Sway bar install issue...
Old Sep 16, 2007 | 12:14 AM
rxaddict's Avatar
I went to install my progress sway bars tonight but ran into a problem. All the nuts came off the bushings easily enough - as did the driver side bolt connecting the stock sway bar to the end link. The same bolt on the passenger side, however, just turned endlessly without loosening or stripping. Any ideas or suggestions?
This is my first post, btw. I've already gotten tons of great info off this site and am very grateful for all those who contribute...this really is an amazing site.
Old Sep 16, 2007 | 08:12 AM
8rotor8's Avatar
Back in the day...
was it the front or rear? post some pictures to make it a bit clearer of what happened.
It seems like the bolt did strip though...
Old Sep 16, 2007 | 08:54 AM
O'Renesis's Avatar
You should check this thread for information as to how to remove the endlinks, it should help with your issue, https://www.rx8club.com/showthread.php?t=43677.html
Old Sep 16, 2007 | 09:02 AM
qtwre's Avatar
You're just spinning the ball joint. You'll find the threaded stud (bolt) has a hole for an alan key. Put the key in there and hold it as you turn the nut with a wrench. Easily done.
Old Sep 16, 2007 | 11:17 AM
ac3mastuh's Avatar
Got Ings?
yup, i did the same thing when i installed my sway bars
you've really got to hang on though to that allen wrench since it takes a fair amount of torque to undo it
Old Sep 16, 2007 | 11:32 AM
rxaddict's Avatar
Sorry guys, that was my mistake. I was using a breaker bar like a moron =) Thanks for the quick replies.
Old Sep 16, 2007 | 11:47 AM
NgoRX8's Avatar
yea sometimes the endlinks require you to use and allen wrench. i never needed it, but plenty of people did.
Prescription 8
Non-Rotary Swaps
117
Feb 14, 2018 12:07 PM
Brokegang
Jan 3, 2016 12:45 PM
zoom44
General Automotive
Nov 16, 2015 11:38 PM
Steve Dallas
Sep 19, 2015 09:39 AM
