Door Piece Removal
Old Oct 12, 2007 | 03:39 PM
RX8USMC's Avatar
Door Piece Removal
I cannot figure out how to take this off can someone offer some help? (check attachment) thanks
Old Oct 12, 2007 | 04:47 PM
c0ldf1ame's Avatar
thats part of the door panel, you hafta take the entire panel off first. The black plastic peice with the window controls pop out, and then you gotta take off the screw behind the door open lever and theres another screw behind the handle by the door pocket. And then you gotta pop out the speakers by the A pillar. After that you should be able to remove the interior panel by pulling it out
Old Oct 14, 2007 | 03:17 PM
RX8USMC's Avatar
I removed those three screws, disconnected the power window/locks piece and removed the bose tweeter and this thing wont even budge what else do I have to do? here is a pic of the progress
Old Oct 14, 2007 | 04:11 PM
Juice's Avatar
I made some poos
There are a bunch of tabs that go around the edges of the door, stick a butter knife or something flat and not sharp on the outside of the panel and pry it from the door, just be careful. There is a picture a couple posts down in this thread that shows ou where the tabs are:
https://www.rx8club.com/series-i-interior-audio-electronics-24/how-remove-door-panel-21613/
once you get the tabs off it will seem like it is just hanging from the top by the window, just lift up from the back and it will come off.
Old Oct 14, 2007 | 06:33 PM
nuke0907's Avatar
Never Blend In
you might have to go buy some more of those tabs when you take it off. i took mine off the other day and 2 of them broke.
Old Oct 14, 2007 | 07:59 PM
RX8USMC's Avatar
Nuke
Thanks I got it off. luckily the tabs didnt break too...anyway nuke I just moved from newport news not a bad spot
Old Oct 17, 2007 | 03:48 AM
nuke0907's Avatar
Never Blend In
no problem. mine only partially broke to where they are still usable, but if i take it off again, i am going to have some problems.
yeah its not too bad here, but i want to move back to FL ASAP
Jst4fun
Apr 17, 2021 07:43 AM
Jst4fun
Mar 5, 2021 07:16 PM
Learners_Permit
Sep 27, 2015 07:38 PM
projectr13b
Series I Do It Yourself Forum
Sep 6, 2015 01:04 PM
