Help! Radio LCD Display Issue....
Old Sep 9, 2007 | 06:18 PM
Ducky's Avatar
I got my Stereo installed, (new speakers, new Amps, Rockford fosgate 3sixty.2 on a bose stereo, everything works great, sounds great, but every once in a while, the LCD on my radio starts flickering, this morning I got up and it wasnt on at all, its like the LCD backlight is on, but the letters dont show up, went to work, everything still works no letters/numbers on the LCD, went into work, got into car and everything is fine again... Is there some wire that goes from that to the rear bose amp? that I might have loose? or is all that in the front under the deck? (I have the factory deck still if you needed to know that) Please give me things to check... Its not showstopping, but sure is annoying...
Old Sep 9, 2007 | 06:21 PM
lurch519's Avatar
www.evoperform.com
sounds like the connection between the radio and the display is loose. check that
Old Sep 9, 2007 | 06:23 PM
Ducky's Avatar
This is going to sound stupid, but is that directly behind the deck? Im guessing it is, but was hoping that something in the back was loose, because i didnt touch the front...
But its worth a shot, thx for the quick reply, any other suggestions welcome!
Old Sep 9, 2007 | 06:26 PM
lurch519's Avatar
www.evoperform.com
its behind the deck, on one side (i forget which side though) if thats not it, it may be something damaged on the radio circuitry from when you took the radio out. it is very easy to do, especially if you arent familiar with taking the radio out.
Old Oct 14, 2007 | 05:40 PM
Ducky's Avatar
Thx, it was the one on the side not in all the way, silly cables..
Old Aug 21, 2013 | 09:20 PM
Aragon26's Avatar
I've never replaced my deck and I still have this problem. Is the wire hard to get to? Do you know if there's a how-to anywhere?
Shankapotamus3
Mar 14, 2021 03:53 PM
nadodave
Aug 28, 2019 05:55 AM
RX8mzda
Oct 1, 2015 10:17 PM
ShellDude
Oct 1, 2015 09:55 PM
Learners_Permit
Sep 27, 2015 07:38 PM
