View Full Version : Pettit Super Charger Owners
Pages : 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 [16] 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38
morkusyambo
12-02-2008, 09:18 AM
What Cam should do is package them with a smaller pulley(and flash) and a coil upgrade,,,
I dont think anyone of us would pass that up!!!
^+1^:eyetwitch
morkusyambo
12-02-2008, 09:19 AM
OD, I used the same wiring diagram as Juan, and neither him nor I have had a lick of trouble.
-Yambo
olddragger
12-02-2008, 11:34 AM
i did too--and thats the fustrating part. Just my dang luck a gremblin of some sort has taken up residence in my ig system. I even soldered all the connections etc.
Can the capacitator go bad? But if it did it would affect ALL the firing on all coils--so cant be that.
Did you have to add a spacer to your pickup like Dann is speaking of? May try that.
currently just tracing all wires to insure all connections (did replace the power wire pigtail as it was busted up but it was wrapped etc and once repaired it didtnt make any difference), wires are ok and using this "oppitunity" to sanitize the harness/engine bay. also double checking the spark plu wires and installing wire loom to keep them separated well
I have female connectors for the oem set up--think i will order one new coil and make a plug and play system while running the stock set.
There should not be any difference as far as wiring between the yukon coils and the ls2 --right?
thanks for all the help guys.
olddragger
marsredr100
12-02-2008, 12:12 PM
Denny,
Did you soldered directly into the coils connectors? If so, you probably ruined the internal coil connectors/solder. I'm speaking from experience. :eyetwitch
Bastage
12-02-2008, 12:15 PM
There should not be any difference as far as wiring between the yukon coils and the ls2 --right?thanks for all the help guys.
olddragger
Correct. They are exactly the same except the yukons have a heatsink on them and the mounting points are oriented differently.
So let me get this straight: your coils all work at low RPM but when you rev the engine some of them stop firing? If that's the case, you mostly likely have some bad coils. I had this problem initially with some used coils purchased off of ebay, and it was verified with a timing light. All 4 coils would work fine while idling, but once they went over 4k rpms, 2 of them would quit, and it was always the same 2 coils (we swapped connections/plug wires around on them to verify it was the coils and not the connectors/plug wires). Once I had some good coils in there, it ran excellently, and I haven't had a problem since. Test them out with a timing light and see if this is what's happening.
marsredr100
12-02-2008, 12:22 PM
+1 :eyetwitch
MazdaManiac
12-02-2008, 12:35 PM
The timing light verification method works best if you tape it to the windscreen and have a passenger watch it while you beat the living crap out of the car.
Testing at idle won't tell you much.
Bastage
12-02-2008, 01:28 PM
Right, especially since his seem to fire fine while idling.
Rote8
12-02-2008, 08:06 PM
I read the Yukons actually have more current flow, but even the LS* coils have way more spark than the stock coils.
Hymee
12-02-2008, 08:31 PM
What is the scoop with the connector on these LSx coils?
The problem I'm chasing is intermittent. http://www.rx8club.com/showthread.php?t=161523
Cheers,
Hymee.
olddragger
12-02-2008, 10:31 PM
yes i soldered the wires of the connectors to the harness wires--about 3 inches of wire from the connector itself--my connectors were preformed and had wires already.Used a mini torch to do it. It was 36F while I was doing this--I got a tad bit cold. What internal solder are yall talking about---should I just use connectors then? Juan didnt you form your own connectors?
Got my oems back on(had to re solder all those d--- wires--)-car runs like a top now.
As stated probably bad coils--i did get them from e bay but its a long standing company. Havent given up---ran across some female connectors for the oem ones so a plug and play set up is being formed
right--- mine was ok at idle, at crank and at free rev--it was only when a slight load was placed on the car like acceleration or going up a hill--so bad it was not drivable. Just my d--- luck.
At least she is ok now to get me to my class with Eric Meyer concerning rx8 chassis set up at Road Atlanta this w/e.
thanks for all the support ---will try again after Christmas.
Have a fuel system to now work on.
OD
Bastage
12-02-2008, 11:30 PM
OD
Is the business you bought them from in COLUMBUS,OH 43231?
If so, they sell used/probably factory rejected coils they claim to be new. 2 of mine were bad, so I sent them all back, and got 4 as replacement, which had at least one that didn't seem to like high RPMs, because it felt a little off. I ended up just buying the Yukons from Northeast Core and Component (which were definitely new) and have not had a problem.
MazdaManiac
12-03-2008, 03:35 AM
http://www.rx8club.com/showpost.php?p=2297851&postcount=37
Hymee
12-03-2008, 06:06 AM
Thanks! I knew one of me buddies would point me in the right direction instead of yelling about the search button. :)
Cheers,
Hymee.
MazdaManiac
12-03-2008, 11:59 AM
Cheers,
Hymee.
http://www.mazdamaniac.com/images/misc/searchdumbass.jpg
california style
12-03-2008, 01:44 PM
haha, first the carrot, and THEN the stick! 8)
Hymee
12-03-2008, 04:09 PM
Hahaha. I must be that clever that I don't get that on my main menu !! LOL.
morkusyambo
12-03-2008, 06:36 PM
OD, i'll take some pictures of my setup and post them here so you'll have another visual. I also soldered my connections.
marsredr100
12-03-2008, 11:13 PM
Life is good! From a cruising 80 mph to 129 mph with AF ratios below 12. Although fuel pressure/flow was plenty judging by the AF ratios, a fuel pressure gauge is in the works to make sure the fuel pressure does not drop due to my new secondary 440 injectors. I also have something else in the works, ha! :eyetwitch
MazdaManiac
12-04-2008, 02:11 AM
For you MAF junkies, a datalog from this afternoon:
http://www.rx8club.com/attachment.php?attachmentid=129854&stc=1&d=1228374611
Yes, that is 387 g/sec at 6800 RPM in 4th. Load of 2.0.
california style
12-04-2008, 05:05 AM
Good stuff. Nice airflow. I bet that keeps you pushed into the seat!
PS Juan. You never stop! Keep adding bits mate! 8)
olddragger
12-04-2008, 06:09 PM
nice numbers dude.
txs mork after the reverse analysis was done it boils down to one coil totally shot and one coil marginal. I have some female plugs for the oem one and i am going to make a plug and play harness.
The guys I got the coils from are not in ohio and they are talking to me. You are right I dont think they were new.
right now trying to get some Yokohama s drive tires on--the ford place here screwed me over--i took time off from work etc for my appointment install and I get there and suddenly they cant do it. There guy is "tied up" on another job(great guy by the way)--pissed me off. They should have called me. Guess an $800 set of tires doesnt matter to them. Told them to forgot it.
OD
OD
Rotr8
12-04-2008, 06:18 PM
alright still having the stall issue...
Only happens after stopping for gas, no matter what my driving habbits were prior.
this time it took 4 start ups to finally have it sit at idle...
Any suggestions? simularities....
I will data log this next time since I know its a instance I can easily replicate...
Moon Assad
12-04-2008, 07:19 PM
Try checking your coils, since the trail fires first at idle you might have one going bad. When we did the install on Rolands car wich only had 700 miles on it, if I recall, 3 of his coils were bad already. I cant count how many went bad on my car.
marsredr100
12-04-2008, 10:30 PM
Well folks, I guess is time to let you know about my latest mod. After weeks of begging Cam let me purchase an SC Automatic eccentric shaft pulley. I other words, a 5-inch pulley instead of the SC Manual 4.5-inch. I finally had the time to install it this afternoon. I took the car for a quick around town test and I immediately noticed a bit more of blower whine were before I could not hear due to my Exotic Speed header/RB race pipe/RB exhaust combo. I got 10.3 psi boost at @ 8200 rpm. The SC belt needs a bit more tightening (new gatorback 33.5 inch) but I’m waiting for it to stretch before I readjust it. According to a website with a pulley conversion that I use, my new drive pulley ratio is 1.479 from 1.331 At 8200 rpm the blower is turning at 12,127 rpm. I would have to hit 8800 rpm in other to max the blower’s 13000 rpm but why should I since 8200 rpm is where peak hp rest. Noticed that my AF ratio fluctuate below 12 when the engine rpm is below 8000 rpm and just over 12 after 8000 rpm.
Anyway, before you start thinking (I got to get me one of this) I highly recommend you to address your SC RX8 ignition, injectors and methanol injection or you might end up rebuilding your engine due to a catastrophic case of detonation. Mine runs with MSD and NGK 10.5 leading ~ 11.5 trailing plugs for ignition, 440 (blue) secondary injectors, 50/50 mix of VP Racing M-5 methanol, RP 10W-40 and K&N oil filter.
I’m installing a temporary fuel pressure gauge tomorrow just to verify that the fuel pressure does not drop below 60 psi while at full throttle (drive it like you stole it) mode and from sustained highway cruising speed to (I hope there is not a cop ahead, behind or around the corner) mode. :eyetwitch :eyetwitch :eyetwitch
Rotr8
12-04-2008, 10:36 PM
:yumyum: :yumyum: :yumyum: very nice.....
olddragger
12-04-2008, 10:56 PM
you are the man dude--have been building to this havent ya!
time to go to a 20/50 oil and warm her up gently?
wise to be careful with the fuel pressure.
what are your thoughts on the front bearing stress?
OD
california style
12-05-2008, 02:36 AM
Go Juan! And Ray! Don't blow up though!
PS I know everyone says power is addictive etc, but for me, my car is awesome now.
I have no desire for anymore. Just more opportunities to hit the track etc....
Rote8
12-05-2008, 02:48 AM
OD
Pre-mix with 10mg Valium per gallon.
We are adding more torsional loading, but I have not yet heard of any front bearing failure, even if you are not running the 20-W50 as recommended by Pettit.
(Hopes I won't need to check that bearing, ever)
I use 20-W50 Valvoline or Castrol for the engine (dino flavoured) and use Royal Purple 20-W50 in the blower itself.
I have always liked the tear down results of an engine running Valvoline.
It's very nice to have no crud in the crankcase when an engine is torn down.
I have not yet torn apart a Castrol engine, but I have had as many friends swear by Castrol as Valvoline.
marsredr100
12-05-2008, 07:35 AM
Negative Ghost Rider. I'll do that after an engine rebuilt and replacement of the Eccentric Shaft Thermal Pellet.
Every time I think of it I get flashback from a nasty clap episode while stationed in Korea back in 1986.
OD
:eyetwitch
marsredr100
12-05-2008, 07:41 AM
"Dino Flavoured" Eek! :icon_no2:
Is not about crud/sludge in the crankcase. Is about keeping all the rotor seals and rotor O-rings from getting stuck/brittle due to dino spuge leftover.
RP 50 weight for the blower and a cocktail of lead (to combat Florida's 10% ethanol gas) and Marvel Mystery Oil for pre-mix. :eyetwitch
olddragger
12-05-2008, 02:52 PM
did they treat that clap with the old marine corp method involving a hammer?!:)
DIno for me after tearing down my engine with 50K and 40K of that on RP. SHould have seen my front bearing. It was through the copper on one side. This was really before the s.c. and the belts were OK. Rest of her looked pretty good as far as waer was concerned--the lubricated areas I mean.
Castrol GTX 20w/50 for me. I have heard people swear by valvoline also.
Changing oil q 3K-5K and keeping the engine cool will take care of the seals etc.
DO NOT run RP in the trans!!!
On the pellant --i have heard both pros and cons on doing that.
Has the intake temps gone up with the increased boost? Time to change the w/m nozzles?
Yokohama s drive tires on today for every day driving---very sweet! Makes a new car out of it.
OD
marsredr100
12-05-2008, 06:56 PM
OD
A hammer? :Eyecrazy:
Nope, a trip down to the ville home schooled doctor. Total cost a jar of mayo and two packets of hotdogs (black-market items back then). :eyetwitch
morkusyambo
12-05-2008, 08:53 PM
I'm glad others are trying this. You should be seeing 10lbs of boost@4000 rpm though. Also, the blower is now spinning @13,800. Not to worry though, it can handle even more than that.
-Yambo
Rotr8
12-05-2008, 09:23 PM
are you enticing the sale of them ???
marsredr100
12-05-2008, 09:32 PM
Castrol GTX 20w/50 for me. I have heard people swear by valvoline also. OD
Well I'll stick with RP since it is what Racing Beat recommends and have the experience/reputation to back them up. Also David Canitz RP Tech Services Manager and professional race drive of a GT3 RX3 (Big Time Rotorhead) recommends the same. Heck! I use synthetic oil even on my lawn mower. Now that I think of…I wonder if synthetic oil can enhance french-fries flavor like MSG? :eyetwitch
marsredr100
12-05-2008, 09:39 PM
I'm getting there. I installed a temporary fuel pressure gauge today but did not have the time to take the car for a test. BTW all previous log attachments were taken with the DSC on. I will do a couple of passes with the DSC off once I feel comfortable with my current setup. :eyetwitch
marsredr100
12-05-2008, 09:44 PM
Has the intake temps gone up with the increased boost? It is hard to tell cuz the ambient temp was 55 at the time I took it for a spin.
I will find out later this month at the dyno. For now 100m/l before the blower and 60m/l after the blower.OD :eyetwitch
marsredr100
12-06-2008, 08:07 AM
That’s right…here’s what’s coming next: :eyetwitch
RX-8 Race Pipe with Presilencers
The RX-8 forums have been active with requests for a resonated RX-8 Race Pipe, and we've responded!
It seems that the popular Mazsport resonated race pipe (which featured dual Racing Beat universal presilencers) is no longer available on the market. We've decided to fill the void and offer a revised version of this resonated race pipe using two presilencers that have been specifically designed for the limited space available in the RX-8 chassis. These reconfigured presilencer units will assure adequate chassis clearance and eliminate the need for the "spacer" blocks that were required with the Mazsport unit. The revised presilencers should be in-house within 6-8 weeks.
Thanks to all of the RX-8 forum members for their input!
olddragger
12-06-2008, 09:28 AM
you will like that midpipe--i have been running one for some time and it is as quiet as stock until you hammer it down. the spacers were no problem. need just a little room--not much.
OD
Rotr8
12-06-2008, 02:46 PM
Ha I got that newsletter too,, I posted it in the RB header development thread...
Brettus
12-06-2008, 03:32 PM
-Yambo
are you serious - 10lbs at 4000 rpm ? I thought the SC did not reach max boost till max rpm ?
Rotr8
12-06-2008, 03:48 PM
Lysom style chargers arent like what your thinking,,, I can hit max boost any gear any rpm...
Brettus
12-06-2008, 04:14 PM
better post up a dyno then - cause earlier dynos of the Petit kit did not seem to reflect this .....
Rotr8
12-06-2008, 04:32 PM
earlier dynos waved around by Jeff or the ones that have been posted in threads that are currently locked becasue of Pettit haters?
I have nothing against Jeff or BHR, and Ray is one of the nicest and most informed people on this forum, but you guys should really stop shitting in here
Brettus
12-06-2008, 04:46 PM
I'm genuinely interested - not shitting at all
Rotr8
12-06-2008, 04:51 PM
Well then, I havent Dynoed yet I just installed three weeks ago, theres a local tuner that just got the pro logger software for the 8's Cobb AP and Cobb is doing a 10% sale during December that will probably never happen again ,,, sooo it should be very soon...
Of course Im not one of ther lucky few testers that happens to have the new pulley, but I hit 7lbs on a conservative tune from Pettit
EDIT- well maybe not 'any' rpms,,,(pre-measures against language/grammer mongers)
MazdaManiac
12-06-2008, 05:15 PM
Uh, yeah. :icon_no2:
How about just fact-mongers?
Rotr8
12-06-2008, 05:36 PM
how about fucking people with no life other than a forum
awaiting some kinda smart ass remark... But thats ok I still have nothing personal against you, you just need to be put on a leash sometimes:lol: ...
ohh yeah another pre-warning ,, yeah I know you know more than me:lol2: ...
MazdaManiac
12-06-2008, 05:42 PM
Yeah. All I do is sit around here.
I'm already wearing your mom's harness, so why not.:lol2:
StealthTL
Claims ain't facts until the dyno sheet appears.....
10lbs at any rpm, 7lbs at any rpm, whatever - post it or take the criticism.
S
Rotr8
12-06-2008, 05:56 PM
I can take it...
Norm and Juan are the ones running the new hardware...
nice sig by the way, I waited a whole what two days for my FI option...
Moon Assad
12-06-2008, 06:05 PM
Pettit, continuing to make other wishfull owners eat words they regret. Ok, once everything is ironed out with the injectors, bags of them that Cam showed me, who wants to put there car up for a nice dyno to state another fact?????? I have $10 on 335, 340WHP. TQ, thats to be seen, :eyetwitch very curios myself.
Rotr8
12-06-2008, 06:08 PM
hmm interesting, I assume we are talking about the two pre mentioned SCs that have yet to be dynoed....
Moon Assad
12-06-2008, 06:14 PM
Yep, no crapping on this thread anymore, that goes for everybody. Time will tell, assumptions, well you now.
tibyABv6
12-06-2008, 06:38 PM
You do not shift at peack hp ... unells you have mad torque... you have to look at what power you land in next gear, most of the time it is still lower then at redline.
But yes, you do not want to get too klose to blower limits.
Moon Assad
12-06-2008, 06:51 PM
Well, just a thought, I overspun my 1.4 blower buy alot, like 7k and more for a long time 10k with no ill effects on the blower but it was at low boost, from what I hear if you overspin at more boost you run the risk of raising output temps but since your well within the recomended max psi (30 psi I think) You might get away from that issue over spinning with meth keeping your air temps down. If you can get say 15 psi buy changing out your pullys, its still well with in the Blower perameters, any thoughts????
california style
12-06-2008, 07:02 PM
OD
I got the Yokohama Advan Sports on mine and they are really good so far.
Very impressed.
marsredr100
12-06-2008, 07:10 PM
Today I finally got the time to take the car for a spin with the temporary fuel pressure gauge. I drove the car over 30 miles at various speeds, on the go acceleration and take off with just a ¼ of a tank in order to make it a worst-case scenario. My son monitored the gauge the whole time and kept giving me feedback while I monitored my AEM AF ratio gauge just to make sure I did not go lean. At the end the OEM fuel pump did its job. It maintained pressure no matter the conditions (except lateral acceleration). :eyetwitch
marsredr100
12-06-2008, 07:22 PM
After disconnecting the temporary fuel pressure gauge and filling the fuel tank at $1:85 a gallon for premium we then hit the road again for some EFIdude logs. The chart below shows fifth gear acceleration from 57 mph to 107 mph and with a final 11.3 psi boost. :eyetwitch
marsredr100
12-06-2008, 07:33 PM
My highest boost reading was 11.5 psi on forth gear and I still need to re-adjust the blower belt. Ambient temp was 75 degrees and the AIT was 78 degrees thanks to my 50/50 VP Racing M-5 mixture.
The car feels 100% better. :ylsuper:
I’m going to dyno it within the next few weeks and see if the butt dyno matches the real dyno. :eyetwitch
Moon Assad
12-06-2008, 07:51 PM
What kind of airflow are you seeing??
marsredr100
12-06-2008, 08:35 PM
Three fity fife so far and I still need to re-adjust the blower belt. :eyetwitch
Rote8
12-06-2008, 08:55 PM
All my high readings are in a quick burst in 1st or second gear, as I do not have higher flow injectors yet. (I pray for my rotor seals)
The seat of the pants dyno tells me it feels strong.
I have seen 10 PSI on my boost gauge, but I do not have the time to examine it closely when the engine is screaming and the car is trying to go sideways.
I don't have traction control on my model car, or really any traction at all in low gears.
Bastage
12-06-2008, 09:47 PM
all I have to say is:
Nice!
swoope
12-07-2008, 10:01 AM
I’m going to dyno it within the next few weeks and see if the butt dyno matches the real dyno. :eyetwitch[/QUOTE]
juan,
let me know when you are going to go.. i will meet you! :)
beers :beer:
Rotr8
12-07-2008, 10:11 AM
Swoope,
Brice tells me you may sitll have a new RP supercat that you may be interested in selling...
Im going to check mine, Im having the same problems Juan was when his went bad.... PM the price and availability...
swoope
12-07-2008, 10:27 AM
Swoope,
ok,
but i would be sending it back if you got it from them. they are supporting the product. :)
beers :beer:
Rotr8
12-07-2008, 10:37 AM
my car is my DD and I got the RP because my OEM blew up,,, so that would mean my car would have to sit for a while, and that means LWOP for me...
Rotr8
12-07-2008, 11:22 AM
lol Ray, you've never overstayed your welcome,,, as far as Im concerned you all class and no ass...
Rotr8
12-07-2008, 11:28 AM
:Drooling_ :Drooling_ :Drooling_ Wish my car wasnt my DD so it could be tuners test mule....
morkusyambo
12-07-2008, 12:48 PM
Yes. This is not with the standard pulley setup. It is with the 5" blower drive pulley. I was using it several months ago.
Juan, I noticed you have made a few posts in regards to your belt. I purchased a Goodyear Gatorback 5PK350, which is slightly longer than the belt we get from Pettit. It worked just fine, while producing the aforementioned boost numbers.
Rote8
12-07-2008, 01:06 PM
Yes, same here, I needed a 33.5 inch belt compared to the stock 32.5 inch.
It will be a while before I get to dyno, I still need the bigger injectors AND a set of Yukon ignition coils.
It really looks like Juan is the only one ready to dyno.
marsredr100
12-07-2008, 02:42 PM
Yup, that's the one I'm currently running. I re-adjusted the belt this morning before heading to work. I was able to hit a solid 12 psi boost. I'm going to take a short video this evening on my way home and hope to have it on youtube after 10:30 tonight. :eyetwitch
california style
12-07-2008, 05:19 PM
12 psi! Blimey!
Looking forward to the vids, and hopefully not as shaky as the ones we made, haha!
Moon Assad
12-07-2008, 05:35 PM
Little sunday drive, sorry its in a Subi
http://video.kenblockracing.com/flash/small_player/preloader.swf?vendor_id=204&media_id=9183&bgcolor=FFFFFF&autoplay
Rotr8
12-07-2008, 06:16 PM
Its gonna be hard Ray its a very limited customer base.... I'd be interested later after acouple people would prove it there are still other areas of my car I want to address first....
marsredr100
12-07-2008, 07:40 PM
Yeah, well the first prototype of the BHR blower drive kit is about to be built but alternate ratios were never the key point. ZERO belt slippage at all RPMs is. Now that I am seeing higher overdrive ratios (from the Pettit-spec'd ratio of 1.46:1) in action and hearing of their effectiveness I am considering adding a second blower pulley to the kit. I just need to know if anybody really cares because my chosen tester and you, Rotr8, seem to be the only Pettit SC owners willing to engage conversation with me these days.
Sorry Ray I did not know you felt a little neglected. Here is a big (non ghey) one from me. :kiss:
Bastage
12-07-2008, 07:46 PM
:cuddle: We've all been extremely busy I guess. Here's another non-ghey one from me.
Kane
12-07-2008, 09:21 PM
Here IS a gay one... :kiss:
Rote8
12-07-2008, 10:39 PM
Yo, Ray.
Did I miss something about ignoring you?
Was there a memo? :icon_no2:
marsredr100
12-07-2008, 11:06 PM
Well people I only got up to 11.3 psi boost cuz I ran out of road and very hard to film and drive going that fast. The pull was done on fourth gear and sorry for the poor quality. :eyetwitch
http://www.youtube.com/watch?v=5DMthgPrmZM
marsredr100
12-07-2008, 11:15 PM
The first log shows when it hit 12 psi on 5th gear and the second shows 11.3 psi on 4th gear. :eyetwitch
shinka213
you know i still love ya Ray!!!.....
i am happy with my set up at present...focusing on another vehicle...lookin at some TRD stuff...:lol2:
perhaps we will be doing some business later on down the line?????
Moon Assad
12-07-2008, 11:54 PM
Awsome, bet shes a real ripper.
california style
12-08-2008, 04:10 AM
yeah from what MM said earlier in the thread when we were discussing MAFs etc, the OEM MAF is pegged at 369, and you are right on that now Juan..
PS also a friendly hug going out to Ray! :)
Rote8
12-08-2008, 04:22 AM
Uh, why is it sideways?
My neck hurts....
morkusyambo
12-08-2008, 08:09 AM
I am currently experimenting with the COBB AP/Racetuner software trying to get the MAF values nailed down. This will be of the utmost import in regards to tuning for the different sized ratios.
If I lived close to Cam, I would take him my car so he and Dian could make a decent tune with the EFI Dude. Alas, I don't, so i'll be doing this myself.
-Yambo
Rote8
12-08-2008, 08:41 AM
-Yambo
I spoke with Juan, he has 0 long term fuel trims.
Juan was working with Cam via emailing EFI log files.
morkusyambo
12-08-2008, 03:30 PM
I did as well several months ago. I have my own reasons for wanting to use the AP.
Rotr8
12-08-2008, 04:05 PM
Hey Denny what happened to your tips, tweaks and improvements thread,,, Its totally gone, did you delete it or did the mods delete it???:icon_no2: .....
olddragger
12-08-2008, 07:02 PM
Dont know?
yesterday Eric Meyer spent 2 hrs with us at his Road Atlanta set up (wicked flat black paint cars!) and we talked about brakes, suspension setup, engine air flow, cooling, fuel supply systems--especially fuel pressure issues, running without the mop, advantages and disadvantages of non return versus return fuel systems, lower intake variables, and the vdi--among other things!:Eyecrazy: He even gave us hats with the club name sewn it the side of it--divers talked with all of us, watched them working on the cars etc etc-- Eric is one class act--his entire team also was nothing but the best. Many thanks to you Sir, many thanks for taking time with the locals like you did. Most impressive.
Eric was interested in the amount of air we are moving and confirmed our thoughts/practices concerning the vdi. They do much more with the intake than we do--they want flow rates on the intake i have done.
After that the Roar racing team let us park beside them and as always Roar made us feel like family--we talked more about the cars and started to get into even more detail. Roar is like a brother too us and dont think we dont appreciate it.
Got a lot of confirmation about the direction of which I am heading in addressing fuel pressure/starvation issues. One word of caution---if you have a fuel cut issue--the engine does not like it--right? Well you can have a slight reduction in fuel pressure and not know it and lose about 40hp! We need to watch fp issues a little closer than we do.
Be careful with the blues(injectors) the spray pattern is much coarser(we know)--just be aware when you are tuning.
our man Nabil missed the TTD championship by 1 sec against a race prepared BMW with stripped interior, full roll cage, full race harness and so forth. Get the picture?. He turned a tad bit over a 1:44--which aint bad at all:), His 8 is basically stock, tomico shocks , rb bars, act flywheel and REVI intake and i think that is it!
he is running 17" tires with new r compounds for this event. His car has at least 8-9K track miles on it and I think over 70K---original engine--replaced trans x 1.
We are proud on him--did good.
Lots of stuff.
OD
G-ReX
12-08-2008, 08:52 PM
You need to display older threads (last year rather than last 100 days).
Rotr8
12-08-2008, 09:08 PM
Thanks Grex!!!
marsredr100
12-09-2008, 08:41 PM
juan,
beers :beer:[/QUOTE]
Dyno at Delirium on Saturday 8:00 AM and please bring your avatar girl along with you. :eyetwitch
Brettus
12-09-2008, 08:47 PM
OD
please elaborate
OD
what are you saying ? A small adjustment will make a big diff to AFR ?
MazdaManiac
12-09-2008, 08:55 PM
The "blues" have a spray pattern that is slightly more coarse than the "yellow" injectors.
It has little to no effect on AFR.
Brettus
12-09-2008, 09:05 PM
so that means you have to do what to dial them in ?
MazdaManiac
12-09-2008, 09:39 PM
Same thing as any other injector.
olddragger
12-10-2008, 11:29 AM
exactly--just a factor to keep in mind. Less atomization of the fuel can affect flame front etc. Probably will never be an issue for us but you never know..
Fuel pressures will become more and more important as we continue.
Eric was asking about flow results we have seen in regard to the vdi(i believe most of us disable that) as they too disable it. I dont want to devulge any of their propiertary secrets on the lower intake, but I will say that it is a stock intake, they just do differant things with it. Most of which would not suit us street guys. OK?
He was interested in my finding that the vdi even when closed is NOT sealed totally. He says that he has seen some which appear to be and some which definitly are not. It is much more easily recognized when boost is applied. I have a lower intake i have been messing around with in which I have toally sealed the vdi and ported/smoothed the upper ports of the lower intake(there are multiple ridges etc that can be removed etc) and I used the old funnel concept in continuing throughout the channels--also did a little bit of stuff on the sausages.
He would like to see it flow tested.
I can reveal that they run without an mop and use 1 1/2 oz's per gal of premix. And they pay strict attention to fuel filters.
It was an excellant day.
OD
olddragger
12-12-2008, 11:11 AM
i wonder why the electrical scematic is differant than the actual wiring concerning the coils? The scematic has the trigger wire located in the middle of the connector but the actual site is the right handed side. Curious.
anybody out there??
OD
MazdaManiac
12-12-2008, 02:55 PM
anybody out there??
OD
Huh? No it doesn't.
http://www.rx8club.com/attachment.php?attachmentid=130326&stc=1&d=1229111706
dannobre
12-12-2008, 02:58 PM
Denny: Got to look at the plug diagrams to figure it out :)
MazdaManiac
12-12-2008, 03:10 PM
<singing>
"A, B, C, D, E, F, G."
</singing>
olddragger
12-12-2008, 03:39 PM
wait a min---the scematic has the trigger wire color coded y/g (for example) has the pin in the middle of the connector--correct? In acutally on the 2 harness's I have worked with that wire the y/g one is on a pin on the side of that connector--not in the middle. Further more the solid black wire(ground) in these hareness's is in the middle of that connector. On the schematic it is shown as being on the side.
I am talking about the diagram in the schematic that has all four coils shown in a group. I know it is differant in the individual pictures of each coil connector.
got yall's attention?
Olddragger
MazdaManiac
12-12-2008, 04:19 PM
No. You are misreading the schematic.
MazdaManiac
12-12-2008, 06:13 PM
I think the problem is OD is reading the schematic as if it were a diagram.
The order of the coil connector wires is shown as "C - A - B" in the schematic for clarity, even though the actual connector is "A - B - C".
That is how schematics work. They aren't a physical representation of the layout of components. Rather, they are a sort of "flow chart" that explains the movement of electrons in the clearest fashion possible, without regards to the configuration of the hardware.
dannobre
12-12-2008, 06:18 PM
^^ Yup...Mazda especially tends to put things in the easiest way to read/draw layout...not in the actual plug layout...that's why they put the plug diagrams on as well
dannobre
12-12-2008, 06:20 PM
Yes. Electrical engineers have far different objectives than do mechanics, technicians, and assemblers, and they communicate differently.
And they like screwing with them as much as possible too :lol:
dannobre
12-12-2008, 06:35 PM
Porn works with both ;)
MazdaManiac
12-12-2008, 06:54 PM
Yes. The great communications equalizer!
olddragger
12-12-2008, 10:39 PM
well learn something everyday--frigging world is screwed up--we all need to speak in the same language if we want to communicate---like PORN is porn is porn.
Wait a minute I seem to remember seeing something about donkeys once---nope that aint porn to me!
Need another example. Maybe----???
OD
Rote8
12-13-2008, 05:37 AM
OD
Donkey? (http://topratings.files.wordpress.com/2007/08/donkey-pulling-cart.jpg)
:uhh:
JMKuco
12-13-2008, 10:06 AM
Hi every one,
just happy to ay that I ordered yesterday a petit racing supercharger :)
can't wait ti install it :lol:
Bastage
12-13-2008, 01:11 PM
Hi every one,
Congratulations man, you will not be disappointed. Welcome to the addiction.
BTW, met up with Juan this morning at Delirium Motorsports.... it was... fun... :eyetwitch :Eyecrazy:
More details and videos/pictures to come...
marsredr100
12-13-2008, 01:28 PM
Well guys and girls I took the car this morning for a dyno test after my last mods. Everything looked promising to brake the 400 whp but to my and Bastage disappointment my car was only able to achieve 327 whp on the first pull and 330 whp on the second. I think all the time spent researching and mods trials did not come to fruition. I’m contemplating listing the car on eBay…NOT! :wiggle:
Many thanks to:
Delirium-Motorsports Dyno
2828 Michigan Ave.
Kissimmee, Fl 34744
321-286-6641
:eyetwitch
Brettus
12-13-2008, 01:33 PM
great result - going to post it up ?
Moon Assad
12-13-2008, 01:45 PM
Hell yeh, thats what im talkin about
Moon Assad
12-13-2008, 01:47 PM
I see you throttled down at 8300, why didnt you hit redline????
marsredr100
12-13-2008, 01:56 PM
Didn't want to risk it for a couple of more whp. I'm an hour away/50 miles from the dyno location. :eyetwitch
Moon Assad
12-13-2008, 02:00 PM
It looks like your stepping into a sick power band.
Brettus
12-13-2008, 02:13 PM
what psi were you at ?
marsredr100
12-13-2008, 02:25 PM
http://www.youtube.com/watch?v=Jk99SuPrCp8
http://www.youtube.com/watch?v=mtINFMTOUdY
9.6 psi on 3rd gear dyno.
11.3 psi on 4th gear on the highway.
12 psi on 5th gear on the highway. :eyetwitch
Brettus
12-13-2008, 03:32 PM
i'll ask ... Why does the psi go up with each gear ?
shinka213
12-13-2008, 03:38 PM
very nice Juan!!!!.....
:D:
mysql
12-13-2008, 03:41 PM
congrats. Once you break 330, you won't want to go back under 300.
marsredr100
12-13-2008, 04:07 PM
Thanks :eyetwitch
marsredr100
12-13-2008, 04:09 PM
:D:
Thanks...ready to update yours? :eyetwitch
Bastage
12-13-2008, 05:42 PM
Why did you then? :eyetwitch
mysql
12-13-2008, 05:48 PM
Not by choice. I was going to sell the car.
Getting ready to go top mount turbo shortly. Just bought the intercooler last night :)
california style
good job!
That must be pretty crazy to drive!
Bastage
12-13-2008, 06:12 PM
good job!
I drove it after the dyno... just have to say wow.
My car will be this crazy soon.
Bastage
12-13-2008, 06:16 PM
some pictures:
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0002.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0011.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0017-1.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0031-1.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0061.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/DSC_0063.jpg
Moon Assad
12-13-2008, 07:05 PM
The slower the acceleration the less air the engine excepts.
Moon Assad
12-13-2008, 07:23 PM
Tell you what I found from experiance with this kit on my car, I bumped the redline to 8500 from 7500, it made it a whole new animal. Thats with the smaller ports on the auto. You look like your just tapping that same powerband like I had from 7,000 to 8,500 except your RPM tune is higher port wise. You see how your TQ jumps at that same RPM, its comming on like a 2 stroke but better. Kinda like a periff port likes 8,000 plus. Im not telling you to do it but if conditions ar correct it might come on like this
http://www.youtube.com/watch?v=E2ung98buGc
.06 and .11 secounds into the video gotta do your motor though.
rx8thunder
12-13-2008, 07:54 PM
Many thanks to:
2828 Michigan Ave.
Kissimmee, Fl 34744
321-286-6641
:eyetwitch
That's an awesome result!
Bastage
12-13-2008, 08:05 PM
Vid of his car's 327 rwhp run:
http://www.youtube.com/watch?v=sx5QQ6V7hMM
and my car's 281 rwhp run:
http://www.youtube.com/watch?v=ve6Bxz1mpuw
Totally...
http://i212.photobucket.com/albums/cc7/bastage_2005/juanhp.jpg
http://i212.photobucket.com/albums/cc7/bastage_2005/juantorque.jpg
Kane
12-13-2008, 08:07 PM
Nice - really really nice.
Moon Assad
12-13-2008, 09:10 PM
Guess its time to get off your sas and change this
http://www.rx8club.com/showthread.php?t=132628&highlight=dyno
Kane
12-13-2008, 09:11 PM
Me? That isn't my thread.
mysql
12-13-2008, 09:12 PM
need to post the dyno jet files, or start converting the x axis to rpm like everyone else does.
Moon Assad
12-13-2008, 09:17 PM
Wasnt talkin about you. Thread jack, youve been around the block and had a chance to dive ALOT. If you were gona go free diving were would you go to kill a BIG 100 + pound fish??
Moon Assad
12-13-2008, 09:19 PM
Not talking hammer head in Pearl either.
Kane
12-13-2008, 09:20 PM
Free Diving... for something that big; here is my list.
1 - Ryuku Islands; Okinawa etc. I have seen Volkswagon sized grouper down past 100 FSW
2 - Kwajalien; Marshall Islands
3 - Palau
4 - Hawaii; can be done; but kind of rare here.
Allof these spots assume the right gun and a 3+ minute breath hold.
Moon Assad
12-13-2008, 09:27 PM
Working on the breathholds, 1.5 sofar, had 3 min. in the day. Got the equipment, 6.5 ft omar with real and a big knife when it gets close. Got big boat bumper to let him drag around also.
Moon Assad
12-13-2008, 09:47 PM
Sold
http://picasaweb.google.com/timschimpf/HighlightsFromPalau#5145462488814487122
Rotr8
12-13-2008, 09:55 PM
very nice pulls guys...
I hhad a little problem today going to my parents house for a funeral... So I come around a bend of the highway Im on, knowing where the cops would sit if there were any and hoping traffice was all clear, and both of those wishes were granted, so I decide to run it,,, built from about 73mph and eased into it in fifth gear,,, so the mphs start to climb and shes pulling real smooth everythin looks and sounds as expected, then,,,, ka-blamo hit 119mph and something went,,, real loud noise, and my boost gauge fucking pegged at 15lbs, with all the warning lights(of the gauge that is, no CELS),,, totally scared the shit out of me, swalled my heart in my throat and eased off immediately...
Have no idea what happened, and spent the rest of the ride out of boost.... After the funeral I started to test boost and finally built enough courage to ease into the 6-7lb range,,, nothing sounded outta wack or felt no sign of a problem ,,, anyone want to take a stab at it...
Ohh and here are two screen shot from the ride,,, first image hit 332g/s(real strong second gear pull) and the second is from the high speed incident....
Please,,, if anyone has any insight to what may have happened please suggest something....
olddragger
12-13-2008, 11:20 PM
Oh boy:)
New plugs gaped at 45 will give you another 10hp/
still running the same nozzles(w/m)?
like THAT TQ CURVE!!
Love that engine tq damper
OD
olddragger
12-13-2008, 11:32 PM
sounds like a big fart. so many things it could have been
you were in the danger zone --where the intake is opening valves etc--do you have the w/m system going--cant remember?
glad you /car are ok.
OD
MazdaManiac
12-14-2008, 12:30 AM
You wanna try explaining that one? (I presume you meant "accepts".)
The slower the rate of engine acceleration, the more air it will ingest.
That is one of the reasons motors make their most power in higher gears.
That thread is for base kit results. It is intended to show "out-of-the-box" results, not optimized examples.
Otherwise, the comparo would be worthless (and quickly get out of control). Water/meth and smaller pulleys exempt the results.
Can you imagine the mayhem that would result if I posted one of the maxed-out dynos from the MM system?
, then,,,, ka-blamo hit 119mph and something went,,, real loud noise, and my boost gauge fucking pegged at 15lbs, with all the warning lights(of the gauge that is, no CELS),,,the second is from the high speed incident
Were you spraying W/M and, if so, what are your mix ratios?
Your load was fairly low (~130%) for such a rich AF, too.
You need to have your 5/6 fuel table tuned.
paulmasoner
12-14-2008, 01:06 AM
/threadjack
Pearl is the Tiger's breeding ground mostly. Plus you'll get arrested if caught in those waters :) Hammers are in Kaneohe Bay.
I've seen some big Ulua(i think ulua is grouper?) on the west coast of Oahu when i used to skin dive a lot. couple miles north of the power plant at Tracks beach park. I've seen the HI Skin Diver guys out there a time or two, that should mean something. Also if you do have the balls to get into deeper waters in K-bay, there are a lot of BIG fish in there(so the old locals told me).
If you ever do get to the islands and serisouly want to fish, get in touch. Couple of locals i worked with out there grew up diving on the north shore of oahu, and a bit on kaui/maui. They know ALL the spots.
Brettus
12-14-2008, 02:18 AM
yes - it would be like a panic scene from a hollywood spoof movie ....
MazdaManiac
12-14-2008, 02:35 AM
http://www.benkepple.com/Images/riot.jpg
Brettus
12-14-2008, 02:45 AM
i was thinking of the one where a naked woman with large boobies jumps up and its jelly on a plate time .
But yeah
california style
12-14-2008, 05:03 AM
haha, the airplane panic scenes were alwys classic. Mind you the forum flameathonss here can sometimes require the "face slapping,'calm down!'" airplane scenes as well.
Rote8
12-14-2008, 05:47 AM
So, we are told "Post results and it will be changed".
When the results are posted, these are called "maxed out" despite the fact that all S/C components are from Pettit Racing. Cam is just very conservative with customer's engines.
On another note:
"Can you imagine the mayhem that would result if I posted one of the maxed-out dynos from the MM system?"
Are you claiming you are not charting maxed out turbos?:dunno:
I wonder if any other dyno results on that page are low balled? :nono:
You are currently making a baseless claim that the results on your chart are not a "maxed out turbo"; show us some "maxed out" DynoJet dyno sheets proving what YOU are claiming or we will have to consider the chart irrelevant.
Rote8
12-14-2008, 05:59 AM
I had a little problem today going to my parents house for a funeral... So I come around a bend of the highway I'm on, knowing where the cops would sit if there were any and hoping traffic was all clear, and both of those wishes were granted, so I decide to run it,,, built from about 73mph and eased into it in fifth gear,,, so the mph start to climb and she's pulling real smooth everything looks and sounds as expected, then,,,, ka-blamo hit 119mph and something went,,, real loud noise, and my boost gauge fucking pegged at 15lbs, with all the warning lights(of the gauge that is, no CELS),,, totally scared the shit out of me, swallowed my heart in my throat and eased off immediately...
Maybe the extra two ports did not open, or opened incorrectly? (or suddenly closed)
:banghead:
If you have a methanol kit, check for a possible siphon dumping too much water/meth in before the S/C. (water takes space, and practically doesn't compress)
Is your boost gauge digital or the old school vacuum line? (alternator issue if digital gauge?)
Flashwing
12-14-2008, 06:15 AM
Rote, I'll try and address your questions since I think the thread in question is very important to anyone looking to purchase an FI upgrade to the RX8.
It's important to understand the difference between dyno numbers produced by the kit "as is" from the manufacturer and dyno numbers produced by a kit plus other custom installed parts such as boost controllers, water/meth, gauges, etc. T
The idea is to show how a kit performs right out of the box. The dynographs listed in the comparison thread were provided from customers who installed the kit and had dyno numbers to display. I don't know what modifications in addition to the supercharger that Mars has on his car, but I image it's more than what came with the Pettit kit itself.
I won't play the "if you only knew what I knew" game with the MM/BHR Turbo kit but I will say that the dyno sheet listed for that turbo can easily be reproduced on any RX8 we install it in. Any power gains beyond that are due to custom installs by the customer.
The hope is to have a dyno chart showing power results should the kit in question be installed on any RX8 and produce the same results without any additional modification. Any power gains beyond what's listed should be considered a "plus" or "bonus" and not an expected result.
I'm sure that a "maxed out" comparison thread could be made but I'm positve the results would shock people and no doubt there would be a lot of bickering and claims the data provided was false.
I hope that addresses your concerns.
mysql
12-14-2008, 06:51 AM
Jeff's 3071R is extremely conservative. It's like the SC guys running 4 psi of boost.
What might make things interesting is if someone takes control of a "max dyno charts" thread and pulls the max gains we've seen for each kit. No one said Jeff has a monopoly on creating charts.
I used to do it, but it's a PITA to keep up to date.
This could be a good thing, cause the current dyno on the GReddy turbo kit should be replaced with a more typical 7-9 psi run.
MazdaManiac
12-14-2008, 08:23 AM
Try reading a bit:
- The base cost for what the kit costs new and ready to run (this means with fuel management).
To make things somewhat fair, the price must be the lowest price the kit can be bought for new, and functional. This means fuel management must be included in the price tag. Extras like boost controller, gauges, sensors, etc. are all custom for your install, as is install cost.
On another note:
The chart in the Dyno Comparison for the MM upgrade is just that - the GReddy system plus the upgrade.
What I have taken that system to is way beyond what is posted.
I doubt anyone "low-balled" their chart. The MM chart shown was pretty well tuned to acheive that result. It just didn't inclued an optional equipment.
marsredr100
12-14-2008, 08:40 AM
Here is my 330 whp formula for the record:
1. Pettit Racing SC Kit with the 5 inch crank pulley (that is the only mod to the kit out of the box). The stock kit comes with a 4.5 inch crank pulley.
2. I’m using the stock ECU flash that came with the kit (it can be improved but I like to see 11.6~11.8 AF ratios at max whp rather than lean it and risk catastrophic detonation). Sorry, my personal choice and anything just past 300 whp is fine for me.
3. 440cc (blue) injectors for secondary instead of the 380cc (yellow) injectors with the stock OEM fuel pump.
4. ExoticSpeed header, Racing Beat Race Pipe and Racing Beat Exhaust.
5. Racing Beat Aluminum Light Flywheel with Exedy Stage 1 clutch.
6. Snow Performance water methanol system pumping 50/50 VP Racing M-5 methanol (100m/l before the blower and 60m/l after the intercooler).
7. MSDs LS2 8247 Multiple Spark ignition coils, MSD Super Conductor ignition wires and NGKs Racing 10.5 leading 11.5 trailing gapped at .035 Yes, you cap gap these plugs but not the OEM RX8. The ground electrode on the NGK Racing plugs are imbedded/welded into the plug body and not tacked welded on top like the ones on the OEM RX8 plugs.
The best part is that my car can sit in my garage for weeks and all I have to do is get in, start the engine, let it warm up and drive (have fun with it). No worries, no fuzz, spank some ricers along the way and best of all excellent customer support from Pettit Racing the owner himself practically any time of the week. :eyetwitch
MazdaManiac
12-14-2008, 09:46 AM
Mars -
Do you actually have the blues in the secondary position?
You do know why they need to be in the P2 position, right?
11.8:1 AFR is perfectly fine. There is a little more power to be had at 12.3:1 (especially with the W/M where the sky is the limit), but not a ton.
The car will drive better with 12.x:1 off of the torque peak at WOT.
marsredr100
12-14-2008, 11:06 AM
Mars -
Yes, both ends (left/right) of the fuel rail.
Yes
:eyetwitch
Moon Assad
12-14-2008, 11:28 AM
Mars -
Havent you been saying somthing different for years on the AF, I think you even started arguments about how 12 is to lean, I think you stated 10.5 or 11 or somthing in that area. Tripping over your own feet arnt ya.
Rotr8
12-14-2008, 11:43 AM
No W/M,,,
why would the load be much higher with the gradually acceleration?
agree about a more refined tune,,, getting the AP very soon and a reputable local tuning shop is acquiring the protuner software for the 8 this month so I will be able to work out all these hik-ups, hopefully,,,
:banghead:
doesn't compress)
Old school mechanical boost/vac gauge thats measuring off the LIM....
Would the rear tires coming off the ground lead to soething like this,,, I drove over a bridge divider, may have broken loose for a second.
Also my RP supercat is at the point of expected(reported) life expectancy I currently have 15K mles on it, will be swapping a new one in hopefully tomorrow thanks to Swoope:)
Moon Assad
12-14-2008, 11:54 AM
/threadjack
Yeh, didnt get arrested when we were jumping from 5 storys up off the boat. Our 1st segt did confine us to the boat for the weekend though :banghead: kinda thought somthing was gona happen when I saw him standing on the lower deck on the way down. Gave us a chance to do some fishing, more baby bonnet heads then I ever saw, I think we cought 50 between all involved that evening. Then the next day the Seals were running there mini sub following a 8ft hammer head, no will to swim in the pearl again.
marsredr100
12-14-2008, 12:31 PM
Picture me saying this with a thick redneck accent: Well Bern, here is your problem! :eyetwitch
Also, be careful with swoope’s advice/parts cuz I went to my local AutoZone store looking for that wobbly tool he referenced to a while back and I almost got tossed out of the store. :rollingla
Brettus
12-14-2008, 01:54 PM
agree 100% on that - the Greddy chart is definately not an "out of the box" result - it is a maxed out result .
mars - you should start another thread with your dyno as the first post so this does not get lost over time . It is an impressive result - I can't understand why it has taken so long for someone to get there though ....
Rotr8
12-14-2008, 02:18 PM
He as well as others have already done this, in our own section mind you, until they were all shut down or locked becuase haters shitting in the threads...
Rotr8
12-14-2008, 02:21 PM
Should have recieved it yesterday, so I guess I'll get it tomorrow....
Kane
12-14-2008, 02:53 PM
Sold
Do jellyfish lake while there... swimming in a sea of fake boobies....
Moon Assad
12-14-2008, 05:00 PM
No jellyfish for me :Eyecrazy: I was floating around roosavelt roads, I probly spelled that wrong but anyway I swam into a shallow cove and notice this cool plant life, it looked like colie flower, turned out it was upside down jellyfish 2 foot off my wetsuit. :eek:
Kane
12-14-2008, 05:07 PM
They don't sting you big girl! ;)
Moon Assad
12-14-2008, 05:18 PM
If they dont sting, cool but that kinda thing classifies in the group of turning around and looking eye to eye with a 850 pound manitee, you now it harmless but holy crap. Also in that classification would be
http://picasaweb.google.com/timschimpf/HighlightsFromPalau#5145453735671137090
Man VS beast and no fishing pole between you and it just 1 shot of your spear gun, the bigger the better.
Kane
12-14-2008, 05:20 PM
Multiply that times 80 or so... and that would be Kwajalien...never seen so many sharks in my life.
marsredr100
12-14-2008, 05:40 PM
If you guys keep talking about big smelly fish I’m gonna have to call the wife and have her serve me a nice seafood paella when I get back to the bedroom. :eyetwitch
Bastage
12-14-2008, 08:07 PM
:lol2:
MazdaManiac
12-14-2008, 11:26 PM
Reading comprehension is not your thing is it? Apparently, spelling, grammar, punctuation and not breathing through your mouth are equally difficult.
Of course, I understand that you don't have any idea what you are talking about - let alone suggesting that you know what I am talking about.
But I'll offer you these for some bathroom reading (don't take your 15" VGA monitor in the bathroom with you!):
http://www.rx8club.com/showpost.php?p=1556991&postcount=9
http://www.rx8club.com/showpost.php?p=1558045&postcount=13
http://www.rx8club.com/showpost.php?p=2578744&postcount=17
etc...
In some scenarios, 12.3:1 is actually too lean, BTW.
But you have to understand a whole bunch of big words and and scary numbers to have a discussion with the adults about the subject and I wouldn't want to distract you from the quality time you spend with your navel.
Mars -
Uh, that is the secondary position.
The Primary 2 are the inside of that rail. They spray into the primary intake tracts. The injectors on the "ends" are the secondaries.
http://www.rx8club.com/showthread.php?t=150432
Yes
Apparently not.
If you put what are essentially your "auxiliary" injectors in the secondary intake tract, they are unavailable for the first 3800 RPM at a minimum.
On a supercharged car which, purportedly, will achieve full boost at any RPM, not having your main auxiliary fuel delivery available until nearly half-way through the RPM band would be a bad thing.
Hymee
12-15-2008, 06:02 AM
Main auxiliaries... God bless us!
Actually, I beg to differ with part of that argument though. If the "fuel system" is adequate at 100% load at full RPM, then in theory it would be OK at 200% load at 1/2 RPM, within reason. But yes, the second 1/2 of the RPM band would be problematic though!
Cheers,
Hymee.
Flashwing
12-15-2008, 06:24 AM
So THAT'S what I have been doing wrong this whole time. I even set up a table with an extension cord and everything! :lol:
marsredr100
12-15-2008, 08:56 AM
Apparently not.
Negative Ghost Rider. I placed the 440 injectors in the right position. I suggest you figure out why. I placed them at the ends of the fuel rail not because I know any better but because I get most of my advice from people that will not dare to chime in this circus style forum. People that have nothing to prove because their reputation and knowledge goes without saying. Basically, very humble, willing to help and most of all non-ego mongers wanna be like you. Also, before anyone out there (fanboyz) start flinging arrows, this is not about SC vs Turbo crap. In fact, I will be replacing my current R100 bridge ported 13B engine to a twin turbo 13B engine in the near future.
Jeff, the bottom line is that I have nothing to prove on this forum but to show people what works and what doesn’t by using and abusing my car while sharing facts (without blowing my engine). I don’t depend or need this forum to make a living. I’m already retired from one federal job and working on a second federal retirement. My real job is devoted to keep bad people from introducing explosives to commercial aircrafts, which is far more important than playing around with a car.
May I suggest bringing a second extension cord and join moon with his bathroom reading. Although be aware that moon likes to talk about big smelly fish. :eyetwitch
MazdaManiac
12-15-2008, 11:55 AM
If you (and quite a few other people on your side of the gymnasium) would be less concerned with my "ego" and more concerned with facts and genuinely understanding this stuff instead of just playing parrot, you would be less likely to fall victim to this sort of nonsense from your "awe-shucks" oracle.
Its your car - do what ever you like.
But don't pretend that you have great insight into any of the whys and hows of this stuff just because someone told you so.
Lol. Yes. Semantic gaffe. Made me chuckle as well. I'll leave it for posterity.
I'll state it again in as simple terms as I can so that other readers who are NOT concerned with my motives or attitude will have the correct information:
There are three paths for air to follow into the 6-port motor.
The primary, the secondary and the auxiliary.
There are fuel injectors mounted in the primary (the P and P2) and the secondary (S).
The primary air path is always open.
The secondaries are behind butterflies that only open after 3800 RPM at a minimum.
So, fuel provided by those secondary injectors is not available to the motor until after this point.
zoom44
12-15-2008, 12:06 PM
didn't we all agree along time ago to call it the Tertiary? why do we keep falling back to auxiliary.
And Jeff that trashing of Moon was completely unnecessary. Dial it back please.
MazdaManiac
12-15-2008, 12:17 PM
Old habits.
Perpetually pumping this thread full of misinformation and outright lies is completely unnecessary.
These poor people have been misled enough already.
marsredr100
12-15-2008, 12:32 PM
Jeff, don't be hate-ing! :eyetwitch
Enjoy the video http://www.youtube.com/watch?v=sx5QQ6V7hMM
Bastage
12-15-2008, 12:35 PM
Old habits.
I totally agree with you. Mods, can you just ban him from the Pettit threads already? Things were so much nicer here while he was gone.
MazdaManiac
12-15-2008, 01:03 PM
:lol: At least you used a hyphen.
Uh, OK. Maybe you could chroma-key some scenery going by or something to jazz it up. You should at least tack on a pic of the dyno sheet or something for a money-shot.
Or, you could watch a car making more power (http://www.youtube.com/watch?v=0VA54JB4_V8) actually going somewhere.
1) I've never been "gone" from this thread.
2) I guess things are nicer when you have your head in the sand.
Bastage
12-15-2008, 01:15 PM
At least here, I know you're at least trying to speak from experience... but if there's truth to it, then I'd still be on your ignore list, right? :lol2:
What is this now, round 15?
Moon Assad
12-15-2008, 02:52 PM
No dufas, you forgot somthing, if its a 6 port you have 6 intake and 4 exhaust, on a 4 port you have 4 intake and 4 exhaust. You for got to multiply by 2 for 2 rotors 3 ports a rotor.
are stages that feed each port times 2 again
or you car wouldnt run!!!!!!!
Butterflies, look jeeniass, the only butterfly involved in the intake system is your throttle body, your talking about barrel and shutter valves, excuse the spelling.
So, fuel provided by those secondary injectors is not available to the motor until after this point.[/QUOTE] Or it would just puddle up at that point, it might make it into your combustion chamber but not as an atomized gas, are we done yet??????????????????????????????????????????????? ???????????????????????????????????
How many ports can a single rotor renissis have???
Moon Assad
12-15-2008, 02:55 PM
Enjoy the video http://www.youtube.com/watch?v=sx5QQ6V7hMM[/QUOTE]
Hasnt blown a motor yet cause he plays buy the rules Jeff. Not Jeffs rules.
MazdaManiac
12-15-2008, 03:22 PM
He hasn't blown a motor because he hasn't tried to push it as far or as hard.
And, if you could actually comprehend what you are reading, you would know the difference.
Really, do you honestly have a hard time connecting the dots?
Do you think that everybody doesn't understand the idea that each rotor has its on copy of the ports?
Yes, there are two primary ports, each with two injectors and two secondary ports, each with one injector. And a "tertiary" or "auxiliary" port for each rotor that contains no injectors.
I didn't think that needed to be spelled out.
Did you really believe that I was asserting as well that the motor only had three injectors total?
No, I took you off.
I was, apparently, missing too much fun stuff, so I removed you from the list (of which you were the only member) at the suggestion of several other people on the board.
Moon Assad
12-15-2008, 03:26 PM
Stilll havent answered my ?? how many ports will a single rotor rennissis have?????
Moon Assad
12-15-2008, 03:28 PM
Still waiting for a number???
Moon Assad
12-15-2008, 03:30 PM
Ok, sorry to tie up your head, 4,5,or 6.
MazdaManiac
12-15-2008, 03:49 PM
WTF is a single rotor Renesis? Why would you even bother?
Who the f*ck cares?
We are not even talking about the motor. All we are discussing is the intake manifold. What are you going to do, saw one in half?
Jedi54
12-15-2008, 03:53 PM
it's times like this I (kind of) wish I had a Pettit Supercharger so I could have a legitimate reason for posting but I don't, so I will just ask that someone pass the popcorn.
:fruit:
mysql
12-15-2008, 03:54 PM
Jeff, how many fingers am I holding up? 3, 6 or 8?
also what color underwear is Moon going to wear on Thursday next week?
mysql
12-15-2008, 03:56 PM
Jeff, you haven't answered me. The answer is either: Boxers, briefs, au natural, or granny panties.
Damn it man. Get with the program! We all know color=type.
dannobre
12-15-2008, 03:59 PM
I love this thread..I come here when I'm bored ;)
Always good info floating around under all the crap though :lol:
chickenwafer
12-15-2008, 04:01 PM
boy shorts
mysql
12-15-2008, 04:02 PM
boy shorts
That's not a color. And you didn't specify if he put them on backwards, frontwards, or upside down.
Moon Assad
12-15-2008, 04:23 PM
Who the f*ck cares?
Well, you can mix and match auto/manual engine parts to get different outcomes on a single rotor motor and a single rotor wont push your car around very well, the reason I mentioned it is im pretty sure its gona make this fun to drive especialy with a blower
http://www.rx8club.com/showthread.php?p=2759529&posted=1#post2759529
Guess all the people watching care atleast.
TheWulf
12-15-2008, 04:29 PM
Oh no, we don't. We're just here to be entertained.
*hands out popcorn*
Moon Assad
12-15-2008, 04:32 PM
Yeh, I find it amusing at times myself. It pisses away a few hours a day and gives me a chance to hold down the couch.
MazdaManiac
12-15-2008, 05:24 PM
OK. Now THAT'S the spirit! lol
Good stuff, Moon!
Mazurfer
12-15-2008, 09:05 PM
Well now................haven't been in this thread for months, and I suddenly realize why I don't come in here much anymore. Too difficult to find any good info between all the crap.
"G", saw you pulled like 281rwhp and Juan was right about 330rwhp.
Is the only difference the larger pulley and injectors he's running.
olddragger
12-15-2008, 09:10 PM
Jeff--seriously, what the hell are you doing?
Remember-- if someone comes to give you a gift and you do not receive it-- to whom does the gift belong?
olddragger
MazdaManiac
12-16-2008, 12:45 AM
You're kidding, right? Do you read what gets said in here, or just have a knee-jerk reaction to how its said?
I have NO idea how that is a relevant parable in the context that you are suggesting it, but the gift always belongs to the recipient or it wasn't a gift.
Why do you think I even bother to help you people?
For the most part, this thread is rife with ignorance and ingratitude.
The level to which folks here will drop to belittle the messenger to diminish the message is simply impossible to believe.
I have nothing to gain here. None of the participants in this thread are gonna buy anything I'm selling - literally or figuratively.
If anyone here really believes I contribute here to bolster my ego, you need only look how I'm treated here to dispel that misconception.
Even the few here that have directly benefited from the things I've contributed are required to treat me as a pariah as to not lose their cool-dude status in this tiny, tiny clique.
So, sit there and contemplate to whom this gift does belong and why its given.
Hymee
12-16-2008, 06:01 AM
As Jeremy Clarkson would say...
"Anyhow..."
MazdaManiac
12-16-2008, 06:06 AM
"And on that bombshell, GOOD NIGHT!"
Bastage
12-16-2008, 07:16 AM
Juan also has headers, but most of that power increase was from the 5" pulley and the bigger injectors.
marsredr100
12-16-2008, 08:27 AM
And don’t forget to mention that I spent the previous night at a Holiday Inn Express. :eyetwitch
olddragger
12-16-2008, 11:53 AM
and it seems that help could be offered without personnel attacks IF that person who is offering help really wants people to listen to what they have to say.
I always like to remember that there usually is more than one way of doing things and "best" is relative.
Learning to dicuss something without insults/aggressive remarks is the only way any"teacher" will get a point across and remember the teacher is not above learning themselves. If they think they are then they are already antiquated. (yes I know I dont spell everything correctly).
Jeff if you didnt understand the relavance of my para then you need to think about it some more.
Enough, I am done.
olddragger
MazdaManiac
12-16-2008, 01:34 PM
Its interesting to me that the perception here is that:
1) I am the one starting the insults and personal attacks; and
2) That the only people I am trying to help are the nimrods that are so vocal in this thread.
Remember - for every big-mouthed, cretinous fanbois here, there are (and will be) two that are out there absorbing this stuff and doing their own thinking.
I think the idea that I am the one starting these exchanges stems from the fact that I am so superior at it that the original post is eclipsed. :lol:
But I suggest that you look at any of my most "offensive" posts, back up a few posts and see who and what actually started it.
Ultimately, I love this sort of stuff because its funny.
Brettus
12-16-2008, 02:08 PM
this is true - having been the target for your sarcasim in the past made me realise I just need to chill out and concentrate on the discussion at hand . I realised this is how you disarm your opponent .
Some of the guys in this thread need to realise this as well ....
MazdaManiac
12-16-2008, 02:20 PM
Yes!
You know, I think the problem is that none of the folks in this thread have ever been the guest of honor at a good, old fashioned, New York-style roast.
Hymee
12-16-2008, 02:34 PM
Yes!
So what would one of those be in terms that make sense to me?
Cheers,
Hymee.
Bastage
12-16-2008, 03:08 PM
Cheers,
Hymee.
A NY style roast is when a bunch of people get together to celebrate someone else's life or career by poking fun at them. The problem with his analogy is that the people doing the roasting are liked and respected by the roastee, and the roastee gets to roast back in the end without the roasters crying like little girls and putting him on their ignore list.
It's pretty arrogant to think that we would care to put up with a bunch of BS to get a !@#$ing breadcrumb of opinionated information from someone that we can get from someone else sans BS.
Anyway, here's what is important. We're making even more power safely with our supercharger setup:
marsredr100
12-16-2008, 03:57 PM
Also, don’t forget to add over 10,000 miles since self-install of the kit, countless autocross events, several sustained 130+ mph sprints and on the original engine. :eyetwitch
Bastage
12-16-2008, 04:06 PM
:lol2:
I have ~16,400 supercharged miles, a dozen or so autocross events, and a few dragrace events, but I've only had a few sustained 120+mph sprints :eyetwitch
Also still on the original engine, still running as strong as ever, and it still brings a smile to my face every time I turn the key or mash the accelerator. Once I get the pulley and those injectors I'm going to need a muscle relaxant for my face.
marsredr100
12-16-2008, 05:24 PM
The continuance is noted by all who read.
Not really Ray. However, allow me to savior my personal achievement. Sorry it doesn’t set too well with the rest of the peanut gallery. :eyetwitch
http://www.youtube.com/watch?v=Jk99SuPrCp8&feature=related
Bastage
12-16-2008, 05:36 PM
I will warn you guys that we didn't include any ghey music or effects in our videos, so viewers beware:
http://www.youtube.com/watch?v=xjr_1TvvSoU
http://www.youtube.com/watch?v=zVs2YnppnKg&NR=1
http://www.youtube.com/watch?v=0K-xzxDpNb8
http://www.youtube.com/watch?v=hbID0DXLVJg
http://www.youtube.com/watch?v=2iU3LCgGV4o
http://www.youtube.com/watch?v=T6oy9s1BZcc
http://www.youtube.com/watch?v=n4B4i1CGKNA
http://www.youtube.com/watch?v=F9hgnT4A2W0
http://www.youtube.com/watch?v=MCV-60Zzs6I
http://www.youtube.com/watch?v=L8PFQZGn71M
http://www.youtube.com/watch?v=NEubwwsXhmE
Moon Assad
12-16-2008, 06:53 PM
Also dont forget to include this, LOL.
http://i212.photobucket.com/albums/cc7/bastage_2005/Pages1and2.jpg
olddragger
12-16-2008, 08:13 PM
and dont forget i have --so far over 500 hundred miles on the track (more to come)with engine temps no hotter than 180-190F, and 10 mpg while doing it.(love the tq)
OD
Jedi54
12-16-2008, 08:23 PM
OD: did you get your temps back up? I remember for a while they were too low.
olddragger
12-16-2008, 08:40 PM
yea--did--i reinstalled the oem thermostat and just ran the secondary radiator--warms up great now-- even on 27F mornings! So far so good,
Jeff--I would just like to point out that most of the content of my posts did not mention any specific name--it is generic in design.
Backing up a few posts I can see some of what you said.
I got to stop being so damn serious. Frigging old brain. Time to suck fish oil
OD
MazdaManiac
12-16-2008, 08:55 PM
Mmmm. Fish oil.
tubingchamp
12-16-2008, 09:14 PM
Most likely the route I'm going to take next year.
(not the fish oil, I already get enough of that)
rx8thunder
12-16-2008, 11:24 PM
Amen... stoked about this result!
Brettus
12-17-2008, 12:49 AM
hey guys - check out this dyno !!!!!
MazdaManiac
12-17-2008, 03:10 AM
lol :spank:
marsredr100
12-17-2008, 07:20 AM
lol :spank:
Wait, wait, wait…don’t forget the video that comes along with it.
100% satisfaction guaranteed and a sour taste on wannabes. :eyetwitch
MazdaManiac
12-17-2008, 07:42 AM
You mean like this one?
or this one?
http://www.youtube.com/watch?v=uzwfWYI8LXg
I particularly like the check engine light.
This one is kinda fun, too:
http://www.youtube.com/watch?v=OISnUU3tp5w
Bastage
12-17-2008, 07:57 AM
or this one?
Correct. Thanks for finding those. Prodigy and Guns N' Roses are both on my iPod. Chinese Democracy came out, and people have said that that will happen when hell freezes over, so maybe there's hope for you.
And yeah, all of us Pettit Owners had a check engine light until October of last year when they developed their own reflash solution. My car does not have one, and neither does the car that produced this dyno:
http://s212.photobucket.com/albums/cc7/bastage_2005/juanhp.jpg
marsredr100
12-17-2008, 08:18 AM
Is that the best you can do Jeff? :lol:
I highly recommend giving this people a call/visit.
http://www.counselingconsulting.org/anger-management.html
Or a little bit of Puerto Rican rotary know how.
http://www.youtube.com/watch?v=cqezMv8k-ME
http://www.youtube.com/watch?v=O1ZStKvjVTk
http://www.youtube.com/watch?v=YMudrPezvmQ
and also 4 cylinders too.
http://www.youtube.com/watch?v=VYcFsZgRvf4 :eyetwitch
Kane
12-17-2008, 10:53 AM
Hey; anyone heard about that 330 HP dyno?
Bastage
12-17-2008, 10:58 AM
yeah, ain't it great? :D:
It will be even better when all of us have that kind of power.
mysql
12-17-2008, 11:09 AM
Nothing beats having to buy all new hardware to change boost, only to find out that elevation throws it off, requiring you to swap pulleys to maintain a specified pressure.
I heard it was the best thing since... a boost controller.
I like my wastegate. 0.2 bar spring, so 2.9 psi no matter what elevation with load. Turn the knob, configurable to any pressure I want instantly. Worried about overboost? Set the overboost PSI so that over X pressure, open the wastegate to bypass.
boost controller is also $300.
marsredr100
12-17-2008, 11:26 AM
Are you kidding me?
Here’s a coloring book. I’ll keep you busy while driving your slowpoke NA RX8 around town. :eyetwitch
mysql
12-17-2008, 11:27 AM
Yeah, not kidding you. Even a base greddy kit makes more torque. Enjoy.
marsredr100
12-17-2008, 11:33 AM
Enjoy.
I am. :lol: :eyetwitch
Red Devil
12-17-2008, 11:41 AM
My e-penis is bigger than yours...can you tell????
Bastage
12-17-2008, 11:45 AM
The pulley costs like a quarter of what a boost controller costs, and once we switch to this one, we won't want to switch again since we'd risk overspinning the blower.
Considering that the mean elevation here in Florida (where we both live) is like 100 ft above sea level, why should we care? Are you planning on moving to Colorado or something?
By the looks of your sig and your posts you'd almost think that your car's engine never died and you're still turboed.
marsredr100
12-17-2008, 11:48 AM
Absolutely, you D-man. :worship:
RedefineRX8
12-17-2008, 11:54 AM
:lol: this thread delivers!
Brettus
time to get comfortable - sit back and watch the show
http://i154.photobucket.com/albums/s255/brettus_rx8/sofa.jpg
Bastage
12-17-2008, 12:16 PM
Is it too much to ask to let this guy enjoy his accomplishment without a bunch of people coming here and trying to rain on his parade? :)
RedefineRX8
12-17-2008, 12:17 PM
Yes, this is the internet. Of course that is too much to ask. Duh.
Also makes it hard for people trying to consider their options to siff through so much fickle bullshit to get thoughts from OWNERS when threads turn into ones like this. Maybe I'll just start talking directly with S/C owners instead of trying to get information in a thread named for it's owners.... yep..
Bastage
12-17-2008, 12:21 PM
:lol:
Yeah, I guess you're right :)
olddragger
12-17-2008, 12:30 PM
fish oil tastes like crap--may have to add catsup.
never mind the hp--talk about that tq curve----errrrr what curve lol!
makes the car very predickable.
OK --may have found part of the fuel starvation fix quest(check thread for full explanations)
when you compress our fuel pump unit(like you do on the install) there is a overhang ledge in the front part(where little arrow is) over the can assemble itself. The flat side of the can .I think it is reasonable to say that that ledge will impede fuel overflowing into the can during accelleration/certain turns etc. there really isnt much space inbetween the top of the assembly and the can itself and the inner part of the assembly does not leave much room for fuel to overflow (as in full tank) into the can itself --at least the front part. You cant get rid of this ledge/overhang. SO i notched the can--in the front--between the two little plastic bracket hanger things(we dont use). This should open up the can so fuel can get in more easily when the tank is at full to 3/4.
This is only part of my theory addressing this problem.
External fuel filter placement is being formulated. I was able to remove the oem filter from its house leaving the regulator/venturi line intact. wasnt easy.
back to the show!!
OD
