Chris_Bangle
10-02-2007, 05:47 PM
Since different people lurke in different sections of the forum I will post this here as well:
I have decided to get Koni dampers. I already have RB sways on the car and now thinking about what springs to will work best the RB Koni combo.
The car is a daily driver, which I am hoping is going to do about 12-15 track events per season. Lapping, driving schools and possibly solosprint. All this is done with the objective to become a better driver and having fun, I am not competing.
In the future I will probably add a set of 17" RA1 for the track.
I am currently deciding between Swift and H&R. Their rates seem well suited to work with the RB sways (not overly firm, whatever that means).
I know that rates don't tell the whole story but don't have much more then this and people's inputs to rely on.
Here are a few points I have been thinking about.
H&R seems to have a decent reputation where as Swift is somewhat of a dark horse.
Swift has comparatively low rate for the rear spring but I am not sure what to make of this, on one hand this means more grip for the rear or understeer which might be good considering the aggressive nature of the RB sways and me starting up. On the other hand I dont get this.
H&R drop is lower 1.25 to 0.8, which is probably better for the track.
Any other springs which would work well with the RB sway and Koni dampers?
Another related point;
Will I have to set up the Koni's differently based on the springs I go with?
Completely new to suspension set up,
All positive input is appreciated...
Spring Info:
stock sport
Front drop 0"
Front rate 156 lb
Rear Drop 0"
Rear rate 113 lb
Swift:
drop: -0.8 inch front and rear
front spring rate: 3.7 Kg/mm 207 lbs/inch
rear spring rate: 1.6-2.3 Kg/mm 90-129 lbs/inch
H&R Sport
Front drop 1.25"
Front rate 195 lb Progressive
Rear Drop 1.25"
Rear rate 141 lb Progressive
stock sport I verified these spring rates on post number 97 of this thred
Front drop 0"
Front rate 156 lb
Rear Drop 0"
Rear rate 113 lb
Sway info:
Off the RB site:
The diameter of the front tubular bar is 1.25 (32mm) x .1875 wall thickness, as compared to the stock 1.05 (27mm) x .134 wall thickness front bar.
The diameter of the rear tubular bar is .75 (19mm) x .125 wall thickness, as compared to the stock .632 (16mm) x .097 wall thickness rear bar.
Spring Info:
stock sport
Front drop 0"
Front rate 156 lb
Rear Drop 0"
Rear rate 113 lb
Swift:
H&R Sport
Front drop 1.25"
Rear Drop 1.25"
Front drop 0"
Front rate 156 lb
Rear Drop 0"
Rear rate 113 lb
Sway info:
Off the RB site:
