check Engine light with K&N intake
Old Sep 12, 2007 | 09:48 PM
Roxie 1's Avatar
Exclamation check Engine light with K&N intake
I have the old version K&N just installed and the dsc was blinking off and on and traction light was on then I test drove it and floored it and the check engine light just came on when i got back home and turned the car off and started it and the dsc was off and traction light but check engine was still on, turned it off and started it again and nothing still check engine light, also found strange heat comming from the engine but the fans are working stll...
Please help thanks guys..
Old Sep 12, 2007 | 10:03 PM
First of all, why would you want K&N version 1 ? it is CRAP. I had it, and yes its CRAP.
and try to find out whats your CEL code before posting.
Damn its hard to read it like this next time try to break it in parts or something can you do that please because I was about to throw up just by reading what you wrote ok thank you now go find our what your CEL is and post them here without it god knows what it is it might be gas cap or whatever but just go find the CEL code some auto parts store like autozone can pull the code out for you for free so just check around do not go to dealership for this
Old Sep 12, 2007 | 10:06 PM
Roxie 1's Avatar
Thumbs up
ok thanks ill post CEL code asap
Old Sep 12, 2007 | 10:52 PM
Roxie 1's Avatar
cell code
cell code is
Cylinder 1 detected misfire
Any clue guys
Old Sep 14, 2007 | 11:02 PM
It happens sometimes.
whats ur miles ?
but b4 anything, I still suggest you to take that Version 1 off and put stock intake back on for now.
Old Sep 16, 2007 | 04:22 PM
Roxie 1's Avatar
Exclamation engine light bad again
I reseted the ecu for the check engine light for cylinder misfire 1 went off for two days then went on again but this time its a cylinder misfire 2 I have a 2004 with 15,600 miles on it, my two mods I installed were the KNN V1 and Agency Power Crank pulley any clue guys before I change everything back to stock. please reply asap
Old Sep 16, 2007 | 06:26 PM
Change it back to stock, bring it to dealership and check
what yr is ur 8 ? Mt or AT ?
Old Sep 17, 2007 | 08:30 AM
mmats69's Avatar
93.5 octane
Get that intake out of there!!
vapor2
Nov 3, 2020 03:38 PM
Sifu
Aug 30, 2015 10:51 PM
marc2820
Jul 26, 2015 10:47 PM
netrovers
Jul 20, 2015 03:32 AM
