the best way to get rid of condensation
Old Oct 2, 2007 | 12:19 AM
yushinrt's Avatar
hi just wanted to know what would be the best way to get rid of condensation out of your tail/headlights.
any one got good easy way ??
and i don't really want replays like just take it to dealer or get new ones or something like that
i personaly think bakeing way is pretty easy
Old Oct 2, 2007 | 12:52 AM
c0ldf1ame's Avatar
i remember in my civic days we used some form of silicon sealant, never tried on the 8 thought, but im pretty sure it should work the same way
Old Oct 2, 2007 | 12:57 AM
NgoRX8's Avatar
yes, silicon should be the fix. why? did you end up getting condensation in your headlights?
Old Oct 2, 2007 | 01:02 AM
MyEnemy's Avatar
Why not take to a dealer, bad dealership where you are? Other then that take the lights off and use a hairdryer and the reseal them I guess.
Old Oct 2, 2007 | 01:12 AM
Decat's Avatar
Wink
I am assuming you are getting the typical condensation in the rear driver side tail light assembly. Easiest most safe method is to use an air compressor to blow the air out, other method which is more risky is to turn on a high watt lamp and evaporate the water out, but do not let the lamp get too close or let the tail lamp get too hot or the clear plastic will end up melting completely. After it is all out, install all your bulbs but not the harnesses. Use very high quality automotive duct tape to seal up all the small hole you can see that might let water in. Hold a flashlight up on the outside of the unit and use duct tape until you cannot see any light coming through the other side where the light bulbs insert. My RX-8 was involved in a small fender bender on the rear left before I got it and so the factory will not cover this repair so I have had to get creative! Let me know if you have any problems. New fixture on ebay is around $40 if you mess up.
Old Oct 2, 2007 | 01:16 AM
yushinrt's Avatar
no no i fixed my one allready with drying it out by bakeing it and resilicon the light but jus wanted more information.
i just wanted to know if there is easer away of doing this and wanted to know whats a good what thats all
Old Oct 2, 2007 | 02:35 PM
baking is good but you have to take it out.
Otherwise I like the compressed air method.
Old Oct 2, 2007 | 06:17 PM
lowrdteg's Avatar
Who needs Cylinders
how many miles you got? less than 50k go to a dealer its under warnaty. I got my tail replaced for free
Old Oct 6, 2007 | 06:19 AM
DOMINION's Avatar
I don't buy Kool-Aid
Yeah there was a DIY on here a long time ago.
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
nferguson88
Oct 6, 2015 12:45 PM
XxVindicatorxX
Sep 20, 2015 12:50 PM
