it! Why did it not light up, I don't know. This is a brand new car, how could it have "burnt out" already?
Will talk to dealer tomorrow. They try to scam me!
Mazurfer 10-13-2007, 09:30 PM Okay, I just went downstairs and took a screw driver to that clear plastic thing. There was a BULB inside it! Why did it not light up, I don't know. This is a brand new car, how could it have "burnt out" already?
They just didn't want to mess with it. I would still change it and put in an LED. Hell, I'm surprised you got the cover off that easy, it's actually one of the tougher ones to get off unless they have changed the design. Anyway, I need to go look now and see if I left the cover off after installing the 194 LED or whether I put it back on????? It may have looked better and more light with it off. I'll edit this when I get back in and let you know. BTW........it's the same bulb that you have in your doors, so if you really want to know if it's the bulb.......then you could just try one of those.................but since you are under warranty, let the dealer do it.
You do know that you have to have your lights at least on to the parking lights and/or headlights to have that glove light work righht? I forgot that little fact when I just went out and looked! oh...............I did put the cover back on, it must be the one in the trunk that I left off.
snipaz2420 10-13-2007, 09:34 PM thats weird because my glove box doesn't light up either! i'm going to check it out tomorrow
Mazurfer 10-13-2007, 09:38 PM thats weird because my glove box doesn't light up either! i'm going to check it out tomorrow
Read my other post about two up......I just edited it!
Don't forget you gotta have your lights on!!!!! :lol2: I forgot that little fact!
Footman 10-13-2007, 09:40 PM what the heck? Mazurfer.. you're saying the glove box only lights up when the engine is running and and the lights are turned on? That's the stupidest engineering I've seen. If someone were to access that box when the car is off, then there is no light??? I'm going to turn on the headlights to see if they work... can it be rewired to be turned on when opened?
Seriously, what kind of engineer came up with that idea for the glove box light to ONLY come on when the headlights are on?
Footman 10-13-2007, 09:42 PM BTW, it was easy for me, ebcause I used a swiss army (swing out screwdriver blade)...
so the entire length of my prying took is only about 4 inchs. There are 4 tabs to pry off.. easy..
Mazurfer 10-13-2007, 09:45 PM what the heck? Mazurfer.. you're saying the glove box only lights up when the engine is running and and the lights are turned on? That's the stupidest engineering I've seen. If someone were to access that box when the car is off, then there is no light??? I'm going to turn on the headlights to see if they work... can it be rewired to be turned on when opened?
:lol2: I don't know, but that's how mine is..........car doesn't have to be running, but lights must be on. I guess if you think about it.........90% of the time you would probably have the lights on in the car when you went into the glove. Guess they figured you'd get stuff out without lights 10%(when it was dark out) and didn't bother??????? Daytime doesn't matter.
Yes, you could re-wire, but I'm not sure it's really worth it.
Footman 10-13-2007, 10:02 PM wait, when you say lights on, you don't mean the "light on" button near the sunroof controls right? You mean like, the headlights on?
Mazurfer 10-13-2007, 10:06 PM wait, when you say lights on, you don't mean the "light on" button near the sunroof controls right? You mean like, the headlights on?
Yep, you must at least turn the headlight switch to the first position.......so that your radio/center console lights come on.
Footman 10-13-2007, 10:20 PM Okay, I just verified... it works. WOW that is the ABSOLUTE GAYNESS SH*T I've seen... it comes on ONLY when your lights (first toggle) is on... and you know what's more gay.... the glove box light is on indefinitely; even when closed. Mazda skimped out on the sensor that turns on only when open. What a waste of bulb life and battery!
Mazurfer 10-13-2007, 10:25 PM Okay, I just verified... it works. WOW that is the ABSOLUTE GAYNESS SH*T I've seen... it comes on ONLY when your lights (first toggle) is on... and you know what's more gay.... the glove box light is on indefinitely; even when closed. Mazda skimped out on the sensor that turns on only when open. What a waste of bulb life and battery!
Agreed, but not much battery loss since your headlights or interior lights would drain the battery much more quickly..........since those have to be on. :)
Pretty funny when you think about it.............it is kinda stupid of them. :rolleyes:
Footman 10-13-2007, 10:35 PM I'm an engineer myself... I know this is poor engineering. (thoughtless engineering)
Mazurfer 10-13-2007, 10:38 PM I'm an engineer myself... I know this is poor engineering. (thoughtless engineering)
Yep, I do Design, Product, and Test Engineering on high-rel Military/Space ASIC's and all sorts of other commercial/automotive IC's.............I'd never let it out that way!
qtwre 10-14-2007, 12:07 AM Dude you are one outraged SOB. Chill brah. :P
GoesLikeStink 10-14-2007, 10:26 AM Dude you are one outraged SOB. Chill brah. :P
Ha ha...nice!!
:lol2:
Late2Brake 11-16-2007, 12:39 AM WTF, there IS a glove box light. Never opened my glove box while driving at night, so who would have known? That's one of the first things I noticed, Oh "No" glove box light.
Definitely a candidate for a rewire mod.
Crazy design.
MazdaManiac 11-16-2007, 12:51 AM Mazda just didn't feel like paying for a switch on the latch, I suppose.
Late2Brake 11-16-2007, 01:06 AM It's kind of hard to believe, I mean when you have the dim blue led 'nightlights' on the gauges when you open the doors (pretty cool).
Maybe it was the same guy who thought up the fuel door without a strap hanger.
rx8phase1 11-16-2007, 06:30 AM It's kind of hard to believe, I mean when you have the dim blue led 'nightlights' on the gauges when you open the doors (pretty cool).
haha my brother said my car was cheap cuz it didnt have that strap for the full knob i mean come on this is the first car i'vee seen that didnt have one another thing it didnt have was a light bulb for the engine
delhi 11-16-2007, 12:34 PM actually you can dangle the strap using the fuel door hook.
Late2Brake 11-16-2007, 01:56 PM actually you can dangle the strap using the fuel door hook.
It's still against the paint, plus it's kinda in the way of the pump handle.
rettro 11-25-2007, 01:57 AM My '93 MX-6 glove box is the same way; the headlights (or at least the park lights) have to be on. Looks like a Mazda tradition!
