View Full Version : i found my wheels
chetrickerman
10-08-2007, 08:30 PM
Black O.Z. ultraleggera 18 x 8 are the rims im going to go with. They are beautiful, and light as hell. And im either going to go with Yokohama AVS ES100 or BFGoodrich g-Force T/A KDW 2 for tires. What do you think for tires. Do you know of any places for rims and tires that are cheaper than tirerack.com?
SolarYellow510
10-08-2007, 11:04 PM
KDW2 in stock size is a good choice. Hard to go wrong, great value. ES100 is noisy.
I doubt you'll find a better deal on the package from a reputable place anywhere else.
You might consider having the wheels and tires shipped to one of their preferred installers local to you, so you can have your tire pressure sensors transferred over to the new wheels before the tires are installed.
chetrickerman
10-08-2007, 11:09 PM
ok thanks, thats what i planned on doing
GeorgeIngleton
10-09-2007, 10:44 PM
Sick wheels be sure to post pics. I wanted a set of bronze ultraleggeras for my Brilliant Black
Revvittupp
10-09-2007, 11:56 PM
FWIW people that work at tire stores and Car delerships typically buy their own tires on Tire Rack. Tire Rack is essentially a retail site with wholesale prices. .
chetrickerman
10-10-2007, 08:56 AM
so tirerack is the cheapest, ok fine by me, i love these rims, cant wait to get them
and they are light as hell, 18#s
savedsol
10-10-2007, 01:15 PM
What offset would you go with? My guess is Tire Rack would only be willing to sell you the +48 vs a +35 or so that would look much better.
mac11
10-10-2007, 01:34 PM
Tire rack will sell you anything.
chetrickerman
10-10-2007, 02:10 PM
i dont know much about offset, so i would want to keep it as close to stock as possible, and stock is 50, so i would go with 48.
BlueRenesis82
10-10-2007, 02:24 PM
KDW2's are great tires, I loved the set that I had.
chetrickerman
10-10-2007, 02:28 PM
well i will get the rims and tires over the winter, a long with other mods, but i wont be putting them on until spring when the snow is all gone
BlueRenesis82
10-10-2007, 02:30 PM
Good call, are you planning on driving the car over the winter?
chetrickerman
10-10-2007, 02:32 PM
i have to drive it over winter, but im getting an underbody rustproof coating from zeibart, and i have winter tires that came with the car, so i will take real good care of my baby
nikos_g
10-10-2007, 03:04 PM
http://www.tires-easy.com/
this where i found my tires, best price ever i got anywhere i looked.
take a look!
loved your trims.
how is the offset affects the driving?
chetrickerman
10-10-2007, 03:10 PM
thanks, i dont know yet, i dont have them, but i will let you know how they are
BigOLundh
10-10-2007, 03:34 PM
i dont know much about offset, so i would want to keep it as close to stock as possible, and stock is 50, so i would go with 48.big mistake
chetrickerman
10-10-2007, 05:21 PM
whys that? like i said, i dont know much about wheel offset
mac11
10-10-2007, 07:10 PM
under carriage bullshit from ziebart? waste of money.
the whole underpan of the car is coated with a rubberized coating already.
chetrickerman
10-10-2007, 07:21 PM
yea, but it would be good for all the bolts and exposed stuff, but why is a 48 mm offset bad?
thecow135
10-10-2007, 09:58 PM
why is it bad?
SolarYellow510
10-10-2007, 10:42 PM
Stock is +50 et. Get the +48 et. A +35 et will make your steering suck.
And if you don't have to drive them through winter, get these tires:
http://www.tirerack.com/tires/tires.jsp?tireMake=Bridgestone&tireModel=Potenza+S-03+Pole+Position&partnum=245YR8S03PP&vehicleSearch=true&fromCompare1=yes&place=2&speed_rating=H&speed_rating=V&speed_rating=Z&speed_rating=W&speed_rating=Y&minSpeedRating=H
The only risk is because they are on closeout, something happens to one and you can't get a replacement. So keep them rotated and pay attention to inflation and your tire pressure sensor warnings. And get your car aligned properly, as close to zero toe as the factory range provides for.
Have the wheels and tires shipped to a Tire Rack preferred installer close to you, unmounted, so you can have your tire pressure sensors swapped over.
mac11
10-10-2007, 10:46 PM
now, please tell me why a +35et will make the steering "suck"?
SolarYellow510
10-10-2007, 11:07 PM
15mm change in scrub radius is significant. It will almost always change steering feel significantly. Mazda's product development engineers will want to give you a massive wedgie when they hear about you doing it.
Different platforms have different tolerance for change. I've driven an E46 that was ruined by an 8mm difference, other cars that were decent with 11mm change. If a wheel that's otherwise the same with 2mm change is available, why go with the 15mm change? If you want to fill out the fenders cosmetically, 9.5" +45 et all the way.
chetrickerman
10-11-2007, 07:42 AM
well my wheels only have a 48mm offset, so i will be good
savedsol
10-11-2007, 08:03 AM
Although you provide an example your logic is based on one car and your own "feeling". Keep in mind there are Japanese laws regarding tire to fender width tolerances - read about it in Motor Trend a long time ago (lost my microfische sorry). Also, it would seem ridculous to say that moving outwards 15mm is going to change your steering any more than moving to a wheel that is 1.5" wider, sticks out more (24mm) and also encroaches (14mm) to the inside of the car. 24 and 14 is not exactly a balanced ratio either. It would be like just buying a 8" +40 wheel. 5mm? C'mon.
Nemesis8
10-11-2007, 11:55 AM
The KDW's are noisy - they are on the '02 337 my daughter drives.
chetrickerman
10-11-2007, 12:54 PM
annoying noisy, or just eh whatever noisy?
mac11
10-11-2007, 01:31 PM
Thats all subjective.
chetrickerman
10-11-2007, 01:43 PM
ok, well im either gonna go with the KDW's or Bridgestone Potenza S-03 Pole Position tire, but 48mm offset rims isnt bad or going to effect my steering/handling correct?
mac11
10-11-2007, 02:24 PM
thats damn near stock. shouldn't effect anything unless they are overly heavy.
I say the noise from the KDW's is subjective because a lot of people hate the road noise from the OEM Potenza's but I generally don't notice it. Same with the squeal from the OEM brake pads. I hardly notice and even when I do it doesn't bother me.
BlueRenesis82
10-11-2007, 02:32 PM
You know that the S-03's are discontinued right? Plus those are some HEAVY tires
savedsol
10-11-2007, 02:35 PM
I'm not trying to be a jerk but you need to go research offsets here and otherwise. There are TONS of threads on: is this offset ok, what's the max offset, will these wheels fit, etc, etc. Tire Rack has good FAQs on their site and helpful staff. Read all you can and call them if you are confused regarding your application. Also the old standby...
http://www.1010tires.com/WheelOffsetCalculator.asp
Stock wheels are 8" in +50.
savedsol
10-11-2007, 02:44 PM
And I would doubt their Wisco winter performance anyway.
BlueRenesis82
10-11-2007, 04:08 PM
No kidding! You would be much better off just expecting to pile into something.
chetrickerman
10-11-2007, 05:31 PM
im not going to use them during the winter, i already have winter tires on there, but i guess i wont go with the S-03's cause i do want light tires, and i will look up offsets, thanks
zerobio
01-06-2008, 06:25 PM
Chet, did you get those black ultraleggeras? I am so tempted to get them for my summer rims. I just can't decide between Oz Ultralegger, Axis Reverb, or Tenzo DC-6, all black for my BB.
reverbs:
http://www.zerobio.com/rx8/axis_reverb.jpg
tenzos:
http://www.zerobio.com/rx8/tenzo_r_dc_6.jpg
I would also go with the 48 offset ... right now I have 40 with the SPYN rims and it feels fine but I'll also be happy going back closer to stock. That and the fact that the spyns are 25.5 lbs :(
chetrickerman
01-06-2008, 06:26 PM
no, too expensive for me. i am just going to go with a package with Enkei RPF1 and Toyo TR-1 tires for $2100
zerobio
01-06-2008, 06:43 PM
Yeah the oz are. Those rpf1's are light, 18 lbs. Would you go for staggered or just 35 (or 45) offset in front/back?
dmak_el
01-06-2008, 07:54 PM
not to be an ass
but do u mind explain urself on how the offset can make such a "huge" different feel as you said?
do u know what's scrub radius?
from what i know from school, it can only be affected by SAI and camber. Since there are not adjustment on SAI on our car. only thing that really affect the scrub radius would be our camber setting.
chetrickerman
01-06-2008, 07:58 PM
not staggered. staggered effects the handling, and i will be tracking quite a bit, so i want the best handling i can get
zerobio
01-06-2008, 08:05 PM
Got it.
SolarYellow510
01-07-2008, 10:25 AM
Moving SAI or camber will change both the center of pressure of the contact patch and the point at which the steering axis intersects the ground (claimed as the "Dave Point" by my friend who is now a Mazda product development engineer). Your school assumed you are doing alignments, not changing wheels.
Jedi54
01-07-2008, 10:31 AM
I say go bigger and wider! 19's would look hawt. (assuming they're available in that size)
chetrickerman
01-07-2008, 11:02 AM
nah, i just want to go wider. i dont need anymore top speed
lxlxlxl_saki_lxlxlxl
01-07-2008, 02:23 PM
heard that the rims are light weight also. like around 18 lbs?
