View Full Version : What rotors with Hawk HPS???
poweredbyplaav 09-25-2007, 10:46 PM all 4 of my rotors/pads need to be replaced. Im planning on going with the Hawk HPS pads all around but not sure with which rotors to go with. there is: drilled, slotted, or neither. which would you guys recommend????
i remember reading some where that when the rotors are drilled/slotted, they tend to crack sooner, unless you go with the full brembo kits. but that sounds wrong since the whole purpose of having drilled/slotted is for better ventilation so they dont heat up as much. so what do u guys think? any experiences with specific rotor brands?
any feedback is appreciated...
peterlemonjello 09-26-2007, 08:12 AM I have rotora slotted rotors with Hawk HPS pads. I'm very pleased with the combination. I stayed away from the drilled rotors because some people said they're more likely to crack. I'm not sure how true that is for normal street driving. The only cracked drilled rotors I've seen are on cars that frequent the track.
poweredbyplaav 09-27-2007, 12:24 AM how long have you had the slotted rotors?
Wind Dance 09-27-2007, 03:57 AM slotteds are fine... Cross drilled on a oem blank disk is not a good choice.
May i ask what are you planning on doing with this? Auto-x, track, some type of racing? If not blanks are easier and best choice.
Brembo makes oem sized slotted, rotora, power slot, ebc are all good choices.
If your into jdm you can invest in some project mu but then those are pricey.
peterlemonjello 09-27-2007, 09:41 AM I've had them for 14,000+ miles. I had to replace the OEM pads and rotors at 35,000 miles.
So far the rotors are wearing much better than the OEM's. The Hawk HPS pads feel similar to the OEM pads with a lot less brake dust.
FYI, here's some rotora rotors and Hawk pads for sale on the forum.
http://www.rx8club.com/showthread.php?t=126544
http://www.rx8club.com/showthread.php?t=127624
Razz1 09-27-2007, 01:00 PM I have rotara rotors too!
Hawk pads eat rotors. That's why I use Portefield brakes.
GRGJTSN 09-27-2007, 06:32 PM I recommend RacingBrake.com rotors. I have the cross-drilled and curve-slotted rotors with Hawk Pads, and am very happy.
P.S. Look in the vendor section for AutoRnD, PM him (Rishie is his name) and he will give you a good deal if you decide to go with RacingBrake.
poweredbyplaav 09-27-2007, 07:21 PM slotteds are fine... Cross drilled on a oem blank disk is not a good choice.
no autocrossing...just want some good rotors for street driving. aside from the "cool factor" of slotted or cross drilled, there really isnt an advantage is there?
if slotted hold up and dont crack, then ill go with those.
NotAPreppie 09-28-2007, 01:46 AM For street use? No. Actually, probably less stopping power for street use with slotted/drilled rotors as there is less friction surface and no real benefit with the voids.
8rotor8 09-28-2007, 02:23 AM about the rotora front's, which way did you guys align the slots? against or with the forward rotation?
Wind Dance 09-28-2007, 04:08 AM no autocrossing...just want some good rotors for street driving. aside from the "cool factor" of slotted or cross drilled, there really isnt an advantage is there?
No, no real gain unless you can heat up your rotors enough on the street, but then you would be seen as a LUNATIC.. lol jk
Brembo oem blanks are fine, bling factor slotted for a few dollars more
Wind Dance 09-28-2007, 04:08 AM about the rotora front's, which way did you guys align the slots? against or with the forward rotation?
With
poweredbyplaav 09-28-2007, 03:32 PM No, no real gain unless you can heat up your rotors enough on the street, but then you would be seen as a LUNATIC.. lol jk
well on my previous car i had the brembo blanks and they were fine but im having a hard time finding the brembo blanks on our cars. you sure they make them for rx8s?
Wind Dance 09-28-2007, 07:25 PM they should i mean brembo is one of the largest.
try this place:
http://www.livermoreperformance.com/mazda_brake_rotors.html
poweredbyplaav 09-28-2007, 10:32 PM they should i mean brembo is one of the largest.
try this place:
that site doesnt have rx8s either. they have brembo rotors for rx7s but nothing for our 8s. i would assume that brembo makes them for rx8s but i havent come across any.
Mazurfer 09-28-2007, 10:40 PM Racing Brake two piece slotted gets my vote!
http://www.racingbrake.com/RX8_SPORT_FRONT_04_07_p/90151-211.htm
http://www.racingbrake.com/RX8_REAR_04_07_p/9017-111.htm
Wind Dance 09-29-2007, 01:12 AM :D: My vote goes to Project Mu two piece..
http://www.nyxracing.com/project-rear-rotors-mazda-p-18952.html
if i were a baller ^.^
But yeah anywho.. this place has alot of good parts
http://www.good-win-racing.com/mazda/miata/index.html?id=CVBc7UjZ
i vote racing brake 2 piece curved open slot (like mine :)) all around. even if you dont race, reduced rotational mass will theoretically allow you to accelerate quicker, brake quicker, and even get better gas mileage :p:
