Spinning Sushi
10-02-2007, 07:09 PM
So... I decided to paint my engine cover... (I broke my DigiCam and I had to use my crappy cell phone to take pictures. So I took a lot of pictures just in case)
Things Needed:
400 Grit Sandpaper
Painter's Tape
Newspapers/Paper/etc.
High Temp Primer
High Temp Paint
A sharp knife/razor blade
A really hot day where the sun is out (Quicker drying :rolleyes: )
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0046.jpg
What I did was sanded it down with 400 Grit Sandpaper...
This is the hard part, using Painter's tape... I had to get into the small corners with my nails (Luckily for me, I didn't trim my nails yet) to push the tape down. I then used a very sharp knife to cut the middle part with a lot of precision. This is what it looks like after I finish trimming the middle part where the painter's tape stuck out.
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0041.jpg
Notice how the tape don't stick out? I trimmed it when the tape is still in the crevice.
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0042.jpg
Now, spray on an even coat of primer, use a zig zag motion, do not go over the same spot twice, this will cause overspray! It'll look ugly...
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0043.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0044.jpg
Remember to pray to the sun god! It dried in less than 30 mins! (Had to sacrifice a goat to the Sun God in order for him to make the day warm so the paint can dry)
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0045.jpg
Next, spray on your color of choice, same thing. Zig Zag motion, do not overspray! I recommend two coats of it.
You'll get something like this...
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0048.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0049.jpg
Now, did you offered a sacrifice to the Sun God yet? You'll need it. Why you ask?
Reason:
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0050.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0051.jpg
When The Sun God is happy, he'll shine shine bright so your paint will dry faster!
Slowly peel back the painter's tape along with whatever you covered your cover with and voila. You're done.
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0052.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0053.jpg
Cover in my Engine Bay.
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0054.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0055.jpg
http://i36.photobucket.com/albums/e37/xDarkGenesisx/Photo-0056.jpg
Just in case you're wondering... Yes, it's my first DIY... Please excuse my inexperience to write up a DIY :rolleyes:
Things Needed:
400 Grit Sandpaper
Painter's Tape
High Temp Primer
High Temp Paint
Reason:
