Help!!! Check Engine Light!!
Old Sep 27, 2007 | 04:41 PM
devourerc's Avatar
Hello guyz! thnx you too much if any1 wanna help me..this ******* light..damn it..CEL...is always on..no1 know wich is the problem..Mazda say to me i have a probelme to the engine and i must change it..it's impossible.It is a big problem ? i think no..
Old Sep 27, 2007 | 04:44 PM
Rems31's Avatar
what's the code?
Old Sep 27, 2007 | 04:48 PM
FirstSpin's Avatar
I can only tell you what I learned about my rx-8 today. My check engine light came on and stayed on for days on end. I knew that a gas-cap left off or left loose could account for the light coming on. I tightened the bejeezus out of the gas cap and it did nothing.
Turns out... my 3.8 yr old gas cap had ceased to make a good seal with the opening to the gas tank. It was "seeping" fumes or losing pressure - doing something that the computer picked up on and reported as a CEL.
Spring for a new gas cap and see if that does the trick. It's cheaper than an engine ))
Old Sep 27, 2007 | 04:52 PM
StealthTL's Avatar
Metatron
First stop should be a code-reader ($90 approx) that can read the info from the computer - make sure you buy one that can handle the new CanBus protocol.
Then you can stop guessing......
S
Maverick86's Avatar
If your RX8 is completely stock and has absolutely no mods, check your gas cap, it may not be properly tightened or it doesn't seem to be operating up to what it should be. Chances are, that's the reason of your CEL. I had the same problem with my Mazda3, there was something wrong with the mechanism so they had to replace my gas cap.
If it is moded, find out the code and check it out using a scanalyzer.
You can see what the code means here:
https://www.rx8club.com/series-i-tech-garage-22/rx-8-technical-info-cel-codes-pcm-pin-list-collision-guide-26291/
Old Sep 27, 2007 | 04:54 PM
BranDaMan's Avatar
I had the same problem on my 04.
champi0n's Avatar
Isn't there a key on /key off cycle that will allow you to read the code numbers via blinking CEL lights?
my old 97 car you'd key on/off 3 times then the light would blink like moorse code for ya.
Old Sep 27, 2007 | 05:06 PM
Ike's Avatar
Ike
Blue By You
ZOMG, youz shud take it to teh delarz!
Old Sep 27, 2007 | 05:09 PM
go to autozone, use their code reader
Old Sep 27, 2007 | 05:12 PM
Rems31's Avatar
then check it with these codes
https://www.rx8club.com/showthread.php?t=26291
Old Sep 27, 2007 | 05:17 PM
Nemesis8's Avatar
Bigus Rotus
Check your gas cap BTW
Old Sep 27, 2007 | 05:43 PM
Silver_Mazda09's Avatar
Stop Looking @ my Rotary!
I don't believe so....You now days have to use and Scan Tool to pull any "Check Engine" codes. Not like the old days. everything getting more advanced. Computers control most of the cars now!
Old Sep 28, 2007 | 10:03 AM
Maybe you do need a new engine
Old Sep 28, 2007 | 10:51 AM
mike73737's Avatar
Yep, don't bother with a reader, engine is shot!
Old Sep 29, 2007 | 06:18 AM
devourerc's Avatar
thnx!!
i thank you guys... i'll try to buy a new gas cap for the gas tank... if this doesn't work, i'll try to get a code reader. my mazda rx-8 doesn't show the error codes. hope i'll solve the problem! thanks again for the answers.
Old Sep 29, 2007 | 07:27 AM
j67345's Avatar
There is a TSB for the gas cap though. If it is the cap, they should replace it for you for free. I'm on my 4th one now (they had a bit of a problem getting one that sealed properly!).
Old Sep 29, 2007 | 07:34 AM
Spinning Sushi's Avatar
I <3 Sushi
Well, usually a CEL means your car is going to blow up. You better sell it ASAP.
OR.... you can take it to Autozone, they have a code reader there that they'll let you use for free.
Old Sep 29, 2007 | 08:41 AM
New Yorker's Avatar
I have the original gas cap ('05 model). From the day I bought the car, I've never been able to tighten it (the way other gas caps on other cars tighten). Instead, it tightens a little, and then just clicks, no matter how many times I turn it.
Is this normal? I would think my gas cap is defective and should be replaced with the redesigned one, except for one thing: CEL has never come on. What gives?
Old Sep 29, 2007 | 05:09 PM
devourerc's Avatar
hmm...
can be sparks ?or gas filter?? hmmm...wednesday i know...ohh...
Old Sep 29, 2007 | 06:33 PM
nate340's Avatar
If it’s not throwing a cel, it must not be leaking. So I guess you don’t need a new cap.
i had to have mine replaced a few days ago since it kept throwing a cel, small leak
Old Sep 29, 2007 | 06:37 PM
TheKDog's Avatar
2007 BB RX8 GT
My '07 had the light come on because of the gas cap.
But it did not go away after tightening. I had to take it to the dealer to reset it.
Old Sep 29, 2007 | 06:41 PM
trick to tightening gas cap. hold straight, tighten slowly. Click 3 times, STOP.
You're all set.
Old Sep 29, 2007 | 07:19 PM
Ericok's Avatar
Rotary Wanker
That's exactly the way it works. Turn till it clicks a few times, you're done.
Old Sep 29, 2007 | 08:30 PM
ken-x8's Avatar
Correct. If the problem is the gas cap, replacing the cap won't make the CEL go out right away. I believe it takes a couple of tanks and on/off cycles. Since a lot of CEL events are intermittent, and the light will go away after a few cycles, it is nearly impossible to tell what's happening without reading the code.
The gas cap problem applies to a specific range of VINs. They're listed in the TSB.
FWIW - When my 8's CEL came on because of the gas cap (P0455), I did not see the light engage in any sexual acts, so I suspect the OP's problem is something else.
Ken
Old Oct 6, 2007 | 06:39 AM
devourerc's Avatar
My Rx8 is fucked up...
Oil pump told me....ffs....error P1688 - PCM ...
