Changing Wheel Size
Old Oct 10, 2007 | 11:37 PM
Silent_Angel's Avatar
Changing Wheel Size
Hi recently purchased a new 8 and getting ready for Canadian Winter
I have a set of 16" rims that I want to use but I was wondering will it affact things like the Engine Management or Speedometer?
And does the 04 have a Tire pressure Sensor?
Old Oct 11, 2007 | 12:07 AM
nuke0907's Avatar
Never Blend In
maybe and yes
Old Oct 11, 2007 | 12:14 AM
by a noticable margin? say 2-5km/h? or something like 10-15km
Old Oct 11, 2007 | 01:01 AM
nuke0907's Avatar
Never Blend In
depends on the overall diameter of the tire.
Old Oct 11, 2007 | 01:03 AM
Nopstnz8's Avatar
It might because I have 20"s and my speedometer is one mph faster than I'm actually going.
Old Oct 11, 2007 | 03:38 AM
Z1k RX8's Avatar
If you keep the overall diameter of the tires within + - .4%, the differance to the speedo shouldn't be enough to worry about. Your real problem is the size of the front brake disk. I'm not sure about the 04's but the newer models that come with 18's have a bigger front disk than the back. If thats the case then the 16's won't fit. Of course you can always try a test fit with one wheel to make sure.
Do you know if the bolt pattern and offset of the 16's will work with your car?
ladnarf1
Apr 29, 2021 11:53 PM
rx8inator
Sep 1, 2015 07:18 PM
Shinka84
Aug 19, 2015 04:55 PM
GK1707
Aug 3, 2015 10:23 PM
