L.E.D. bulbs for the rx8
Old Oct 13, 2007 | 03:42 AM
matt13b's Avatar
I just got some led bulb bulbs and fitted them up to my brake lights,reverse lights, numberplate lights etc from Japan and was just wondering if anyone knew where I could get some more from australia anywhere for the centre brake light and side mirros/door lights etc??
Old Oct 13, 2007 | 04:09 AM
Black-8's Avatar
Rotary noob
don't know about the side mirror light, but isn't the centre brake light and inside door is normal T10? The map light is also T10. The centre roof interior light is the festoon dome base type. I usually buy my LEDs from eBay, from this particular seller: http://stores.ebay.com.au/id=7001941...TRK:MEFS:MESST
Old Oct 13, 2007 | 08:51 AM
takahashi's Avatar
Side mirror light is a W5W, 194.
3rd (centre) brake light is a standard T20 or 7440.
https://www.rx8club.com/showthread.p...bulb+code+list
EDIT: My experience of LED in the parker light and number plate lights are not very good. They die prematurely while the interior one last over 3 years now.
Old Oct 13, 2007 | 08:19 PM
RNE515's Avatar
what a wankel!
Yeah, thats been my experience as well. Quite annoying
Are there any recommendations for the parker light? something thats close to the stock headlights?
Old Oct 13, 2007 | 08:50 PM
Mazurfer's Avatar
Surf Hard, Drive Hard
If they will ship down under(sorry for that mate) use V-LED's and I promise you won't be sorry. Here's what I run and you should be able to cross numbers if need be.
https://www.rx8club.com/showthread.p...58587#poststop
BTW......."Parker Light"?, is that what we call "Parking Lights"?
If so, what I have is a good match and I think you'd like them. They are a real pain to get to though unless you got really small hands.
And....................Be careful changing the 3rd brake light(the center one) to an LED, it can actually cause problems. I'll see if I can find that thread and post it here if I find it.
Dave
Old Oct 13, 2007 | 09:13 PM
takahashi's Avatar
Thanks for the links ... yeah we call it the "parker"
Right... the problem of the LED in parker is that the current may be too high. Otherwise, I am not able to think of another explanation. Is the V LED highest quality you can find. Coz it is a waste of money to ship it half way across the globe otherwise.
Old Oct 13, 2007 | 09:21 PM
Mazurfer's Avatar
Naw, the LED's work fine in the parking lights up front, it's that third brake light in the rear that was causing issues with some folks. Think it was the DCS circuit believe it or not and was getting disrupted and setting it off. I do think it was a current sensitivity issue, and for some reason in that third brake light position, it didn't like it.
Well............I'm not an expert, but I've been running everthing you saw in that thread for over a year with no issues and no burnouts. Before I started, I did alot of research on this site and people without a doubt liked them best. Maybe you should do a group buy for everybody in Oz?
Old Oct 13, 2007 | 09:42 PM
Mazurfer's Avatar
Taka...................here's that other thread about the third brake light issue if you or any others are interested.
https://www.rx8club.com/showthread.p...28246#poststop
Believe it or not, I think it was an issue because there wasn't enough current draw using LED in that position.
Dave
Old Oct 13, 2007 | 10:42 PM
RXP33D's Avatar
My V-LED led for the parkers just died in the *** last night.
Old Oct 13, 2007 | 11:11 PM
RNE515's Avatar
what a wankel!
And....................Be careful changing the 3rd brake light(the center one) to an LED, it can actually cause problems. I'll see if I can find that thread and post it here if I find it.Dave
Cool, thanks mate! I have been looking for a decent match for a while.
My thinking is that its the heat causing the LED parking lights to fail but who knows.
I'll prob order a set of blue's and the super whites in your thread...lets see how it goes.
Old Oct 14, 2007 | 02:08 AM
takahashi's Avatar
LED does not generate as much heat as normal lights.
Old Oct 14, 2007 | 04:19 AM
DrewMan's Avatar
Culpam Poena Premit Comes
you get what you pay fir with lights IMO.
get some decent PIAA ones and they will last for yonks
Old Oct 14, 2007 | 04:56 AM
matt13b's Avatar
ok thanks for the help guys..
dmengel
Feb 16, 2016 09:47 PM
SupraG
Sep 21, 2015 12:09 AM
CARBONRX-8
Aug 23, 2015 09:52 PM
Stubbs
Jul 28, 2015 09:23 PM
RX7.9
Jul 20, 2015 12:01 PM
