170kw Rx8
Old Oct 13, 2007 | 01:09 AM
matt13b's Avatar
170kw Rx8
I know that due to emissions they had to start making the rx8 170 kw(in Australia). I assume that they just reprogramed the computers on them,but does mazda re-flash all our cars that when we go in for a service or leave them at 177kw's??
Old Oct 13, 2007 | 02:55 AM
DavidM's Avatar
Maybe it's the same power as before, just revised power claim?
Going back a few years, Mazda had to revise the claimed power figures for both MX5 and RX8 in US as they found them to be overated. Just from memory, I tought the claimed power in the States for the rx8 is more like 167kW.
Old Oct 13, 2007 | 02:58 AM
takahashi's Avatar
The reflash of the car does not normally change the main fuel map of the car, so I will suspect that it will remain the same power. Dunno if 177kW and 170kw is the same. We do not have a new car to confirm that the flash version is totally different.
Revised power claim could be possible
Old Oct 13, 2007 | 05:57 AM
matt13b's Avatar
O.k. thanx all. I hope my 05 model still has 177kw's!
Old Oct 13, 2007 | 07:09 AM
Black-8's Avatar
Rotary noob
problem with dyno-ing it is that you won't know if you have that extra 7kw or not, because all car produces different power, even stock
Some says it depends on how you run in the engine, the more you baby it, the less power you get
Old Oct 14, 2007 | 04:25 AM
DrewMan's Avatar
Culpam Poena Premit Comes
On top of that, all dynos produce different results and all have tiny mitigating factors.
but they are usually within 4kw of each other
Old Oct 14, 2007 | 04:31 AM
Cromax's Avatar
Buzz Buzz Buzz
You left out the fact that all dynos are different as well.
Old Oct 14, 2007 | 04:32 AM
DrewMan's Avatar
Beat you to it cromax!
Old Oct 14, 2007 | 04:36 AM
Cromax's Avatar
Buzz Buzz Buzz
So you did!
Old Oct 14, 2007 | 04:41 AM
Cromax's Avatar
Buzz Buzz Buzz
I did a few dynos on my other car with the same setup and they were all different between about 10kw.
They're a waste of time anyway ... who cares about how much power your car has, it's all to do with the mushy organic stuff sitting in the drivers seat anyway!
Am I right or am I right?
Old Oct 14, 2007 | 04:58 AM
matt13b's Avatar
I would dyno it but have recently put a high flow cat,midpipe and exhaust on and so the dyno figur won't be for a standard car??
Old Oct 14, 2007 | 05:00 AM
Black-8's Avatar
Rotary noob
true, every dyno is different, but I was just merely stating (implicitly) that if the car is put on the same dyno, the car that was claimed having 170kws with the car claimed having 177kws will not yield conclusive result as to which one is 177kws and which one is 170kws.
having said that, if the weather changed much (temp, humidity, etc), then even on the same dyno won't yield same result
Old Oct 14, 2007 | 05:27 AM
Cromax's Avatar
Buzz Buzz Buzz
The high flow cat would, but who cares?
Old Oct 14, 2007 | 05:44 AM
Cromax's Avatar
Buzz Buzz Buzz
Yeah, I know ... his car will obviously be over the stock emissions anyway!
Old Oct 14, 2007 | 07:40 AM
matt13b's Avatar
Originally Posted by MissyK
Well I'm just saying he is concerned that the stock 177kw will impact on new emissions laws since the rx8 now gone down to 170kw yet if he has the older model, but has those mods.. should be more concerned with that model he has with the mods that actually do increase emissions.. ?
No I don't care about the emissions,I just want to see if my 177kw car hasnt been changed back to 170kw for the emissions like the new ones are..
Old Oct 14, 2007 | 07:45 AM
DavidM's Avatar
On top of that, all dynos produce different results and all have tiny mitigating factors. but they are usually within 4kw of each other
I'd say there's more like 50kW range between dynos. It's more like (up to) 20kW difference most of the time, but have seen instances where the same car produced 50kW different readings on different dynos.
Though, same day / place / operator dynos shuld read within 10kW from one run to another.
Old Oct 14, 2007 | 08:27 AM
Cromax's Avatar
Buzz Buzz Buzz
Do a search. But the answer is no.
Old Oct 14, 2007 | 04:40 PM
auzoom's Avatar
Hmmmmmm.........
I remember reading somewhere or hearing something that said the 170kw drop is to do with a change in Cat'. Also, I am not sure about NZ or the rest of Australia but in Victoria a car is always assessed on the laws at the time the car was first registered. So emissions law changes now, dont affect my car registered nearly 3 years ago.
Old Oct 14, 2007 | 06:33 PM
takahashi's Avatar
The cat is different is the one in Japan. I think it is the same cat in Australia from 2003 onwards.
I am more into the reclaim power figure from the fuel we used. You see you totally agree there is heaps more power when we use V Power Racing
Old Oct 20, 2007 | 05:39 AM
matt13b's Avatar
Do you mean the 100 octane when you say that Taka?
