rotaryPilot
09-26-2007, 06:47 AM
Hi all,
Well as it is known every stock RX-8 with 18inc Rims comes with 225/45-R18. However, a version available at Germany, Greece and some other countries comes with 235/40-R18 and different design rims but 8JJ.
I guess that 225/45-R18 is similar to 235/40-R18 but also have some differences.
Which one do you think is most appropriate for RX-8. I would go for the well know stock 225/45-R18 and I do not know the reason why the dealer in Germany or some other countries fit 235/40-R18 to a specific version of RX-8.
Do you think that 225/45-R18 may have an advantage over 235/40-R18 ????
rotaryPilot
09-26-2007, 08:19 AM
In order to help you more in the photo below you can see the RX-8 version with
235/40-R18 which is called Revolution compared to Cosmo the stock 6 Manual 231 with 225/45-R18 and challenge the stock 192 5T manual with the same tires (225/45-R18)
Do you see any disadvantage of 235/40-R18 compared to 225/45-R18???
http://www.imageshack.gr/images/1m1omfwmr1mj2hkigzwz.jpg (http://www.imageshack.gr/viewer.php?file=1m1omfwmr1mj2hkigzwz.jpg)
takahashi
09-26-2007, 09:00 AM
Not sure what you are on about, but:
235 has slightly higher reading than you actually travels. e.g. it may read 102mph but you're travelling at 100mph.
235 fits better in a 8" rim than 225 in most brands of tyres.
235 is smaller and your car looks lower (well it is actually lowered).
235 has a bigger foot print.
235 may have more choices of tyres makes and pattern in your country (well at least 235 is more common in Australia than 225).
rotaryPilot
09-26-2007, 09:08 AM
Well my question is:
Will an RX-8 with 225/45-R18 perform in a drag race slightly BETTER than an RX-8 with 235/40-R18??? (other things being equal)
I am talking even for very small differences !
takahashi
09-26-2007, 09:12 AM
235 - bigger foot print. More grip for launch. Why not?
235 - Side wall is stiffer. less movement.
rotaryPilot
09-26-2007, 09:31 AM
^ what about 235 has more friction than 225 so may perform worst. WHY ΜΑZDA installs 225 in every manual 6sp and not a 235 which may be chipper?
