17"/18" wheel setup
Old Sep 24, 2007 | 08:47 PM
nex100's Avatar
17"/18" wheel setup
Hi Guys, Anyone here is on a 17" wheel setup? same all round or staggered? I am trying to make a choice between 17" or 18" and I'm on Malaysian roads alot where there is a lot of pot holes. Will 18" tyres be too thin such that will damage the rims when kena pot holes?
Or should i stick to my current 16" wheels?
Old Sep 24, 2007 | 08:59 PM
csl's Avatar
csl
It is not the tyres thin but bigger diameter = weaker rim. I have both 17" and 18" on different cars. 17" still survive until today. But the 18" got 1 pc already bent.
End of the day, it will still depends on the driving behavior. 15" will not survive on a berserker's right feet.
Old Sep 24, 2007 | 09:34 PM
nex100's Avatar
nope i am a normal driver not a mad man so assuming this the 17 inch will survive the pot holes more than the 18 inch assuming both forged rims.
Old Sep 24, 2007 | 09:35 PM
lennon's Avatar
Dont use forge rim if you want long lasting rim.......
Old Sep 25, 2007 | 12:18 AM
Mazdaspeed 88's Avatar
Limited
Lennon, you meant forge rim is only for lighter but not stronger or lasting... interesting, I thought of getting the forge rim...
Old Sep 25, 2007 | 03:59 AM
coupe07's Avatar
SC 300HP!!
forged rims are light and very strong wat....
Old Sep 25, 2007 | 04:18 AM
nex100's Avatar
from what i know it is supposed to be light and strong. Looks like all the rx8 in sg all use 18 inch no one uses 17 inch wheels
Old Sep 25, 2007 | 08:41 AM
Stephy88's Avatar
in'sti·ga'tor
(+) Forging uses intense heat and/or pressure to transform a solid slug of alloy material into the final shape of a wheel. Forged wheels are typically lighter and stronger than their cast counterparts.
(-) Forged wheels are more expensive due to the cost of the manufacturing and machining processes
nex100,
18s" are stock setup for the MTs. i do see some 17s" around thou.
imho: choose 1 good one, 1 you like... wear it, like it, play safe with it
Old Sep 25, 2007 | 09:06 AM
Limited
Yes, that's what I know too... and did some research on forged rim from Wheel Tech:
FORGED OR SEMI-SOLID FORGED
In forged wheels, computer numerically controlled (CNC) mills add the cosmetics and the bolt circle to exacting tolerances.
The ultimate in one-piece wheels. Forging is the process of forcing a solid billet of aluminum between the forging dies under an extreme amount of pressure. This creates a finished product that is very dense, very strong and therefore can be very light. The costs of tooling, development, equipment, etc., make this type of wheel very exclusive and usually demand a high price in the aftermarket.
Old Sep 25, 2007 | 03:08 PM
csl's Avatar
csl
17" pickup faster than 18" :D
Old Sep 25, 2007 | 07:37 PM
lennon's Avatar
I dunno whether it's because of the manufacturing quality or wat..... My 3 year old BBS is in better shape than 3 month old Mazdaspeed rim (well that was checked 2 years ago)......
Old Sep 25, 2007 | 08:21 PM
mkl22's Avatar
i use 17x8. much lighter combo than the stock rims. i run an undertired setup too. 225/45/17 front and 245/40/17 rear on michelin pilot sports2. pick up and handling is better than my stock rim with AD07. maybe its the tires.
Old Sep 25, 2007 | 08:41 PM
Spin9k's Avatar
Momentum Keeps Me Going
My 17x9 with 245/45 ride much nicer than the 18x9.5 with 275/35. I esp notice it as I have coilovers. With the 18s I keep the tire pressure down to improve the ride, but if I was to hit a good sized pothole...maybe low pressure is not so good (I haven't). I also think the 17 accelerate faster but the steering response is a tad slower.
Old Sep 26, 2007 | 05:43 AM
Stephy88's Avatar
in'sti·ga'tor
size does matter... in 1 way or another
really is wat you want...
looks vs comfy vs weight vs cost etc...
Old Sep 27, 2007 | 01:21 AM
nex100's Avatar
What kind of rims are you using? How much is the weight?
Old Sep 27, 2007 | 03:52 AM
Spin9k's Avatar
https://www.rx8club.com/showthread.p...ight=hotwheels
Old Sep 28, 2007 | 06:29 AM
nex100's Avatar
I don't quite get it when you say steering respose is slower. You mean bigger rims give better steering response? Now I am using 16 inch so my steering response when i switch to 17 inch will be better than now?
Rx8 VA Guy
Jun 4, 2016 12:42 AM
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
GranTouTou
Sep 30, 2015 06:11 AM
