Brake help?
Old Sep 16, 2007 | 03:46 PM
CnnmnSchnpps's Avatar
No means yes
Angry Brake help?
Hi guys.... I tried searching and looked in the FSM but came up empty... Got a quick question..
What's the thickness of the stock brake rotors, new? I know the minimum allowable thickness is 22mm front / 16mm rear (per the FSM)... But I want to try to figure my wear in terms of percentage...
-Dmitri
edit
Thanks to RX8Maine, here are the full specs for brake rotor thickness:
Front: 24mm new, 22mm minimum (need to be replaced)
Rear: 18mm new, 16mm minimum (a new set measured at 18.1mm)
Old Sep 17, 2007 | 11:47 PM
DOMINION's Avatar
I don't buy Kool-Aid
If your saying the stock thickness is 22mm then just take your 8 to a brake shope. Have them measure your rotors. That right there will tell you how thin they are from when you first got them. IF you have owned the car from the start based on your driving and / or if you just got new rotors.
Old Sep 17, 2007 | 11:57 PM
No means yes
Gesundheit!
I do not know the original size. I went out to Sears and bought a micrometer so I know the current size (incidentally, my front right is way out of spec for thickness variation... but I'm not concerned about that for now).
22mm is the point at which the FSM tells you to change them. Mine are at 22.8. I wanted to figure out what the original thickness was, so I could say either "oh, they're still at 20%" or "crap, they're at 3%" or something...
Anyone?
Old Sep 18, 2007 | 11:11 AM
markstibbyspot's Avatar
i would also like to know!
Old Sep 18, 2007 | 01:09 PM
No means yes
Going to a meet tonight... Hopefully someone will have a car new enough to give me a good idea...
Old Sep 25, 2007 | 11:08 PM
No means yes
Bump! The meet fell through (ended up at the wrong place)... Does anyone know???
Old Sep 26, 2007 | 03:36 PM
RX8Maine's Avatar
They are listed as 24mm stock, per specifications, but I have never actually taken a micrometer to a new one.
Mine are at 23.2mm after 17,000 miles and 3 track days (approx 4 hours track duty total) on OEM pads.
I would love to know the original thickness of the rear rotors. I haven't found it anywhere.
Old Sep 27, 2007 | 12:15 AM
No means yes
Cool, thanks for the info! That would mean my fronts are at approx 40% (59k miles, 13 of those mine, no track days that I know of)... The rears I am less concerned about but if someone could dig up the numbers that would be great!
Old Sep 27, 2007 | 12:27 PM
Rear brake Pad
min pad thickness 2.0 mm or .079 inches
Rear disc
min disc plate thickness 16mm or .063
Run out limit is the same for both front and rear. Set at .05 mm or .002 "
Old Sep 27, 2007 | 11:10 PM
No means yes
Razz1: Thanks, but I can get that from the FSM I am trying to figure out the original size when new...
Old Sep 28, 2007 | 06:35 AM
RX8Maine's Avatar
As it turns out, I have a new rear rotor on order. I'll measure it when it arrives.
Old Sep 28, 2007 | 08:54 AM
DOMINION's Avatar
^May I ask why?
Old Sep 28, 2007 | 09:27 AM
RX8Maine's Avatar
The old one didn't like meeting the backing plate of the inner pad.
Mazda never thought to put wear indicators on the rear, so I used up a rear pad at the track and was probably dragging the backing plate for at least part of my last session, and on the drive home.
Old Sep 29, 2007 | 06:10 AM
RX8Maine's Avatar
New rear rotor is rated 18mm in thickness and measured to 18.1mm on the micrometer.
Old Sep 29, 2007 | 02:03 PM
No means yes
Sweet! Thanks all... Will update the first post
hufflepuff
May 30, 2016 10:45 AM
Road Cone
Nov 6, 2015 01:52 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
