Will the OEM EVO VIII/IX 17" wheels fit rx8?
Old Sep 19, 2007 | 03:23 PM
blipblip's Avatar
The offset is somewhere in the 30-35 range.
Old Sep 19, 2007 | 04:06 PM
Willicuddy's Avatar
I'm sure you could make them fit with some fender mods. What size width are they?
Old Sep 19, 2007 | 04:14 PM
dillsrotary's Avatar
jersey fresh
stock's i believe are 17x8
Old Sep 19, 2007 | 04:35 PM
blipblip's Avatar
Yes. It is 17x8. I would prefer not to modify anything. I forgot to mention the rx8 I have is the 6spd version.
Old Sep 19, 2007 | 05:08 PM
jersey fresh
the rim will fit over the brakes, its the offset you'd need to check, I dont' know the stock evo's offset, but alot of there aftermarket rims run 30 mm and lower which isn't rx8 territory
Old Sep 19, 2007 | 05:47 PM
Endless Rotaries's Avatar
YES IT WILL WORK.
They are hubcentric as well for the RX8. 67.1
Rishie
Old Sep 19, 2007 | 07:45 PM
AcidAngel7477's Avatar
Once Again..
i thought all 8's were 6 spd. ?
:AA:
Old Sep 19, 2007 | 09:38 PM
blipblip's Avatar
Thanks for the information.
:AA:
Old Sep 20, 2007 | 12:42 AM
8 Maniac's Avatar
Senior Member
:AA:
usually 6 speed is assumed to be the manual option as opposed to the 6 speed auto.
Old Sep 20, 2007 | 12:57 AM
987HYS's Avatar
Dragon Certified
the new AT have a 6 spd, 6 port or 4 spd
Old Sep 21, 2007 | 09:07 AM
ngkenny's Avatar
stock standard
yes it will fit like a glove.
i am using it for track.
Old Sep 25, 2007 | 10:15 PM
nickmc19's Avatar
so since the wheels fit, can you swap on the brake system as well?
Old Sep 27, 2007 | 12:32 PM
Not without fabrication, brakes are totally different.
don't jimmy rig your brakes.
Kahl
Aug 20, 2015 11:49 PM
Mr.Durden
Aug 12, 2015 02:21 PM
Sakebomb Garage
Vendor Classifieds
Jul 31, 2015 07:36 PM
Jazzmeson
Jul 31, 2015 01:47 AM
Brandonien
Jul 30, 2015 12:33 PM
