350z wheels for my 8
Old Aug 29, 2007 | 01:42 PM
tksnobords's Avatar
TK
hey guys...i'm looking at getting a set of 03-05 6 spoke 350z wheels for my 8. I need some drift wheels. Has anyone used 350z wheels on their 8 before? I just talked to my local discount tire co...they said that the 03-05 350z is 5 x 4 1/2 (114.3) and they said the same for the rx8. The only thing i'm not sure about is the staggard setup of the 350z...what do you guys think....
Old Aug 29, 2007 | 01:49 PM
Spinning Sushi's Avatar
I <3 Sushi
If you want good track wheels from Nissan, buy the 19'' OEM G35 wheels. They are manufactured by Rays so they should be pretty light.
Old Aug 29, 2007 | 01:50 PM
tiltmode43's Avatar
OMGITM!
https://www.rx8club.com/showpost.php...&postcount=400
Old Aug 29, 2007 | 03:05 PM
tksnobords's Avatar
TK
i just need another set of cheap wheels and tires. but if i find a set of G35 wheels, thats cool with me. light wheels would be great!
Old Aug 29, 2007 | 03:15 PM
tksnobords's Avatar
TK
"(The wheels are from a Z, they were given to me and are definitely the wrong offset... but they fit, and they bed themselves into the fender liner after a few weeks, so no rubbing anymore)"
the wheels in the pictures arent the same wheels as the ones i'm looking at. but i appreciate the post.
Old Aug 29, 2007 | 06:42 PM
SolarYellow510's Avatar
This keeps coming up here. RX-8 wheels are 50mm offset, if I remember right. If you can stay close to 45mm, that's best. Z wheels are in the 22-30mm range, typically. The difference is how much they'll stick out compared to the right fit.
Do yourself a favor and get wheels that fit right.
Old Aug 29, 2007 | 06:44 PM
LionZoo's Avatar
road warrior
The wheels in that post are AFTERMARKET wheels from someone's Z; definitely not the same as stock. I would add that in addition to an incorrect offset, I think the Z has a smaller hub bore than the RX-8, which would require some machining if you really, absolutely, positively, must have Z wheels.
Old Aug 29, 2007 | 06:55 PM
tksnobords's Avatar
TK
i just need a set of drift wheels and i found a set of 350z wheels for a good price...
Old Aug 29, 2007 | 07:02 PM
tksnobords's Avatar
TK
just talked to les schwab...
the rx8 offset is 48+. The hub bore is 67.1
the 350z offset it 35-42. And the hub bore is 66.1
basically...thanks for your input guys...but they just wont fit
Old Aug 30, 2007 | 06:47 AM
rx8spiritR's Avatar
----Got Rice?----
see......you got it!
Old Aug 30, 2007 | 07:23 AM
DrewMan's Avatar
Culpam Poena Premit Comes
get that drill out and machine them!
Old Aug 30, 2007 | 01:07 PM
tksnobords's Avatar
TK
"To maintain handling characteristics and avoid undue loads on bushings and ball joints, the car maker's original offset should be maintained when choosing new wheels unless there are overriding clearance issues." -wikipedia
i don't want to put any extra stress on my baby 8
hufflepuff
May 30, 2016 10:45 AM
snowrydr01
Nov 23, 2015 09:40 AM
duworm
Oct 1, 2015 04:57 PM
GranTouTou
Sep 30, 2015 06:11 AM
